SMS after dead battery
(06-05-2020, 05:14 PM)a-wai Wrote:
(06-01-2020, 08:40 PM)antiX-Dave Wrote: Still trying to figure out if there is a software reason for this that gets run on shutdown but not reboot or if it is simply due to fully powering off the modem.
This is probably due to fully powering off the modem yes, as there are no difference from the Linux side between shutdown and reboot (the same modem script is executed)
Thank you for verifying this.
It was suspect to me that this would be the case. On the flip side / looking at it from another angle I was thinking "why does deleting one message and rebooting also work if the modem is not being powered off? can it be done without a power cycle? "
Either way just voicing some thoughts, and poking around trying to learn the system a little.
SMS after dead battery - by antiX-Dave - 05-26-2020, 05:49 PM
RE: SMS after dead battery - by rico - 05-27-2020, 09:46 PM
RE: SMS after dead battery - by antiX-Dave - 06-01-2020, 08:40 PM
RE: SMS after dead battery - by a-wai - 06-05-2020, 05:14 PM
RE: SMS after dead battery - by antiX-Dave - 06-05-2020, 08:11 PM
  Battery problem with a Pinephone keyboard and Mobian elode 2 4,732 12-22-2022, 07:10 PM
Last Post: acid andy
  Possible solutions to the battery draining issue? 3x5co 5 6,520 11-28-2022, 10:58 AM
Last Post: 3x5co
  Will this battery-saving script cause problems? rp3 1 2,973 08-28-2022, 02:00 PM
  Battery Management jsch 4 4,925 07-27-2022, 11:17 AM
Last Post: jsch
  Telephony Dead jhasler 3 3,836 05-06-2022, 09:05 AM
Last Post: jhasler
  Limiting battery charging to some percentage TRS-80 3 5,866 08-22-2021, 01:02 AM
Last Post: bcnaz
  Increasing max voltage to use a bigger battery SocialNetworkingWasAMistake 4 6,914 06-09-2021, 09:59 AM
Last Post: wibble
  Possible fix for lousy standby battery life? bitnick 5 8,398 02-04-2021, 04:05 PM
Last Post: dcinoz
Sad battery usage HLing 3 7,036 08-29-2020, 06:04 AM
Last Post: User 18618
