SMS after dead battery
(06-01-2020, 08:40 PM)antiX-Dave Wrote: Still trying to figure out if there is a software reason for this that gets run on shutdown but not reboot or if it is simply due to fully powering off the modem.
This is probably due to fully powering off the modem yes, as there are no difference from the Linux side between shutdown and reboot (the same modem script is executed)
SMS after dead battery - by antiX-Dave - 05-26-2020, 05:49 PM
RE: SMS after dead battery - by rico - 05-27-2020, 09:46 PM
RE: SMS after dead battery - by antiX-Dave - 06-01-2020, 08:40 PM
RE: SMS after dead battery - by a-wai - 06-05-2020, 05:14 PM
RE: SMS after dead battery - by antiX-Dave - 06-05-2020, 08:11 PM
  Battery problem with a Pinephone keyboard and Mobian elode 2 4,854 12-22-2022, 07:10 PM
Last Post: acid andy
  Possible solutions to the battery draining issue? 3x5co 5 6,725 11-28-2022, 10:58 AM
Last Post: 3x5co
  Will this battery-saving script cause problems? rp3 1 3,037 08-28-2022, 02:00 PM
  Battery Management jsch 4 5,088 07-27-2022, 11:17 AM
Last Post: jsch
  Telephony Dead jhasler 3 3,920 05-06-2022, 09:05 AM
Last Post: jhasler
  Limiting battery charging to some percentage TRS-80 3 6,000 08-22-2021, 01:02 AM
Last Post: bcnaz
  Increasing max voltage to use a bigger battery SocialNetworkingWasAMistake 4 7,055 06-09-2021, 09:59 AM
Last Post: wibble
  Possible fix for lousy standby battery life? bitnick 5 8,600 02-04-2021, 04:05 PM
Last Post: dcinoz
Sad battery usage HLing 3 7,182 08-29-2020, 06:04 AM
Last Post: User 18618
