How about a hard power switch? + crash report
(05-16-2020, 10:34 PM)Der Geist der Maschine Wrote: Sysrqs are triggered over procfs or keyboard combinations. [..]
How have you traced invocations of sysrqs?
SYSRQs can also be issued over the UART. And the UART on the PBP is also being used as the headphone jack for audio.
There is significant (~3Vpp) Crosstalk between the audio and UART lines. This is a hardware issue.
Here's a video of my PBP playing audio at full volume (and already distorting a little bit):
https://www.youtube.com/watch?v=MPKHM1J_Uxk
This causes erroneous inputs on the UART /dev/ttyS2. Normally ttyS2 has a getty and the kernel will respond to SYSRQs on this terminal.
These inputs will cause all sorts of behaviour, including hangs, crashes and stuttering because the kernel will stop everything it does to parse the SYSRQs.
If you want to reproduce this, set everything in alsamixer and pavucontrol to max volume, play a loud rock song and make sure to stop serial-getty@ttyS2 (or the equivalent for your OS, otherwise the getty will fetch all your tty input before your cat can).
RE: How about a hard power switch? + crash report - by manawyrm - 05-18-2020, 12:00 AM
  Lockable-until-power-cycle persistent storage Melab 0 667 09-17-2023, 08:51 PM
Last Post: Melab
  power on Pinebook Pro mainboard without keyboard? papable 0 786 07-20-2023, 11:06 PM
Last Post: papable
  I'm booting from NVME but I want to switch back to eMMC acruhl 4 1,384 04-23-2023, 06:58 AM
Last Post: acruhl
  When does Pinebook Pro power LED go on? Bram 0 577 03-14-2023, 09:53 AM
Last Post: Bram
  Doesn’t power on after flashing emmc badguru 3 1,138 02-25-2023, 09:00 PM
Last Post: badguru
Heart Now better battery life or power management? KC9UDX 5 2,161 09-09-2022, 08:13 PM
  Pinebook Pro not powering on when eMMC hardware switch is off vgrimaldi 2 2,880 06-29-2021, 05:19 AM
  Gimp makes stock Manjaro KDE/X11 crash stozi 3 4,135 04-21-2021, 08:15 AM
Last Post: stozi
  Replacement Power Cord recommendation? nathanielwheeler 3 3,207 01-23-2021, 06:43 PM
  power light blinking during charge when pbpro is off Idaho 0 1,756 01-04-2021, 10:53 AM
Last Post: Idaho
