Howto run Linux with resolution other than 1080p
#20
(08-30-2016, 11:40 PM)wboson Wrote: Is there a method to move the menus position using X window settings or configurations such that the position will be lower and\or further into the horizontal \ vertical image area?
Thanks for any direction or ideas.
One thing that many have done to work-around this problem is to use vnc4server and the vncviewer on the same machine; in other words, you close your normal desktop.  Then you start an X session on your local machine (it will be off the screen too, but we don't care. Then you start a vnc4server on your local machine with default geometry of something reasonable like 1367x768, at position 20,20, and then on the same machine you start the vncviewer on localhost, displaying on your X session you started earlier. The vnc session can be made to be whatever size and location you want it to be.  The reason this works is that X is a networked interface, and that works over unix domain sockets just as well as over the network.
You will want to play around with the position and geometry settings to get it the way you want it. Another thing, you do not need a desktop up to run this, just an X server for the vncviewer to run in... it does not even have to have a window manager running !
RE: Howto run Linux with resolution other than 1080p - by MarkHaysHarris777 - 08-31-2016, 12:40 AM
  NEMS Linux 1.5 Released for A64/A64+, A64-LTS/SOPine, Rock64, RockPro64 (NAGIOS) Baldnerd 4 14,327 03-28-2020, 06:20 PM
Last Post: ty1911
  NEMS Linux for Pine A64 (+) Luke 1 7,998 05-09-2019, 05:42 PM
Last Post: pineadmin
  Pine Board using linux stuck during boot sequence ktaragorn 4 12,504 03-30-2019, 06:48 AM
Last Post: ktaragorn
  Gentoo Linux test image xalius 23 61,877 01-28-2019, 11:05 PM
Last Post: necrose99
  Real-time linux kernel Artyom 45 101,045 09-11-2018, 01:08 AM
Last Post: zzwpine
  linux distribution hazerty 3 8,615 04-01-2018, 02:48 PM
Last Post: dkryder
  Linux Web Server OS harcrow 2 7,767 01-30-2018, 10:26 AM
Last Post: Rustproof
  eta linux image?? firosiro 1 5,667 08-03-2017, 10:05 PM
Last Post: pfeerick
  Can I run Alpine Linux on Pine64? douglasmiranda 3 10,677 08-01-2017, 07:20 AM
Last Post: cztian
Music HOWTO: jackd on Pine64 mauritslamers 1 5,342 06-15-2017, 01:21 PM
Last Post: xalius
