RockPro64 Linux Manjaro HDMI 4K
(05-02-2020, 05:29 PM)PakoSt Wrote: Hmm...
Alright, I have two other ideas, @mkne :
- Change EnableHiDPI=false to true inside /usr/lib/sddm/sddm.conf.d/default.conf
- Switch from sddm to gdm as a default display manager: systemctl enable gdm.service --force
Currently I'm experimenting to update the Wayfire edition and Plasma-Mobile on pine64lts/ rockpro64 and sddm is giving me some problems there.
Thanks, but no luck I'm afraid. It's a real shame...
This little ARM board is running KDE nicely on wayland and xorg with a mainline kernel.... Just fuzzy on a 4K monitor. On mainline, I'm not convinced the USB-C port is working, but that's a problem for another day...
The kernel initial boot is to 1080 in the console. All the other 4K capable SOCs detect the monitors "preferred" mode and run even the console at 4K. I noticed a patch here:
https://gitlab.com/ayufan-repos/rock64/l...w=parallel
I'm not sure if it's relevant to the Rockpro64, or not? I'm not sure if PINE64 have patches that will be added to the Mainline Kernel...
Do you think this is a Kernel issue?
Thanks,
Mkne
RockPro64 Linux Manjaro HDMI 4K - by mkne - 05-01-2020, 04:25 PM
RE: RockPro64 Linux Manjaro HDMI 4K - by mkne - 05-01-2020, 05:09 PM
RE: RockPro64 Linux Manjaro HDMI 4K - by PakoSt - 05-01-2020, 05:30 PM
RE: RockPro64 Linux Manjaro HDMI 4K - by mkne - 05-01-2020, 05:43 PM
RE: RockPro64 Linux Manjaro HDMI 4K - by mkne - 05-02-2020, 10:09 AM
RE: RockPro64 Linux Manjaro HDMI 4K - by fire219 - 05-01-2020, 05:40 PM
RE: RockPro64 Linux Manjaro HDMI 4K - by PakoSt - 05-02-2020, 12:06 PM
RE: RockPro64 Linux Manjaro HDMI 4K - by mkne - 05-02-2020, 02:29 PM
RE: RockPro64 Linux Manjaro HDMI 4K - by PakoSt - 05-02-2020, 04:40 PM
RE: RockPro64 Linux Manjaro HDMI 4K - by mkne - 05-02-2020, 04:48 PM
RE: RockPro64 Linux Manjaro HDMI 4K - by PakoSt - 05-02-2020, 05:29 PM
RE: RockPro64 Linux Manjaro HDMI 4K - by mkne - 05-03-2020, 06:28 AM
RE: RockPro64 Linux Manjaro HDMI 4K - by PakoSt - 05-03-2020, 07:23 AM
  irradium (based on crux linux) RockPro64 riscv64, aarch64 mara 1 626 03-25-2024, 12:12 PM
  yocto for RockPro64 Fide 1 770 01-16-2024, 10:01 AM
Last Post: Fide
  Installing Ubuntu Server on RockPro64 deutschlmao 2 2,713 10-29-2023, 04:43 PM
Last Post: brotherj4mes
Exclamation Ethernet regression on Linux Kernel 6.5.4? Deathcrow 3 904 09-22-2023, 04:27 AM
Last Post: diederik
  Vanilla mainline Debian 11 (Bullseye) on the RockPro64 Pete Tandy 22 17,865 08-16-2023, 01:34 AM
Last Post: varac
  slarm64 (unofficial slackware) ROCKPro64 RK3399 (aarch64) mara 54 84,300 08-11-2023, 11:13 AM
  Installing CH431SER on Ayufan 0.9.14: gitlab-ci-linux-build-159 Thisone 4 1,405 07-14-2023, 04:22 AM
Last Post: hunderteins
  How to enable CoreSight ETM trace on RockPro64 shpark 0 624 05-21-2023, 11:34 PM
Last Post: shpark
  Linux laptop does not detect the board when plugged in via USB soupy 1 4,078 04-13-2023, 03:01 AM
Last Post: Reynold Grady
  Rockpro64 Dead on arrival? quixoticgeek 1 1,004 03-12-2023, 06:55 PM
Last Post: quixoticgeek
