VoIP with SIP
baresip
1. You need to use a distro that supports glibc. Mobian does. PostmarketOS/AlpineLinux does not.
2. Build it from source so that you can patch the source to run scripts to mute/unmute channels on incoming/outgoing calls.
3. You'll also need to convert ringtones, audio files, etc into a format that the PinePhone supports.
4. Run it in kgx or konsole in a screen just in case kgx/konsole closes or crashes.
It is rock solid and stable. I'm using it in my practice everyday and I make a lot of calls.
I just need to make the screen automatically turn on/off between calls and standby.
VoIP with SIP - by Mangled - 05-01-2020, 07:08 AM
RE: VoIP with SIP - by rocket2nfinity - 05-03-2020, 05:26 PM
RE: VoIP with SIP - by wibble - 05-04-2020, 03:18 AM
RE: VoIP with SIP - by Mangled - 05-28-2020, 06:53 AM
RE: VoIP with SIP - by cmicallef - 06-11-2020, 06:47 PM
RE: VoIP with SIP - by Dmytro - 06-19-2020, 03:43 AM
RE: VoIP with SIP - by calinb - 11-14-2020, 08:34 PM
RE: VoIP with SIP - by JuniperFury - 11-23-2020, 03:23 AM
RE: VoIP with SIP - by kathrin - 01-13-2025, 03:09 AM
RE: VoIP with SIP - by lm2 - 04-07-2024, 10:19 AM
  Jami on Pinephone [ IM and VOIP ] p1trson 14 18,811 06-09-2022, 01:13 AM
Last Post: AndyM
