Xen to run Manjaro and Raspbian
(04-30-2020, 08:36 AM)astr0baby Wrote:
(04-30-2020, 05:06 AM)tophneal Wrote: I’m not entirely sure, no. But Xen cites itself as having ARM support already, and is in the AUR. If the Xen in the AUR is only x86, it’s still likely possible to build on the PBP by editing the pkgbuild. I’d try it out myself, but I’d have to make another Manjaro SD first.
Read a little more into this on the Arch wiki, and I'm probably wrong about the porting, but it looks like there's a pretty quick way to see if it's possible to run Xen on aarch64:
Quote:To run HVM domU, the physical hardware must have either Intel VT-x or AMD-V (SVM) virtualization support. In order to verify this, run the following command when the Xen hypervisor is not running:
$ grep -E "(vmx|svm)" --color=always /proc/cpuinfo
If the above command does not produce output, then hardware virtualization support is unavailable and your hardware is unable to run HVM domU (or you are already running the Xen hypervisor).
There are no vmx nor svm flags on the Pinebookpro in /proc/cpuinfo
only
fp asmid evtstrm aes pmull sha1 sha2 crc32 cpuid
Yeah, once I saw those flag requirements, I knew I was in the wrong. OP will likely need to explorer other options.
EDIT:
I'm in the midst of updating Fedora on the PBP and it appears it already includes Xen. There's also Xen pkgs for aarch64 available here: https://rpmfind.net/linux/rpm2html/search.php?query=xen
Xen on aarch64 may be a possibility, though it might have some restrictions given those required flags.
Xen to run Manjaro and Raspbian - by marawuti - 04-29-2020, 12:12 PM
Xen to run Manjaro and Raspbian - by tophneal - 04-30-2020, 04:27 AM
Xen to run Manjaro and Raspbian - by tophneal - 04-30-2020, 05:06 AM
RE: Xen to run Manjaro and Raspbian - by tophneal - 04-30-2020, 08:39 AM
RE: Xen to run Manjaro and Raspbian - by simba - 05-05-2020, 01:54 AM
RE: Xen to run Manjaro and Raspbian - by wwtaylor - 05-09-2020, 06:50 PM
  Manjaro versions bad and good gilwood 0 191 02-12-2024, 05:03 PM
Last Post: gilwood
  Brand new Pinebook Pro doesn't boot after Manjaro update johnboiles 8 2,001 12-15-2023, 02:11 PM
  PBP won't boot after trying to reinstall Manjaro ARM soupgirl 3 563 12-13-2023, 08:17 PM
Last Post: trillobite
  Games compilation howto on the Pinebook-pro (Manjaro Linux and Debian native) astr0baby 201 314,584 05-12-2023, 06:09 AM
Last Post: korreckj328
  Manjaro Plasma blinking cursor jcun4128 4 1,376 05-08-2023, 11:17 AM
  PBP blank screen after updating Manjaro Franko 6 1,878 04-01-2023, 07:55 AM
Last Post: hacknix
  Manjaro - which libdrm? hacknix 0 530 04-01-2023, 03:21 AM
Last Post: hacknix
  Partial boot after installing Manjaro on emmc regivanx 11 2,971 02-06-2023, 09:11 AM
  Manjaro pinebookpro images with kernel 5.7.19 rfm83 11 4,526 01-22-2023, 10:05 PM
Last Post: rfm83
  No boot after Manjaro flash PBcurry 14 5,158 10-03-2022, 08:33 PM
