Hinge Clicking Noise on Closing and Opening
(05-28-2020, 10:12 AM)diodelass Wrote: I've had this problem on my unit, and it seems to have been more or less completely solved by using a syringe to insert a very small drop of sewing machine oil into the hinge. it took a few days to work its way into the problem area, but my hinge is now pop-free.
Do be careful about getting oil on the ABS surfaces of the device, though, because it might damage them.
Hi diodelass,
I think thats going to be the route i go. Its not done in for a week or so but im going to strip it down when my M.2 adaptor comes and lube everything up. I've got some oil here i use on photocopiers which should handle everything fine as it doesn't run.
Thanks for your reply.
RE: Hinge Clicking Noise on Closing and Opening - by SamWilts - 05-28-2020, 04:26 PM
Question High Pitch Noise Coming From Pinebook Pro User 11436 60 83,188 11-16-2022, 02:51 PM
Last Post: kebab
  Serious hinge crapout ab1jx 7 6,592 10-06-2021, 03:05 PM
Last Post: ab1jx
  Flickering black window when opening settings Edgars10 0 1,346 06-06-2021, 05:42 AM
Last Post: Edgars10
  Hissing noise when using headphones RotatingNut 4 5,343 07-20-2020, 12:56 PM
Last Post: dlowe
  Pinebook Pro sleep issue (hinge?) pciman 1 2,851 07-12-2020, 12:48 AM
Last Post: MtnSk8
Video Pinebook Pro Opening/Use Video kettek 1 3,150 11-06-2019, 12:48 AM
Last Post: aleksei
