Jitsi Meet on the PBP
if you cant select the webcam, then it is likely not detected due to privacy disable.
jitsi meet encodes and decodes video using vp8 by default. as we do not yet have vaapi support working, your best option is to lower the resolution. the pbp will always use cpu encoding and decoding until vaapi support is available, hence the heat and battery impact.
i would change governor to performance and use the power adapter while using jitsi meet and any other cpu intensive task.
if you (or others reading this) are able to help with vaapi support on the pbp, then see my hwaccel thread for ph5's work on libva and libva-v4l2-request and help adapt them to the newer v4l2 api in newer kernels.
Jitsi Meet on the PBP - by Surehand53 - 04-17-2020, 10:12 AM
RE: Jitsi Meet on the PBP - by Moon1 - 04-27-2020, 08:39 PM
RE: Jitsi Meet on the PBP - by jiyong - 04-28-2020, 08:00 AM
RE: Jitsi Meet on the PBP - by jiyong - 05-07-2020, 03:58 PM
RE: Jitsi Meet on the PBP - by Nora No - 05-31-2020, 05:08 AM
RE: Jitsi Meet on the PBP - by jiyong - 05-31-2020, 08:39 AM
RE: Jitsi Meet on the PBP - by xmixahlx - 05-31-2020, 11:34 AM
RE: Jitsi Meet on the PBP - by fozzedout - 06-02-2020, 01:33 AM
RE: Jitsi Meet on the PBP - by lxn - 04-22-2021, 05:57 PM
RE: Jitsi Meet on the PBP - by Surehand53 - 05-06-2021, 09:41 AM
  Google Meet on the Pinebook Pro carlosqueso 2 6,103 10-06-2020, 10:59 AM
Last Post: carlosqueso
