Pinebook Pro structural integerity failing
I don't think me forgetting to put the spacers back is the problem. The two cracks that my PBP got because I didn't put the spacers back in patched right up with super glue, and I have had zero issues with those two since (Loctite, to be precise). The two cracks that are the biggest problem are the ones around the power port and on the top left plastic casing around the keyboard. The two work together for a double whammy, if you will. When I open my PBP, everything is fine, because the stress is on the crack in the plastic I superglued. When I close it, however, the stress is on the crack in the bottom of the metal band, beneath the power port. Because I haven't put any glue there as I thought it was just a tiny insignificant crack, the whole top left corner by the screen hinge bends up because there is nothing holding it back from doing so. I am afraid that soon the whole corner will snap off! As best I can remember, the crack by the power port seemed to appear relatively soon after I got my PBP, seemingly because of stress when the power adapter was inserted. The crack in the plastic happened when I briefly handled my Pinebook Pro with one hand the other day.
RE: Pinebook Pro structural integerity failing - by TDC_PBP - 04-15-2020, 07:04 AM
  Pinebook Pro Initial Impressions kunger 443 587,551 04-16-2024, 07:29 PM
  looking to buy one pinebook pro (mainland China) duanduan 3 2,279 03-21-2024, 07:44 PM
Last Post: wangyukunshan
  Cellular module for Pinebook Pro Lotech 1 392 03-05-2024, 05:40 AM
  Screen on pinebook stays black but can ssh into machine tuxxpine 0 297 02-23-2024, 04:22 PM
Last Post: tuxxpine
  Sale my ANSI PineBook Pro cuthbertdavies 0 284 02-14-2024, 09:12 PM
Last Post: cuthbertdavies
  Compiling with -j6 on the Pinebook Pro (Overheat) KC9UDX 0 217 02-14-2024, 09:01 AM
  Pinebook Pro in EU for Sale - €90 jan_vdk 2 661 02-07-2024, 02:12 AM
Last Post: 23Ro
  Pinebook Pro for sale tomekdev 2 730 02-01-2024, 11:35 AM
Last Post: tomekdev
  Video Editing Is Possible On The PineBook Pro! ImmyChan 10 7,590 12-17-2023, 09:29 PM
Last Post: insideau786
  Brand new Pinebook Pro doesn't boot after Manjaro update johnboiles 8 2,214 12-15-2023, 02:11 PM
