PP boots into factory test even if flashed sd card is inserted
Yeah that one should work.
The basic usage is: setting the headphone killswitch in the pinephone to the UART position. connect it to your computer and open any serial terminal application (like screen /dev/ttyUSB0 115200).
If you now boot the phone you should get u-boot debug messages and it should log the error.
RE: PP boots into factory test even if flashed sd card is inserted - by MartijnBraam - 04-13-2020, 02:34 PM
  How can I get the permissions to write to the external SD card ...? Peter Gamma 10 11,264 06-16-2024, 02:36 PM
Last Post: Peter Gamma
  How to create a file on the SD card I can modify on my Ubuntu PC? Peter Gamma 0 2,233 06-16-2024, 02:33 PM
  How to write the the external SD card with Abword? Peter Gamma 0 2,665 08-27-2023, 01:10 AM
  How can I open an Abiword file from an external SD card with Abiword? Peter Gamma 5 7,115 08-25-2023, 02:05 AM
  Boots To Shell After Dead Battery (PMOS) britelite 0 2,279 02-17-2023, 02:41 PM
Last Post: britelite
  pinephone boots to green screen after running out of space costava 1 3,344 01-30-2022, 06:29 AM
Last Post: costava
  Help how to mount SD-Card chadwick 8 18,023 11-30-2021, 11:12 PM
Last Post: chadwick
  phone won't boot from emmc with sdcard inserted ssilvi 3 7,046 06-06-2021, 02:47 AM
Last Post: ssilvi
  PMOS test image: failed EG25 test broke modem fw MtnSk8 4 10,435 02-28-2021, 02:20 PM
Last Post: MtnSk8
  terminal command for sd card size pnphn 5 11,155 04-02-2020, 12:51 PM
Last Post: someGermanGuy
