Mr. Fixit Script Manual Update + MicroSD Boot help
(04-12-2020, 08:18 AM)mtlemmonrunner Wrote:
(04-12-2020, 02:57 AM)mlentink Wrote: Thank you!
First I must get the sdcard boot issue solved, and I've been googling for a couple of hours and found some pointers. I'va updated the initial mrfixit distro to the latest version, and will now try to flash a sdcard and boot from it. Keeping my fingers crossed.
If you are having boot from SD issue once Manjaro is installed to eMMc then search the Manjaro forums I think that issue is a known problem.  This brings about the question of the newer PBP coming with Manjaro do they suffer the issue too?
Hi, thanks for the heads-up. It seems I had several bad cards, so bought a few new ones and that fixed the booting problem. Though I now have Manjarro/KDE running (I'm impressed!), it runs from sd-card, not the eMMC, so I can revert back to Debian by simply removing the sd-card and rebooting.  Being a long time Ubuntu user, I'd like to try ayufan s LXDE image first before commiting to eMMC.
RE: Mr. Fixit Script Manual Update + MicroSD Boot help - by mlentink - 04-14-2020, 12:14 PM
  uboot wont boot to SD card after upgrade jbradley419 7 803 01-19-2024, 02:29 PM
  Video Flashing/adjusting on boot and reboot jbradley419 0 286 01-16-2024, 09:17 AM
Last Post: jbradley419
  Brand new Pinebook Pro doesn't boot after Manjaro update johnboiles 8 2,213 12-15-2023, 02:11 PM
  PBP won't boot after trying to reinstall Manjaro ARM soupgirl 3 686 12-13-2023, 08:17 PM
Last Post: trillobite
  Various freezes during boot & while running several Linux distros - hardware error? donuts 1 584 11-22-2023, 11:47 AM
Last Post: fxc
  Cannot boot to Kali SD card after uboot upgrade jbradley419 4 1,171 09-19-2023, 08:48 AM
Last Post: dachalife
  After update, multiple problems, pinebook pro. jd50i 1 1,044 09-16-2023, 09:41 AM
Last Post: jd50i
  Does latest Tow-Boot install/work correctly for everyone? tophneal 4 1,864 08-03-2023, 03:30 PM
  Boot into NVME drive, no wifi, sound, buttons... PaulQ 0 795 07-13-2023, 01:50 PM
Last Post: PaulQ
  New Pinebook pro won’t boot Generaltuxenburg 4 1,930 06-14-2023, 07:20 AM
