Charging via USB
(04-03-2020, 08:01 AM)GloriousCoffee Wrote: So it doesn't take Any charge at all while running if its below 2 amps?
Regarding USB C (if this is true) then the same goes for USB C?
A running PBP takes 2 amps or so from the internal battery, more if the screen is full brightness and more if you added an NVME internal drive or any external USB device.
If you connect an official barrel 3A charger to a running PBP most of its charge current actually runs the PBP with only a bit left over for the battery so the charge level indicated will be slow to change. Worst case is - even with a charger connected the battery percentage drops with use.
The charger electronics within the PBP won't draw more than 3 amps so even connecting it to a 10 amp charger it will still take a maximum of 3 amps which may or may not be enough to charge a working PBP on high screen brightness.
If you run the PBP with an external screen and you turn the PBP screen to minimum brightness then you can charge the battery better from barrel or USB-C charger.
Charging via USB - by GloriousCoffee - 04-02-2020, 09:43 AM
RE: Charging via USB - by neilman - 04-02-2020, 09:54 AM
RE: Charging via USB - by bcnaz - 04-02-2020, 08:09 PM
RE: Charging via USB - by GloriousCoffee - 04-03-2020, 08:01 AM
RE: Charging via USB - by neilman - 04-03-2020, 09:01 AM
RE: Charging via USB - by GloriousCoffee - 04-03-2020, 10:18 AM
RE: Charging via USB - by tophneal - 04-03-2020, 10:40 AM
RE: Charging via USB - by GloriousCoffee - 04-03-2020, 12:01 PM
Photo P{inebook Pro not charging Ome Ko 6 1,972 11-09-2023, 03:29 PM
Last Post: tomekdev
  Pine Book Pro Charging Problems balin 7 6,889 12-15-2022, 02:15 PM
Last Post: tomasgreenro
  Very low battery (but charging) causes boot failures Phillip Bell 7 4,509 02-22-2022, 11:20 AM
  Pinebook Pro Stopped Charging via USB-C MickTheGeek 4 4,289 08-25-2021, 02:51 PM
Last Post: MickTheGeek
  HArdware issues while charging user18130814200115 2 2,817 05-01-2021, 04:13 AM
Last Post: gabeeg
  PineBookPro does not charging floppy_rofling 0 1,641 02-03-2021, 05:29 AM
Last Post: floppy_rofling
  Screen flicker with USB-C charging bchenlee609 5 5,842 01-25-2021, 08:48 PM
Last Post: bchenlee609
  USB-C Charging on the PBP? Paulie420 33 35,732 12-12-2020, 02:20 PM
Last Post: wrzomar
  Charging via USB-C Port tyha 15 20,074 07-22-2020, 08:15 PM
Last Post: iscmob
  Battery not charging via AC Adapter laissezfarrell 1 3,122 05-30-2020, 06:05 PM
