Charging via USB
(04-02-2020, 09:43 AM)GloriousCoffee Wrote: I see it says 5V output on the adapter for PBP, am I correct to assume that I could charge it through any standard USB outlet given that I have the correct round connector to go into the PBP?
Yes, with a suitable "USB to type-H" cable you can charge PBP with any USB charger.
Only problem is if the charger can't provide over 2 amps then you might find the PBP won't charge when switched on and running.
Ok when switched off and a lower current charger will simply take a bit longer.
Charging via USB - by GloriousCoffee - 04-02-2020, 09:43 AM
RE: Charging via USB - by neilman - 04-02-2020, 09:54 AM
RE: Charging via USB - by bcnaz - 04-02-2020, 08:09 PM
RE: Charging via USB - by GloriousCoffee - 04-03-2020, 08:01 AM
RE: Charging via USB - by neilman - 04-03-2020, 09:01 AM
RE: Charging via USB - by GloriousCoffee - 04-03-2020, 10:18 AM
RE: Charging via USB - by tophneal - 04-03-2020, 10:40 AM
RE: Charging via USB - by GloriousCoffee - 04-03-2020, 12:01 PM
Photo P{inebook Pro not charging Ome Ko 6 1,998 11-09-2023, 03:29 PM
Last Post: tomekdev
  Pine Book Pro Charging Problems balin 7 6,904 12-15-2022, 02:15 PM
Last Post: tomasgreenro
  Very low battery (but charging) causes boot failures Phillip Bell 7 4,519 02-22-2022, 11:20 AM
  Pinebook Pro Stopped Charging via USB-C MickTheGeek 4 4,294 08-25-2021, 02:51 PM
Last Post: MickTheGeek
  HArdware issues while charging user18130814200115 2 2,826 05-01-2021, 04:13 AM
Last Post: gabeeg
  PineBookPro does not charging floppy_rofling 0 1,647 02-03-2021, 05:29 AM
Last Post: floppy_rofling
  Screen flicker with USB-C charging bchenlee609 5 5,862 01-25-2021, 08:48 PM
Last Post: bchenlee609
  USB-C Charging on the PBP? Paulie420 33 35,821 12-12-2020, 02:20 PM
Last Post: wrzomar
  Charging via USB-C Port tyha 15 20,093 07-22-2020, 08:15 PM
Last Post: iscmob
  Battery not charging via AC Adapter laissezfarrell 1 3,125 05-30-2020, 06:05 PM
