Audio with Debian
(03-28-2020, 12:28 PM)IoSer Wrote:
(03-28-2020, 07:42 AM)GloriousCoffee Wrote: I've set up a new Debian install with the Thompson installer and successfully got Cinnamon to run with it, but noticed that audio isn't working.
What might be missing in order to get audio to work?
The best way, I think, to resolve audio problems is:
Download
https://gitlab.manjaro.org/manjaro-arm/p...ound.state
as /etc/asound.state
use command (root mode)
alsactl -f /etc/asound.state restore
modify pulse configuration '/etc/pulse/client.conf'
change
; autospawn = yes
to
 autospawn = no
Quote:% sudo alsactl -f /etc/asound.state restore
Found hardware: "rockchip_es8316" "" "" "" ""
Hardware is initialized using a generic method
alsactl: set_control:1325: failed to obtain info for control #28 (No such file or directory)
Is it OK?
PBP ISO / Debian Bullseye (unofficial installer)
Audio with Debian - by GloriousCoffee - 03-28-2020, 07:42 AM
RE: Audio with Debian - by IoSer - 03-28-2020, 12:28 PM
RE: Audio with Debian - by wasgurd - 04-04-2020, 11:39 AM
RE: Audio with Debian - by GloriousCoffee - 03-28-2020, 01:25 PM
RE: Audio with Debian - by IoSer - 03-28-2020, 01:36 PM
RE: Audio with Debian - by Mangled - 10-15-2020, 01:22 PM
  Games compilation howto on the Pinebook-pro (Manjaro Linux and Debian native) astr0baby 201 314,511 05-12-2023, 06:09 AM
Last Post: korreckj328
  Installing Debian using files only from debian.org and encrypted root filesystem omarcomputing 0 739 10-08-2022, 11:03 AM
Last Post: omarcomputing
  Got a PBP - batch(August/September) and the audio is not good(2 big issues) crazyquark 2 1,400 10-01-2022, 10:16 AM
Last Post: crazyquark
  Use SD to install new OS over pinebook debian Rudy558 9 10,422 09-25-2022, 01:19 AM
Last Post: jackwilson
  No audio from HDMI with usb-c adapter rfm83 5 2,884 06-19-2022, 09:06 PM
Last Post: rfm83
  Main Stream Debian on Pinebook Pro ? bcnaz 4 3,496 08-22-2021, 09:11 AM
  Workaround for crackling audio when music starts/stops pato3 1 2,478 07-28-2021, 12:26 PM
Last Post: dsimic
  alsamixer and audio scale settings- how to make persistent straightwalker 0 1,439 06-04-2021, 10:57 AM
Last Post: straightwalker
  help on setting up debian (or ubuntu) on micro sd card pine76 2 8,685 09-17-2020, 05:10 PM
Last Post: bcnaz
  Suspend with NVME not working - Default Debian appdev46 5 8,481 07-14-2020, 01:53 PM
Last Post: Jeremiah Cornelius
