HDMI
#28
(04-07-2020, 02:23 PM)Arwen Wrote: @GloriousCoffee, looking at the math, if we add up your built in screen and external screen horizantal sizes, 1920 + 2560 = 4480.
I sumrise from this, that it's not possible to use a combonation of screen sizes greater than 4096 in either X or Y directions. So if your built in display is 1920 across, (which it is for our Pinebook Pros), and you want to use an external display that is 2560 across, it's not supported by the graphics in the Pinebook Pro.
Remember, the SoC is not a high end one, and neither is the built in graphics.
That said, it may be possible to treat your second monitor as a independant X-Windows display. Thus, having it's own 4096 x 4096 limit. It would not allow drag and drop between monitors. I've used such before, but not recently.
Anyone else have thoughts?
If we do "figure it out", and it is a hard limit of combined monitor sizes of 4096 x 4096, we can add that limitation to the Wiki.
I didn't even think of it as adding the two widths together, but that makes total sense now. Thank you.
By independent X-Window display, do you mean that the PBP screen would be turned off and the 21:9 monitor would act as the "main" screen instead of the PBP screen? If that is the case, I would be very interested to see if there is a solution for it.
HDMI - by GloriousCoffee - 03-17-2020, 03:22 PM
RE: HDMI - by xmixahlx - 03-17-2020, 05:38 PM
RE: HDMI - by GloriousCoffee - 03-17-2020, 06:31 PM
RE: HDMI - by xmixahlx - 03-17-2020, 08:59 PM
RE: HDMI - by vrabac - 03-18-2020, 12:51 AM
RE: HDMI - by GloriousCoffee - 03-18-2020, 05:12 AM
RE: HDMI - by Arwen - 03-19-2020, 04:50 AM
RE: HDMI - by GloriousCoffee - 03-18-2020, 08:53 AM
RE: HDMI - by vrabac - 03-18-2020, 11:13 AM
RE: HDMI - by xmixahlx - 03-18-2020, 01:16 PM
RE: HDMI - by GloriousCoffee - 03-19-2020, 08:27 AM
RE: HDMI - by GloriousCoffee - 03-30-2020, 07:21 PM
RE: HDMI - by xmixahlx - 03-30-2020, 08:19 PM
RE: HDMI - by GloriousCoffee - 03-31-2020, 06:33 AM
RE: HDMI - by GloriousCoffee - 04-03-2020, 08:39 AM
RE: HDMI - by bsammon - 04-03-2020, 08:54 PM
RE: HDMI - by GloriousCoffee - 04-04-2020, 05:50 AM
RE: HDMI - by bsammon - 04-04-2020, 12:48 PM
RE: HDMI - by GloriousCoffee - 04-04-2020, 01:05 PM
RE: HDMI - by GloriousCoffee - 04-04-2020, 04:07 PM
RE: HDMI - by Arwen - 04-05-2020, 12:05 PM
RE: HDMI - by GloriousCoffee - 04-05-2020, 10:57 PM
RE: HDMI - by Arwen - 04-06-2020, 05:39 AM
RE: HDMI - by GloriousCoffee - 04-06-2020, 09:32 AM
RE: HDMI - by LittleWalter - 04-04-2020, 06:56 PM
RE: HDMI - by Arwen - 04-07-2020, 02:23 PM
RE: HDMI - by jiyong - 04-07-2020, 02:45 PM
RE: HDMI - by GloriousCoffee - 04-08-2020, 03:42 AM
RE: HDMI - by Arwen - 04-11-2020, 02:49 PM
RE: HDMI - by GloriousCoffee - 04-13-2020, 03:54 PM
RE: HDMI - by Arwen - 04-14-2020, 08:07 AM
  Broken usb-c to hdmi with kernel 5.18+ rfm83 6 7,609 01-22-2023, 09:55 PM
Last Post: rfm83
  No audio from HDMI with usb-c adapter rfm83 5 13,789 06-19-2022, 09:06 PM
Last Post: rfm83
  USB-C Dock with HDMI no output coolmule 2 5,706 06-04-2020, 09:13 PM
Last Post: axel
  USBC -> HDMI Success! mamboman777 0 2,852 01-21-2020, 09:16 PM
Last Post: mamboman777
