Manjaro and Arch repository with privacy oriented software
#71
Yeah, signal-desktop won't work atm – the version running on the PBP runs with electron, and with most (all?) PinePhone distributions it will not run for lack of upstream electron Wayland support. Plus, it would be very slow.
I have added a (very, very, VERY!) experimental build of axolotl (https://github.com/nanu-c/axolotl) though.
There are two versions available: axolotl-electron-git, which will not work on the PinePhone (see above), but seems to work fine on the PBP – main issue currently is that I couldn't get it to use the system electron, instead it seems to download its own version. Fortunately, that one seems to work.
Then there's axolotl-ut-git, based on the Ubuntu Touch releases. This will pull in many, many dependencies… but then to (mostly) launch fine. The way it's run is somewhat ugly, but well: it's an experiment ^^
Some of those dependencies might go away soon; seems there are upstream efforts to make it possible to run without depending on UT-only features that wouldn't be used on a PinePhone anyway.
For me, though, it then seems to crash (backend only, not the GUI) once sending a message – I couldn't test any further yet, though.
To make it very clear: The axolotl builds are very, very experimental. Using it with an existing Signal account might un-register your existing account (which would mean losing existing verifications, keys, messages etc.). Things might also just not work or any other terrible thing might happen.
So only use this if you know what you are doing and/or you are willing to lose any existing Signal related data!
One last thing: messages only, voice/video calls are not yet featured by axolotl.
@pineitup : I haven't forgotten about you – I hope I'll get to work on your issues soon!
RE: Manjaro and Arch repository with privacy oriented software - by llsf - 11-21-2020, 06:47 AM
  By the way, yay arch... KC9UDX 4 677 03-30-2024, 10:27 PM
  Manjaro Sway Theme Broken Eighty8 1 260 03-08-2024, 08:41 AM
Question Manjaro with Full Disk Encryption and GRUB dumetrulo 1 1,719 02-02-2024, 02:45 AM
Last Post: frankkinney
  Manjaro network problem late 2023 acruhl 1 305 01-19-2024, 11:32 PM
  Help installing Manjaro on eMMC of Pinebook Pro pine4546464 4 2,073 12-13-2023, 07:22 PM
Last Post: trillobite
  Need Help Recovering Manjaro /boot Contents on Pinebook Pro calinb 6 2,152 12-11-2023, 03:47 AM
Last Post: calinb
  Manjaro 20.04 not loading from SD (with Manjaro on eMMC) zaius 1 386 12-07-2023, 03:11 PM
  Manjaro ARM: enabling external monitors & fixing Broadcom WiFi after updating trifleneurotic 2 859 11-14-2023, 10:57 AM
Last Post: trifleneurotic
  Manjaro [ARM Stable Update] 2021-07-23 issues Bocanila 1 1,994 08-21-2023, 09:10 PM
Last Post: vanessadonald
  [Manjaro] u-boot won't boot from eMMC with (unbootable) SD card present zackw 1 1,946 08-21-2023, 09:08 PM
