Manjaro and Arch repository with privacy oriented software
#63
(10-24-2020, 01:44 PM)llsf Wrote: Last time I checked, at least veracrypt could be built directly from the Arch upstream PKGBUILD.
=> https://forum.pine64.org/showthread.php?tid=10924
So including veracrypt as a prebuilt package in the repo shouldn't be much of an issue.
w/r to the other packages: I'll look into their feasibility and get back to you on that ^^
Protonmail bridge mention that the PKGBUILD should work on Arch and Manjaro - do you think it's something I can simply do or does it require modifications to be able to run on PBP?
I kind of need it urgently so I'm trying to see what's the best way to proceed with that...
Thanks!
RE: Manjaro and Arch repository with privacy oriented software - by pineitup - 10-25-2020, 07:15 AM
  By the way, yay arch... KC9UDX 4 679 03-30-2024, 10:27 PM
  Manjaro Sway Theme Broken Eighty8 1 262 03-08-2024, 08:41 AM
Question Manjaro with Full Disk Encryption and GRUB dumetrulo 1 1,721 02-02-2024, 02:45 AM
Last Post: frankkinney
  Manjaro network problem late 2023 acruhl 1 308 01-19-2024, 11:32 PM
  Help installing Manjaro on eMMC of Pinebook Pro pine4546464 4 2,080 12-13-2023, 07:22 PM
Last Post: trillobite
  Need Help Recovering Manjaro /boot Contents on Pinebook Pro calinb 6 2,163 12-11-2023, 03:47 AM
Last Post: calinb
  Manjaro 20.04 not loading from SD (with Manjaro on eMMC) zaius 1 388 12-07-2023, 03:11 PM
  Manjaro ARM: enabling external monitors & fixing Broadcom WiFi after updating trifleneurotic 2 860 11-14-2023, 10:57 AM
Last Post: trifleneurotic
  Manjaro [ARM Stable Update] 2021-07-23 issues Bocanila 1 1,998 08-21-2023, 09:10 PM
Last Post: vanessadonald
  [Manjaro] u-boot won't boot from eMMC with (unbootable) SD card present zackw 1 1,949 08-21-2023, 09:08 PM
