Manjaro and Arch repository with privacy oriented software
#81
(07-28-2021, 05:24 AM)llsf Wrote: Good news "annahellrothsparent": standardnotes-desktop is back in the repo again, thanks to some extra motivation from https://github.com/standardnotes/forum/issues/1241 ^^
You must remove the AT symbol from your post for it to display properly.  I expect that is being worked on, but there seems a minor bug in the forum software.
(02-18-2022, 02:53 PM)tallfrye Wrote: Just bought a pbp. Long time Arch user, not a fan of Manjaro, so looking to switch the OS. I made an SD following the instructions at https://github.com/SvenKiljan/archlinuxa...INSTALL.md
When I put the SD in my pbp and start it up, it boots into Manjaro. The SD shows up in Dolphin with BOOT_ALARM and ROOT_ALARM. I made another installation on another SD, same result.
The wrinkle I'm seeing is the file manager when I'm writing the SD card registers the card as mmcblk0 instead of sdX. I substituted the name in the instructions and followed them otherwise with apparent success. I'm using Gnome 40.4.0 on an Arch install.
Is the SD file naming scheme causing the boot loader to skip over it?
I used the images linked form this page https://wiki.pine64.org/wiki/Pinebook_Pr..._Downloads
I normally burn my SD cards using dd, but there are other tools.
Mine have all worked except one, and that was due to an SD card that did not perform to U3 (or even U1) standard.
Ancient teacher (Secondary Field Science/Math), Warrior (USARNG- RET SSG), and IT warrior (30+ years Coder, Network/Systems Administrator, general house geek).
Pinebook Pro user (Debian, Manjaro)
RE: Manjaro and Arch repository with privacy oriented software - by wpeckham - 02-19-2022, 01:07 PM
  PulseAudio dropouts after Manjaro Testing 2025.07.26 update Dendrocalamus64 2 2,299 08-08-2025, 02:39 PM
Last Post: Dendrocalamus64
  pbp with manjaro arm seems to not find any hardware[no wifi, blutooth or battery] frank_philip 4 3,668 03-15-2025, 01:47 AM
Last Post: frank_philip
  new manjaro install: wlan0 stuck in setting network address zkajdan 5 4,122 02-19-2025, 12:49 PM
Last Post: zkajdan
  By the way, yay arch... KC9UDX 4 4,341 03-30-2024, 10:27 PM
  Manjaro Sway Theme Broken Eighty8 1 2,903 03-08-2024, 08:41 AM
Question Manjaro with Full Disk Encryption and GRUB dumetrulo 1 4,575 02-02-2024, 02:45 AM
Last Post: frankkinney
  Manjaro network problem late 2023 acruhl 1 2,555 01-19-2024, 11:32 PM
  Help installing Manjaro on eMMC of Pinebook Pro pine4546464 4 7,087 12-13-2023, 07:22 PM
Last Post: trillobite
  Need Help Recovering Manjaro /boot Contents on Pinebook Pro calinb 6 8,135 12-11-2023, 03:47 AM
Last Post: calinb
  Manjaro 20.04 not loading from SD (with Manjaro on eMMC) zaius 1 2,412 12-07-2023, 03:11 PM
