Pinetime backlight current.
(03-09-2020, 10:19 AM)danielt Wrote:
(03-08-2020, 11:12 AM)TT-392 Wrote: The wiki of the pinetime mentiones the LCD driver part number, but nothing about the part number of the actual display. or backlight. It does mention the 3 backlight pins (low mid high), and according to the schematic these are just connected to a 2k2, a 100R and a 30R resistor, this suggests 3 different brightness levels, but you could get even more brightness levels if you were to combine these 3 brightness levels, but it doesn't really look like that was the intention of the original design. Now I am wondering. Can I pull all these 3 pins low without sending too much current to the backlight?
Hard to say without knowing the spec of the backlight LED!
I decided not to worry about it too much about joining them together. 2k2 is too different from the other values to make much difference to the perceived brightness and the 30R is already pretty bright. Having said that 100R|30R (a.k.a.23R) should be noticable brighter still (if it doesn't break ;-) ).
All in all if you want smoother backlight fades then experimenting with a PWM might be more profitable.
I guess I'll just stay away from turning on multiple backlight pins then and just use PWM. I don't know if any people from pine are watching this forum, but if it is indeed the case that this could damage the display, then it might be nice if that was mentioned on the forums.
Pinetime backlight current. - by TT-392 - 03-08-2020, 11:12 AM
RE: Pinetime backlight current. - by danielt - 03-09-2020, 10:19 AM
RE: Pinetime backlight current. - by TT-392 - 03-11-2020, 09:57 AM
  Develop a new firmware for PineTime belushi 2 1,362 09-25-2023, 12:32 PM
Last Post: ccchan234
  Bluetooth BLE-MIDI-controller app for PineTime / InfiniTime Luno 0 551 08-20-2023, 05:17 AM
Last Post: Luno
  Zephyr Backlight Examples for PineTime lcj 0 733 05-06-2023, 02:54 PM
Last Post: lcj
  Zephyr is ready for pinetime jandy 1 2,141 05-06-2023, 02:15 PM
Last Post: lcj
  Send a message from Android to pinetime via BLE razrosman 0 941 11-05-2022, 08:24 AM
Last Post: razrosman
  PineTime Stuck in DFU Mode Eesha Barua 1 2,093 07-25-2022, 09:17 PM
Last Post: heyhewmike
  Idle tracking with PineTime: how versatile it is? schaman 1 1,673 07-13-2022, 12:50 AM
Last Post: wibble
  PineTime implemented with partial of pebble API jandy 0 1,578 03-20-2022, 08:58 PM
Last Post: jandy
  "Pine64 USB JTAG Adapter + OpenOCD + PineTime" should it work? ITCactus 4 3,996 03-02-2022, 05:58 AM
Last Post: wibble
  Zephyr based Pinetime jandy 4 4,750 11-11-2021, 05:53 AM
Last Post: jandy
