Serial port cable
(03-10-2020, 11:56 AM)zaius Wrote: The crash during boot might be unrelated to the voltage:
"Note: It is not recommended to connect the serial adapter to pin 10 (RX) while booting, as this often causes the board to hang early in the bootloader. Disconnecting pin 10 still allows the serial console to be viewed, and it can be reconnected after the board boots, allowing interaction with the console."
https://nixos.wiki/wiki/NixOS_on_ARM/PIN...al_console
Regardless, Pine should sell a 3.3V adapter, with the correct chipset.   I have no idea why they are selling a 5V adapter when, as far as I know, none of the Pine computers use 5V UART.
I've seen this note before and I assumed that is was entirely related to the bad voltage (although that doesn't mean that I am right Wink ).
Basically a TTL serial device "parks" at logic high and will always send out 3.3v or 5v when it is not sending characters. In other words unless you are actively typing then there isn't really anything except for the voltage being applied to the RX pin that could be causing the board to hang.
It is not impossible that there are also crashes when 3.3v is applied to the RX pin but I haven't seen any reports of that on the forum (although now the PBP has become so popular I no longer have time to read all the threads). On the other hand I have seen many reports about problems with the 5v adapter.
Serial port cable - by bsammon - 03-06-2020, 04:11 PM
RE: Serial port cable - by tllim - 03-09-2020, 06:00 PM
RE: Serial port cable - by z4v4l - 03-09-2020, 07:06 PM
RE: Serial port cable - by danielt - 03-10-2020, 02:16 AM
RE: Serial port cable - by zaius - 03-10-2020, 11:56 AM
RE: Serial port cable - by danielt - 03-11-2020, 08:53 AM
RE: Serial port cable - by zaius - 03-11-2020, 01:00 PM
RE: Serial port cable - by danielt - 03-11-2020, 02:41 PM
RE: Serial port cable - by zaius - 03-13-2020, 12:37 PM
RE: Serial port cable - by danielt - 03-16-2020, 08:18 AM
RE: Serial port cable - by zaius - 03-16-2020, 12:44 PM
RE: Serial port cable - by vrabac - 03-10-2020, 12:25 AM
RE: Serial port cable - by z4v4l - 03-11-2020, 03:37 PM
RE: Serial port cable - by danielt - 03-12-2020, 04:48 AM
RE: Serial port cable - by xyzzy - 11-18-2020, 09:59 PM
RE: Serial port cable - by mattpenn - 03-03-2021, 08:32 AM
RE: Serial port cable - by tllim - 03-04-2021, 12:49 AM
RE: Serial port cable - by mattpenn - 03-04-2021, 10:00 AM
  serial cable 2023 thread bsammon 2 1,197 07-20-2023, 10:13 AM
Last Post: bsammon
  How are people finding the type-A USB 3.0 port? chris88233 1 997 10-01-2022, 01:04 AM
Last Post: LivingLinux
  Fried the charger port and USB leapylee 1 1,591 01-12-2022, 03:32 AM
Last Post: Danct12
  Pinebook Pro - Display cable broken? snokis 0 1,511 08-17-2021, 11:30 AM
Last Post: snokis
  [SOLVED] Red light flashes next to barrel-port Carl 31 42,614 01-18-2021, 09:34 AM
Last Post: dsimic
  Serial console accessible from outside as400 4 5,238 10-23-2020, 11:21 AM
Last Post: as400
  Pinebook Pro doesn't boot most of the time unless connected via USB-serial! nib0 16 13,285 09-29-2020, 10:24 PM
  Charging via USB-C Port tyha 15 20,087 07-22-2020, 08:15 PM
Last Post: iscmob
  Save your sanity: If you buy a PBP, buy a serial adapter and USB to eMMC adapter. Syonyk 11 12,948 06-30-2020, 10:28 AM
Last Post: manawyrm
Photo Looking for a PBP NVMe/SSD cable ab1jx 13 14,565 06-07-2020, 01:24 PM
Last Post: ab1jx
