Serial port cable
(03-09-2020, 06:00 PM)tllim Wrote:
(03-06-2020, 04:11 PM)bsammon Wrote: So, I've found threads on the forum that say that the serial port cable being sold by Pine64 is not fully compatible with the Pinebook Pro.
Is that still the case?
Is there somewhere I can buy a compatible serial port cable?
Or do I have to make one myself?
Should works :-)
I don't think it does.
For me the excessive voltage level on the adapter TX/PBP RX pin causes the kernel to crash during boot up. My laptop wasn't physically damaged by the over-volting from the adapter but since it doesn't work anyway I saw no reasons to take risks and stopped using it.
I now use a 3.3v TTL adapter from eBay with a hand soldered 3.5mm adapter.
Serial port cable - by bsammon - 03-06-2020, 04:11 PM
RE: Serial port cable - by tllim - 03-09-2020, 06:00 PM
RE: Serial port cable - by z4v4l - 03-09-2020, 07:06 PM
RE: Serial port cable - by danielt - 03-10-2020, 02:16 AM
RE: Serial port cable - by zaius - 03-10-2020, 11:56 AM
RE: Serial port cable - by danielt - 03-11-2020, 08:53 AM
RE: Serial port cable - by zaius - 03-11-2020, 01:00 PM
RE: Serial port cable - by danielt - 03-11-2020, 02:41 PM
RE: Serial port cable - by zaius - 03-13-2020, 12:37 PM
RE: Serial port cable - by danielt - 03-16-2020, 08:18 AM
RE: Serial port cable - by zaius - 03-16-2020, 12:44 PM
RE: Serial port cable - by vrabac - 03-10-2020, 12:25 AM
RE: Serial port cable - by z4v4l - 03-11-2020, 03:37 PM
RE: Serial port cable - by danielt - 03-12-2020, 04:48 AM
RE: Serial port cable - by xyzzy - 11-18-2020, 09:59 PM
RE: Serial port cable - by mattpenn - 03-03-2021, 08:32 AM
RE: Serial port cable - by tllim - 03-04-2021, 12:49 AM
RE: Serial port cable - by mattpenn - 03-04-2021, 10:00 AM
  serial cable 2023 thread bsammon 2 1,202 07-20-2023, 10:13 AM
Last Post: bsammon
  How are people finding the type-A USB 3.0 port? chris88233 1 1,000 10-01-2022, 01:04 AM
Last Post: LivingLinux
  Fried the charger port and USB leapylee 1 1,599 01-12-2022, 03:32 AM
Last Post: Danct12
  Pinebook Pro - Display cable broken? snokis 0 1,516 08-17-2021, 11:30 AM
Last Post: snokis
  [SOLVED] Red light flashes next to barrel-port Carl 31 42,646 01-18-2021, 09:34 AM
Last Post: dsimic
  Serial console accessible from outside as400 4 5,247 10-23-2020, 11:21 AM
Last Post: as400
  Pinebook Pro doesn't boot most of the time unless connected via USB-serial! nib0 16 13,294 09-29-2020, 10:24 PM
  Charging via USB-C Port tyha 15 20,101 07-22-2020, 08:15 PM
Last Post: iscmob
  Save your sanity: If you buy a PBP, buy a serial adapter and USB to eMMC adapter. Syonyk 11 12,953 06-30-2020, 10:28 AM
Last Post: manawyrm
Photo Looking for a PBP NVMe/SSD cable ab1jx 13 14,573 06-07-2020, 01:24 PM
Last Post: ab1jx
