Serial port cable
(03-09-2020, 06:00 PM)tllim Wrote:
(03-06-2020, 04:11 PM)bsammon Wrote: So, I've found threads on the forum that say that the serial port cable being sold by Pine64 is not fully compatible with the Pinebook Pro.
Is that still the case?
Is there somewhere I can buy a compatible serial port cable?
Or do I have to make one myself?
Should works :-)
it has 5V on IO lines! whereas it's supposed to be 3.3V, farthermore, rk3399 uarts want 3.0V (max 3.15)! so it's a two fold problem and indefinitely overlooked. the adapter doesn't work properly and causes instabilities, which is no wonder, given such a voltage mismatch.
ANT - my hobby OS for x86 and ARM.
Serial port cable - by bsammon - 03-06-2020, 04:11 PM
RE: Serial port cable - by tllim - 03-09-2020, 06:00 PM
RE: Serial port cable - by z4v4l - 03-09-2020, 07:06 PM
RE: Serial port cable - by danielt - 03-10-2020, 02:16 AM
RE: Serial port cable - by zaius - 03-10-2020, 11:56 AM
RE: Serial port cable - by danielt - 03-11-2020, 08:53 AM
RE: Serial port cable - by zaius - 03-11-2020, 01:00 PM
RE: Serial port cable - by danielt - 03-11-2020, 02:41 PM
RE: Serial port cable - by zaius - 03-13-2020, 12:37 PM
RE: Serial port cable - by danielt - 03-16-2020, 08:18 AM
RE: Serial port cable - by zaius - 03-16-2020, 12:44 PM
RE: Serial port cable - by vrabac - 03-10-2020, 12:25 AM
RE: Serial port cable - by z4v4l - 03-11-2020, 03:37 PM
RE: Serial port cable - by danielt - 03-12-2020, 04:48 AM
RE: Serial port cable - by xyzzy - 11-18-2020, 09:59 PM
RE: Serial port cable - by mattpenn - 03-03-2021, 08:32 AM
RE: Serial port cable - by tllim - 03-04-2021, 12:49 AM
RE: Serial port cable - by mattpenn - 03-04-2021, 10:00 AM
  serial cable 2023 thread bsammon 2 1,209 07-20-2023, 10:13 AM
Last Post: bsammon
  How are people finding the type-A USB 3.0 port? chris88233 1 1,004 10-01-2022, 01:04 AM
Last Post: LivingLinux
  Fried the charger port and USB leapylee 1 1,605 01-12-2022, 03:32 AM
Last Post: Danct12
  Pinebook Pro - Display cable broken? snokis 0 1,517 08-17-2021, 11:30 AM
Last Post: snokis
  [SOLVED] Red light flashes next to barrel-port Carl 31 42,704 01-18-2021, 09:34 AM
Last Post: dsimic
  Serial console accessible from outside as400 4 5,259 10-23-2020, 11:21 AM
Last Post: as400
  Pinebook Pro doesn't boot most of the time unless connected via USB-serial! nib0 16 13,332 09-29-2020, 10:24 PM
  Charging via USB-C Port tyha 15 20,125 07-22-2020, 08:15 PM
Last Post: iscmob
  Save your sanity: If you buy a PBP, buy a serial adapter and USB to eMMC adapter. Syonyk 11 12,981 06-30-2020, 10:28 AM
Last Post: manawyrm
Photo Looking for a PBP NVMe/SSD cable ab1jx 13 14,591 06-07-2020, 01:24 PM
Last Post: ab1jx
