Help! Rock64 won't boot anything!
(03-06-2020, 04:24 PM)trohn_javolta Wrote:
(03-06-2020, 12:15 PM)z4v4l Wrote: I think your board is not broken. UART output you get, most probably is a result of baud rate mismatch, rockchip socs use this crazy 1500000 baud/s rate, i never managed to really use it with any system connected as a terminal. that is, the board prints info into it, but it does that with that uncommon speed, whereas your receiving port handling software thinks it's normal 115200. may be that. so, first what you need is to establish serial output. you need to ensure your adapter (and its driver) does support 1.5Mbaud/s rate. the problem with the board itself may be in that, there is something in SPI flash, and that something pooped its pants, stuck and preventing you from successful boot out of  sd card. unfortunately, I don't remember how, but you could try to disable SPI, by shorting some pins on the header during boot, search for it here, in the appropriate forum, try it with a guaranteed properly prepared sd card (with uboot etc) inserted, of course. if that boot is successful, you can properly and certainly erase SPI flash from that linux session and have troublefree boots next times.
:O omg, thank you so much! There's light on the ethernet port. Yesss!!! It's pin 21 that needs to be connected with gnd (for example pin 20)
Now I'll erase and rewrite spi Smile
..It's a bit embarassing that "some random person" on this forum just solves this with a quick post (really no offense Big Grin) and Pine64 support cannot do so after a 3 day long lasting ticket troubleshoot Big Grin
Thx again!
Sometimes, forum and IRC are more effective than support ticket. More brains here, less brains there.
RE: Help! Rock64 won't boot anything! - by z4v4l - 03-06-2020, 12:15 PM
RE: Help! Rock64 won't boot anything! - by tllim - 03-09-2020, 06:03 PM
  DeskPi case alternative for ROCK64 v1k699 2 11,050 05-29-2025, 06:57 PM
Last Post: ameridroid
  Case for the rock64 that supports the POE hat. o1CRiMSON1o 2 2,713 05-13-2025, 07:32 AM
  Rock64 is unreliable after 3 years of service - power problem? ReleaseTheGeese 1 2,357 03-24-2025, 06:41 PM
Last Post: arunkhan
Information How to Setup Serial Console Cable Over the Rock64 SBC MarkHaysHarris777 10 42,144 03-24-2025, 06:35 PM
Last Post: arunkhan
  Are HW design files available for ROCK64? irenek 3 9,114 12-11-2023, 09:31 PM
  Rock64 PoE compatbility with Pi4 Hatt recent Single Board Computer offering from PINE kharak 1 3,371 04-26-2023, 11:38 PM
Brick Rock64 usb2.0 Power Control Floating GPIO Tutorial Files & Notes MarkHaysHarris777 6 18,321 01-15-2023, 10:36 AM
Last Post: ds00
  rock64 totally brick dakobg 2 4,447 11-07-2022, 05:45 PM
Last Post: olivercfc
  3D-Printable Button Pegs for the ROCK64 Aluminium Case CounterPillow 2 6,267 08-04-2022, 01:31 AM
Last Post: Vicky Weimann PhD
  Where can I find the ROCK64 POE HAT Zoz 2 5,579 06-08-2022, 12:44 AM
Last Post: Zoz
