Manjaro Arm users - What does your trackpad/keyboard conf file look like?
(02-27-2020, 04:18 PM)Eggmonkey Wrote: Bump - no on else experiencing this or tried to tweak this file to improve the trackpad?
Obviously I realise there are limitations with the hardware, but still doesn't stop me trying to make it better.
Hi.
I am using the Synaptics touchpad driver as well, and I have to say it works quite good now.
I have used it with Manjaro, openSuse and Ubuntu and they all behave pretty much the same, so I assume that the result works for all.
It is easy enough to set up, download the Xorg Synaptics driver, copy the .config file from /usr/share/X11/xorg.conf.d/70-synaptics.conf to /etc/X11/xorg.conf.d/70-synaptics.conf and modify it as you need.
Here are the synaptics parameter I have as an output from synclient:
  LeftEdge                = 56
   RightEdge               = 1344
   TopEdge                 = 49
   BottomEdge              = 865
   FingerLow               = 25
   FingerHigh              = 30
   MaxTapTime              = 250
   MaxTapMove              = 73
   MaxDoubleTapTime        = 180
   SingleTapTimeout        = 180
   ClickTime               = 100
   EmulateMidButtonTime    = 0
   EmulateTwoFingerMinZ    = 50
   EmulateTwoFingerMinW    = 5
   VertScrollDelta         = -33
   HorizScrollDelta        = -33
   VertEdgeScroll          = 0
   HorizEdgeScroll         = 0
   CornerCoasting          = 0
   VertTwoFingerScroll     = 1
   HorizTwoFingerScroll    = 0
   MinSpeed                = 1
   MaxSpeed                = 2.8
   AccelFactor             = 0.5
   TouchpadOff             = 2
   LockedDrags             = 0
   LockedDragTimeout       = 5000
   RTCornerButton          = 0
   RBCornerButton          = 0
   LTCornerButton          = 0
   LBCornerButton          = 0
   TapButton1              = 1
   TapButton2              = 3
   TapButton3              = 0
   ClickFinger1            = 1
   ClickFinger2            = 3
   ClickFinger3            = 2
   CircularScrolling       = 0
   CircScrollDelta         = 0.1
   CircScrollTrigger       = 0
   CircularPad             = 0
   PalmDetect              = 0
   PalmMinWidth            = 10
   PalmMinZ                = 200
   CoastingSpeed           = 20
   CoastingFriction        = 50
   PressureMotionMinZ      = 30
   PressureMotionMaxZ      = 160
   PressureMotionMinFactor = 1
   PressureMotionMaxFactor = 1
   GrabEventDevice         = 0
   TapAndDragGesture       = 1
   AreaLeftEdge            = 0
   AreaRightEdge           = 0
   AreaTopEdge             = 0
   AreaBottomEdge          = 0
   HorizHysteresis         = 8
   VertHysteresis          = 8
   ClickPad                = 1
   RightButtonAreaLeft     = 700
   RightButtonAreaRight    = 0
   RightButtonAreaTop      = 749
   RightButtonAreaBottom   = 0
   MiddleButtonAreaLeft    = 0
   MiddleButtonAreaRight   = 0
   MiddleButtonAreaTop     = 0
   MiddleButtonAreaBottom  = 0
And here is my /etc/X11/xorg.conf.d/70-synaptics.conf file:
Section "InputClass"
       Driver "synaptics"
       MatchIsTouchpad "on"
# This option is recommend on all Linux systems using evdev, but cannot be
# enabled by default. See the following link for details:
# http://who-t.blogspot.com/2010/11/how-to-ignore-configuration-errors.html
      Option "VertScrollDelta" "-33"
      Option "HorizScrollDelta" "-33"
      Option "TapButton1" "1"
      Option "TapButton2" "3"
      Option "TapButton3" "0"
      Option "MinSpeed" "0.25"
      Option "AccelFactor" "0.5"
      Option "EmulateTwoFingerMinZ" "50"
      Option "EmulateTwoFingerMinW" "5"
      Option "MaxTapTime" "250"
This could  be tweaked further, but all in all I am quite happy with it. I have the suspicion that some parameter are set outside of the .conf file, maybe from the KDE touchpad settings, so dependent of the distro you use you might want to copy more parameter from the full list to your .conf file.
(Small side note, it would probably be better if the title of this thread would reference touchpad, rather than keyboard)
RE: Manjaro Arm users - What does your keyboard conf file look like? - by Surehand53 - 04-17-2020, 10:58 AM
  PulseAudio dropouts after Manjaro Testing 2025.07.26 update Dendrocalamus64 2 2,797 08-08-2025, 02:39 PM
Last Post: Dendrocalamus64
  PinePhone keyboard not registering input properly Feemphynead 0 1,899 04-25-2025, 03:37 AM
Last Post: Feemphynead
  pbp with manjaro arm seems to not find any hardware[no wifi, blutooth or battery] frank_philip 4 4,242 03-15-2025, 01:47 AM
Last Post: frank_philip
  new manjaro install: wlan0 stuck in setting network address zkajdan 5 4,748 02-19-2025, 12:49 PM
Last Post: zkajdan
  Manjaro Sway Theme Broken Eighty8 1 3,226 03-08-2024, 08:41 AM
Question Manjaro with Full Disk Encryption and GRUB dumetrulo 1 5,573 02-02-2024, 02:45 AM
Last Post: frankkinney
  Manjaro network problem late 2023 acruhl 1 2,888 01-19-2024, 11:32 PM
  Help installing Manjaro on eMMC of Pinebook Pro pine4546464 4 8,105 12-13-2023, 07:22 PM
Last Post: trillobite
  Need Help Recovering Manjaro /boot Contents on Pinebook Pro calinb 6 9,206 12-11-2023, 03:47 AM
Last Post: calinb
  Manjaro 20.04 not loading from SD (with Manjaro on eMMC) zaius 1 2,679 12-07-2023, 03:11 PM
