Manjaro Arm users - What does your trackpad/keyboard conf file look like?
So I'm using Manjaro for ARM with KDE and it is in general fantastic, so thank you very much to the team behind it.
I have one major issue - whatever I do my trackpad still isn't accurate.
I have run the firmware update described on the Manjaro forum - it helped a bit but I still find that the pointer keeps moving after I drag it across the screen.
I have experimented with the config file, any feedback is welcome:
[ivan@ivan ~]$  cat /etc/X11/xorg.conf.d/00-keyboard.conf
# Written by systemd-localed(8), read by systemd-localed and Xorg. It's
# probably wise not to edit this file manually. Use localectl(1) to
# instruct systemd-localed to update it.
Section "InputClass"
       Identifier "system-keyboard"
       MatchIsKeyboard "on"
       Option "XkbLayout" "gb"
       Option "XkbModel" "pc105"
       Option "XkbOptions" "terminate:ctrl_alt_bksp"
EndSection
       Driver "synaptics"
       MatchIsTouchpad "on"
       Option "MinSpeed" "0.25"
       Option "FingerLow" "0.25"
       Option "PalmDetect" "1"
       Option "VertScrollDelta" "64"
       Option "HorizScrollDelta" "64"
       Option "ConstantDeceleration" "1"
       Option "CoastingFriction" "0"
       Option "HorizHysteresis" "0"
       Option "VertHysteresis" "0"
       Option "PressureMotionMinZ" "60"
       Option "PressureMotionMaxZ" "160"
EndSection
Would others mind catting the contents of their file?
And are you all using synaptics or just libinput?
Cheers.
Manjaro Arm users - What does your trackpad/keyboard conf file look like? - by Eggmonkey - 02-17-2020, 04:00 PM
  PulseAudio dropouts after Manjaro Testing 2025.07.26 update Dendrocalamus64 2 2,809 08-08-2025, 02:39 PM
Last Post: Dendrocalamus64
  PinePhone keyboard not registering input properly Feemphynead 0 1,904 04-25-2025, 03:37 AM
Last Post: Feemphynead
  pbp with manjaro arm seems to not find any hardware[no wifi, blutooth or battery] frank_philip 4 4,258 03-15-2025, 01:47 AM
Last Post: frank_philip
  new manjaro install: wlan0 stuck in setting network address zkajdan 5 4,771 02-19-2025, 12:49 PM
Last Post: zkajdan
  Manjaro Sway Theme Broken Eighty8 1 3,239 03-08-2024, 08:41 AM
Question Manjaro with Full Disk Encryption and GRUB dumetrulo 1 5,589 02-02-2024, 02:45 AM
Last Post: frankkinney
  Manjaro network problem late 2023 acruhl 1 2,897 01-19-2024, 11:32 PM
  Help installing Manjaro on eMMC of Pinebook Pro pine4546464 4 8,123 12-13-2023, 07:22 PM
Last Post: trillobite
  Need Help Recovering Manjaro /boot Contents on Pinebook Pro calinb 6 9,312 12-11-2023, 03:47 AM
Last Post: calinb
  Manjaro 20.04 not loading from SD (with Manjaro on eMMC) zaius 1 2,691 12-07-2023, 03:11 PM
