Any one running any SDR solutions
RTL-SDR is very reliable, it's been around a long time, works well enough with a cheap standard RTL2832 dongle (under $10). BUT, if you step up to the fancier version with TCXO you don't have to enter a PPM correction for the cheap crystal. You'll probably get direct tuning (tries to tune some HF under 27 MHz), and bias tee support (can power a preamp or upconverter). I've got a couple I got for about $18 on Aliexpress. If you want to listen to SSB the cheaper dongles have enough drift to be a nuisance.
CubicSDR is probably the best software I've found. It's in the debs for Buster and up. I'd rather avoid Gnuradio, it's mostly bloatware. If you want to experiment with different modulation methods maybe but for everyday use it's just too complicated and big. GQRX uses Gnuradio, it's just an app under it. HackRF I think is used by CubicSDR, several things are, so you can try it by itself.
Any one running any SDR solutions - by oxoocoffee - 02-15-2020, 09:10 AM
RE: Any one running any SDR solutions - by ab1jx - 02-16-2020, 09:30 AM
RE: Any one running any SDR solutions - by ab1jx - 02-26-2020, 06:07 PM
RE: Any one running any SDR solutions - by ab1jx - 03-04-2020, 12:01 PM
  Various freezes during boot & while running several Linux distros - hardware error? donuts 1 584 11-22-2023, 11:47 AM
Last Post: fxc
  Pro Bricked! Solutions? mspohr 4 1,758 12-08-2022, 03:08 PM
  Pinebook Pro freezes when running on battery petaramesh 5 2,563 09-22-2022, 12:43 AM
Last Post: petaramesh
  Linus Torvalds using M2 Macbook Air running Linux orbital 17 7,836 09-09-2022, 03:57 PM
Last Post: orbital
  Running Libgdx sdk on pinebookpro Nick_dnepr 2 3,226 10-02-2020, 07:56 AM
Last Post: Nick_dnepr
  PBP running shipping Manjaro won't wake from suspend fornio 2 4,465 07-21-2020, 07:04 AM
Last Post: vancheese
  Pinebook Pro seems to "seize up" after running any OS... User 6582 5 7,054 06-14-2020, 07:33 PM
Last Post: User 6582
  Screen burn in after running for a few min Flapjack 2 4,334 06-13-2020, 06:39 AM
Last Post: matosys
  PBR running hot brzegorz 10 11,348 01-22-2020, 02:55 PM
Last Post: wrzomar
