Multi Display on Manjaro KDE
(02-14-2020, 05:48 PM)PakoSt Wrote: Multi-screen setup should work as usual (or as usual as it can with some resolution weirdness) if go the Panfrost route.
For multi-screen setup, I moved from xfce fbturbo to xfce panfrost. Now, I have working multi-screen, but my kernel does not seem to like it too much. It constantly logs:
Feb 18 09:44:24 manjaro kernel: Purging 622592 bytes
Feb 18 09:44:24 manjaro kernel: Purging 544768 bytes
Feb 18 09:44:24 manjaro kernel: Purging 524288 bytes
Feb 18 09:44:24 manjaro kernel: Purging 528384 bytes
Feb 18 09:44:24 manjaro kernel: Purging 593920 bytes
Feb 18 09:44:24 manjaro kernel: Purging 651264 bytes
Feb 18 09:44:25 manjaro kernel: Purging 2170880 bytes
Feb 18 09:44:29 manjaro kernel: panfrost_gem_shrinker_scan: 13 callbacks suppressed
Feb 18 09:44:29 manjaro kernel: Purging 6434816 bytes
Feb 18 09:44:29 manjaro kernel: Purging 983040 bytes
Feb 18 09:44:29 manjaro kernel: Purging 3190784 bytes
Feb 18 09:44:29 manjaro kernel: Purging 688128 bytes
Feb 18 09:44:29 manjaro kernel: Purging 2150400 bytes
Feb 18 09:44:30 manjaro kernel: Purging 2097152 bytes
Feb 18 09:44:30 manjaro kernel: Purging 2752512 bytes
Feb 18 09:44:30 manjaro kernel: Purging 561152 bytes
Feb 18 09:44:30 manjaro kernel: Purging 2396160 bytes
Feb 18 09:44:30 manjaro kernel: Purging 610304 bytes
Feb 18 09:46:57 manjaro kernel: panfrost_gem_shrinker_scan: 13 callbacks suppressed
Feb 18 09:46:57 manjaro kernel: Purging 524288 bytes
Feb 18 09:46:57 manjaro kernel: Purging 536576 bytes
Multi Display on Manjaro KDE - by binholz - 02-14-2020, 11:12 AM
RE: Multi Display on Manjaro KDE - by PakoSt - 02-14-2020, 05:48 PM
RE: Multi Display on Manjaro KDE - by Der Geist der Maschine - 02-18-2020, 11:52 AM
RE: Multi Display on Manjaro KDE - by binholz - 02-18-2020, 02:51 PM
RE: Multi Display on Manjaro KDE - by binholz - 02-25-2020, 07:57 AM
RE: Multi Display on Manjaro KDE - by tllim - 03-01-2020, 04:08 PM
RE: Multi Display on Manjaro KDE - by xmixahlx - 03-01-2020, 08:34 PM
  Manjaro Sway Theme Broken Eighty8 1 272 03-08-2024, 08:41 AM
Question Manjaro with Full Disk Encryption and GRUB dumetrulo 1 1,745 02-02-2024, 02:45 AM
Last Post: frankkinney
  Manjaro network problem late 2023 acruhl 1 320 01-19-2024, 11:32 PM
  Help installing Manjaro on eMMC of Pinebook Pro pine4546464 4 2,120 12-13-2023, 07:22 PM
Last Post: trillobite
  Need Help Recovering Manjaro /boot Contents on Pinebook Pro calinb 6 2,186 12-11-2023, 03:47 AM
Last Post: calinb
  Manjaro 20.04 not loading from SD (with Manjaro on eMMC) zaius 1 400 12-07-2023, 03:11 PM
  Manjaro ARM: enabling external monitors & fixing Broadcom WiFi after updating trifleneurotic 2 872 11-14-2023, 10:57 AM
Last Post: trifleneurotic
  Sleep and external display - Are there any options? chris88233 7 1,703 09-04-2023, 09:03 PM
  Manjaro [ARM Stable Update] 2021-07-23 issues Bocanila 1 2,016 08-21-2023, 09:10 PM
Last Post: vanessadonald
  [Manjaro] u-boot won't boot from eMMC with (unbootable) SD card present zackw 1 1,963 08-21-2023, 09:08 PM
