Multi Display on Manjaro KDE
I guess it's safe to say that you are using XFCE spin with fbturbo? (fbturbo for this effect / xfce because it's more prominent to keep fbturbo on it compared to KDE spin).
For whatever reason, when using fbturbo the external display setup should prepared in `xorg.conf` . I've managed to find only scant and half-working solutions from Raspberry Pi threads which use fbturbo to little success.
Multi-screen setup should work as usual (or as usual as it can with some resolution weirdness) if go the Panfrost route.
Device: Pinebook Pro 128GB No:246 / MainOS: Manjaro ARM
Godot and Flutter - creating something can be fun with the right tools!
Multi Display on Manjaro KDE - by binholz - 02-14-2020, 11:12 AM
RE: Multi Display on Manjaro KDE - by PakoSt - 02-14-2020, 05:48 PM
RE: Multi Display on Manjaro KDE - by binholz - 02-18-2020, 02:51 PM
RE: Multi Display on Manjaro KDE - by binholz - 02-25-2020, 07:57 AM
RE: Multi Display on Manjaro KDE - by tllim - 03-01-2020, 04:08 PM
RE: Multi Display on Manjaro KDE - by xmixahlx - 03-01-2020, 08:34 PM
  Manjaro Sway Theme Broken Eighty8 1 276 03-08-2024, 08:41 AM
Question Manjaro with Full Disk Encryption and GRUB dumetrulo 1 1,746 02-02-2024, 02:45 AM
Last Post: frankkinney
  Manjaro network problem late 2023 acruhl 1 324 01-19-2024, 11:32 PM
  Help installing Manjaro on eMMC of Pinebook Pro pine4546464 4 2,128 12-13-2023, 07:22 PM
Last Post: trillobite
  Need Help Recovering Manjaro /boot Contents on Pinebook Pro calinb 6 2,194 12-11-2023, 03:47 AM
Last Post: calinb
  Manjaro 20.04 not loading from SD (with Manjaro on eMMC) zaius 1 402 12-07-2023, 03:11 PM
  Manjaro ARM: enabling external monitors & fixing Broadcom WiFi after updating trifleneurotic 2 880 11-14-2023, 10:57 AM
Last Post: trifleneurotic
  Sleep and external display - Are there any options? chris88233 7 1,713 09-04-2023, 09:03 PM
  Manjaro [ARM Stable Update] 2021-07-23 issues Bocanila 1 2,016 08-21-2023, 09:10 PM
Last Post: vanessadonald
  [Manjaro] u-boot won't boot from eMMC with (unbootable) SD card present zackw 1 1,963 08-21-2023, 09:08 PM
