Does pmbootstrap install the latest image?
(02-15-2020, 10:51 PM)mypine Wrote: Answering my own question - pmbootstrap does not load the latest version. I downloaded the latest and flashed it via dd (instructions for using dd are below) and it's obvious that the version that pmbootstrap uses is very old because many many things just don't work. However with the latest version, it is much more usable.
To flash the latest version with dd, it seems to be necessary to set blocksize to 1024 bytes. Also, you have to expand the root partition because it only allocates a gb or so. I used gparted to expand the root partition successfully. The dd command is below.
(dd bs=1024 if=imagefile of=/dev/mmbclk0 in my case)
Here is a more complete answer,
but basically yes, it's the latest version. The images are often here to test stuff that's sometimes hard to put together, or sometimes to make distribution easier in some cases. They are not the "latest" version, and I don't think you can actually rely on them getting published regularly, at this point.
Grab one if you really don't want to use pmbootstrap (though you should try to use it if you want to play with different experimental packages), and update it:
apk update && apk upgrade -a
RE: Does pmbootstrap install the latest image? - by M@yeulC - 02-20-2020, 08:54 AM
  Firefox Crashes on Start-up (latest installer) & How do I change Default Browser? aLoop100o 1 3,626 11-22-2023, 10:16 AM
Last Post: zetabeta
  Fresh install pmos+phosh does not boot user641 1 3,380 10-08-2023, 04:04 AM
Last Post: user641
  Plasma mobile latest stable @pp1.2b voice calling audio issue n05ph3r42 3 5,257 10-03-2023, 06:32 PM
  Issues after installing latest PostMarket OS with POSH xen314 4 7,222 08-20-2023, 11:18 PM
Last Post: xen314
  Install 9999 packages AndyM 0 3,110 07-24-2023, 01:07 AM
Last Post: AndyM
  Can't install powersupply user641 0 2,589 07-18-2023, 08:09 AM
Last Post: user641
  Trying to install Mousai AndyM 0 2,881 06-10-2023, 08:25 AM
Last Post: AndyM
  how to install updates? someGermanGuy 2 4,732 04-26-2022, 12:48 PM
Last Post: someGermanGuy
  Latest suggestion to fix modem instability? feklee 10 17,191 01-31-2022, 01:16 PM
Last Post: feklee
  How to install software AndyM 8 14,456 11-14-2021, 01:08 AM
Last Post: AndyM
