Mobile Carriers in the United States
(02-28-2020, 12:57 PM)soyrunner Wrote:
(02-28-2020, 03:30 AM)rocket2nfinity Wrote: Verizon does support VoLTE but even though  they are shutting down their 2G network right now, they are still requiring  certification of the device. So you are unlkily to be able to make calls now or in the near future with them or their MVNOs. Their MVNOs should allow data access - PagePlus etc. But someone else will have to confirm this.
AT&T last month said they are opening any phone with functional VoLTE on their network in preparation  of shutting their 2G network in 2022. It may or may not have been done yet in your area, nor do I know what steps, updates the pinephone community will need to do to make that happen. But you should at least get data.
T-mobile and their MVNOs should work for now. I think they are your best bet. But activate the SIM in another phone first. Metro by Tmobile by the way will require you to call them or go into their store to activate the device on their network. They still lock Sims to the IMEI, so you wont be able to transfer it without calling customer service.
You might be having an APN issue. I got denied at first because Ubuntu Touch didn't update my APN settings
Verizon via PPC is probably similar in locking the sim to the IMEI unless it's just poor reception.  I bought an inexpensive phone to swap SIM to the pinephone.  SIM has been okay, a single bar and working on the inexpensive phone.  I swapped the SIM to the pinephone with ubuntu touch.  No SIM detected.  Shut it down and pulled the sdcard and booted to the test screen,  Automatic tests failed the modem.  Went to the modem and it slowly populated, then a minute later it identified the card and showed VoLTE and incoming but -86dbm.  Went back to automatic tests and modem passed.  I shut it down again and readded the sdcard with ubuntu.  Rebooted and still No SIM detected.  Went outside looking for a signal but no joy.
soyrunner
That is a very weak signal. But it sounds like your modem is not on when in Ubuntu Touch. Did you try inputting this in terminal in Ubuntu Touch?
sudo /usr/share/ofono/scripts/enable-modem
sudo /usr/share/ofono/scripts/online-modem
Mobile Carriers in the United States - by aren - 02-13-2020, 04:11 PM
RE: Mobile Carriers in the United States - by rocket2nfinity - 02-28-2020, 06:20 PM
RE: Mobile Carriers in the United States - by RTP - 07-28-2020, 07:54 PM
  can I retrieve accidentally deleted voice mail with T mobile ? HLing 4 797 12-13-2023, 01:24 AM
Last Post: oldschool
  New Zealand network providers mobile data Linux2thabone 3 3,259 08-05-2023, 06:17 AM
Last Post: SchizoPinePhone225
  US Mobile, via T-Mobile, won't support Pinephone Pro - SOLVED, SIMPLY jovval 10 3,205 07-07-2023, 12:06 PM
Last Post: jovval
  Problems updating KDE Plasma Mobile OS IMSAI8080 6 3,305 06-30-2023, 11:39 PM
Last Post: ionmich
  Current Situation With Setup and Carrier Activation With Tracfone Verizon T-Mobile pinephoneuser22 0 690 05-26-2023, 08:40 PM
Last Post: pinephoneuser22
  Cannot call at several mobile phones Gon 3 1,305 05-04-2023, 05:18 AM
Last Post: Gon
  MMS-Monitor: Help for carriers with dual APNs? treebeard 2 1,323 02-10-2023, 02:45 PM
Last Post: treebeard
  Phone carriers and the Speakout carrier bedtime 3 2,053 08-16-2022, 11:11 PM
Last Post: Oblivion2528
  compatible carriers the7thpoint 2 1,699 06-17-2022, 08:24 AM
Last Post: mikehenson
Lightbulb pinephone mobile dock jasmin763 2 1,688 06-06-2022, 09:06 AM
Last Post: 98cwitr
