Battery / power question
The Pinebook Pro will turn off forcefully (unsafe shutdown).
There is a special jumper wire inside the Pinebook Pro which allows for operation on mains power only.
Important! Do not plug the jumper cable in without unplugging the battery. This would destroy your mainboard.
It can also only be powered from the 5V DC jack, not via USB-C.
You also shouldn't open the Pinebook Pro while the backcover is off, it's a structural part of the device and will cause plastic parts to break.
Battery / power question - by GloriousCoffee - 02-13-2020, 04:32 AM
RE: Battery / power question - by manawyrm - 02-13-2020, 07:41 AM
RE: Battery / power question - by GloriousCoffee - 02-13-2020, 08:38 AM
RE: Battery / power question - by rleasle - 02-13-2020, 10:02 AM
  Newbie Question!! oniichann 3 308 10-26-2023, 07:09 AM
  Lockable-until-power-cycle persistent storage Melab 0 317 09-17-2023, 08:51 PM
Last Post: Melab
  power on Pinebook Pro mainboard without keyboard? papable 0 561 07-20-2023, 11:06 PM
Last Post: papable
  When does Pinebook Pro power LED go on? Bram 0 495 03-14-2023, 09:53 AM
Last Post: Bram
  Doesn’t power on after flashing emmc badguru 3 891 02-25-2023, 09:00 PM
Last Post: badguru
  GPIO breakout question pinus_pinea 0 519 01-17-2023, 06:13 AM
Last Post: pinus_pinea
  Pinebook Pro drains ny battery after shutting it off Tongman 4 1,722 12-01-2022, 02:50 AM
  Battery Frost1776 1 867 10-07-2022, 04:17 PM
Last Post: LivingLinux
  Pinebook Pro freezes when running on battery petaramesh 5 2,049 09-22-2022, 12:43 AM
Last Post: petaramesh
Heart Now better battery life or power management? KC9UDX 5 1,889 09-09-2022, 08:13 PM
