Heat sink required for Pine64?
(05-03-2016, 07:54 PM)Beryllium Wrote: Thanks, you can buy them on ebay, amazon... for few bucks, but you can also find them in junk electronics, old motherboards, graphic cards, dvrs, etc...
I got my fan from some DVR I found. But I think heat sink is doing most of the work.
Just keep in mind lots of the cheap heatinks you have on ebay have crap adhesive. I bought some for my Pi, within 3 months the adhesive had let all the heatsinks drift more than 3-6 mm across the surface of the chips they were on. Since heatsinks are metal, falling off the chip onto the pcb while running would likely suck.
So get good stuff, use permanent thermal epoxy or keep the board horizontal at the very least.
RE: Heat sink required for Pine64? - by Beryllium - 05-03-2016, 05:13 PM
RE: Heat sink required for Pine64? - by g_t_j - 05-03-2016, 06:00 PM
RE: Heat sink required for Pine64? - by Beryllium - 05-03-2016, 06:31 PM
RE: Heat sink required for Pine64? - by g_t_j - 05-28-2016, 05:00 AM
RE: Heat sink required for Pine64? - by g_t_j - 05-03-2016, 07:07 PM
RE: Heat sink required for Pine64? - by Beryllium - 05-03-2016, 07:54 PM
RE: Heat sink required for Pine64? - by g_t_j - 05-04-2016, 07:22 AM
RE: Heat sink required for Pine64? - by rahlquist - 05-04-2016, 08:02 AM
RE: Heat sink required for Pine64? - by Beryllium - 05-04-2016, 05:32 PM
Heat sink required for Pine64? - by Leoncito81 - 05-03-2016, 09:20 PM
RE: Heat sink required for Pine64? - by tkaiser - 05-04-2016, 02:49 AM
RE: Heat sink required for Pine64? - by Pepe - 05-28-2016, 05:18 AM
RE: Heat sink required for Pine64? - by g_t_j - 05-28-2016, 05:27 AM
  When Will the Heat Sinks From Pine be Available? Bob123456789 3 5,241 05-05-2016, 12:07 AM
