rock64 only works with 546 MB bionic-minimal-rock64-0.6.40-226-arm64
I got two rock64 from amazon.
The first one works with every thing I put on .  (Unbuttu, Android , denbian stretch buster, etc..)
The second one crash all the times!  the only version which works with this one is
bionic-minimal-rock64-0.6.40-226-arm64.img.xz
Nothing from the Pine installer works. What am I missing?
this is the serial boot from the second rock64
DDR version 1.13 20180428
In
LPDDR3
786MHz
Bus Width=32 Col=10 Bank=8 Row=15 CS=1 Die Bus-Width=32 Size=1024MB
ddrconfig:1
OUT
U-Boot SPL 2017.09-rockchip-ayufan-1045-g9922d32c04 (Mar 21 2019 - 17:27:13)
setup_ddr_param  1
booted from SPI flash
Trying to boot from SPI
NOTICE:  BL31: v1.3(debug):9d3f591
NOTICE:  BL31: Built : 14:39:02, Jan 17 2018
NOTICE:  BL31:Rockchip release version: v1.3
INFO:    ARM GICv2 driver initialized
INFO:    Using opteed sec cpu_context!
INFO:    boot cpu mask: 1
INFO:    plat_rockchip_pmu_init: pd status 0xe
INFO:    BL31: Initializing runtime services
WARNING: No OPTEE provided by BL2 boot loader, Booting device without OPTEE initialization. SMC`s destined for OPTEE will return SMC_UNK
ERROR:   Error initializing runtime service opteed_fast
INFO:    BL31: Preparing for EL3 exit to normal world
INFO:    Entry point address = 0x200000
INFO:    SPSR = 0x3c9
U-Boot 2017.09-rockchip-ayufan-1045-g9922d32c04 (Mar 21 2019 - 17:27:19 +0000)
Model: Pine64 Rock64
DRAM:  1022 MiB
MMC:   rksdmmc@ff520000: 0, rksdmmc@ff500000: 1
SF: Detected gd25q128 with page size 256 Bytes, erase size 4 KiB, total 16 MiB
*** Warning - bad CRC, using default environment
In:    serial@ff130000
Out:   serial@ff130000
Err:   serial@ff130000
misc_init_r
cpuid=55524b50303930343400000000192106
serial=6630fa723161590
Net:   eth0: ethernet@ff540000
Hit any key to stop autoboot:  0
Card did not respond to voltage select!
mmc_init: -95, time 9
switch to partitions #0, OK
mmc1 is current device
Scanning mmc 1:1...
Found U-Boot script /boot/boot.scr
2949 bytes read in 19 ms (151.4 KiB/s)
## Executing script at 00500000
Boot script loaded from mmc 1
151 bytes read in 16 ms (8.8 KiB/s)
6844859 bytes read i 341 ms (19.1 MiB/s)
19044360 bytes read in 896 ms (20.3 MiB/s)
73888 bytes read in 98 ms (735.4 KiB/s)
** File not found /botb/rockchip/overlay/rockchip-fixup.scr **
## Loading init Ramdisk from Legacy Image at 04000000 ...
  Image Name:   uInitrd
  Image Type:   AArch64 Linux RAMDisk Image (gzip compressed)
  Data Size:    6844795 Bytes = 6.5 MiB
  Load Address: 00000000
  Entry Point:  00000000
  Verifying Checksum ... OK
## Flattened Device Tree blob at 01f00000
  Booting using the fdt blob at 0x1f00000
  Loading Ramdisk to 3d879000, end 3df0017b ... OK
  reserving fdt memory region: addr=1f00000 size=78000
  Loading Device Tree to 000000003d7fe000, end 000000003d878fff ... OK
Starting kernel ...
[    0.000000] Booting Linux on physical CPU 0x0
[    0.000000] Initializing cgroup subsys cpuset
[    0.000000] Initializing cgroup subsys cpuacct
[    0.000000] Linux version 4.4.184-rockchip64 (root@nightly) (gcc version 7.4.1 20181213 [linaro-7.4-2019.02 revision 56ec6f6b99cc167ff0c2f8e1a2eed33b1edc85d4] (Linaro GCC 7.4-2019.02) ) #2 SMP Tue Jul 16 11:29:28 CEST 2019
[    0.000000] Boot CPU: AArch64 Processor [410fd034]
[    0.000000] earlycon: Early serial console at MMIO32 0xff130000 (options '')
[    0.000000] bootconsole [uart0] enabled
ERROR:   suspend_mode_handler: unhandled sip (0x1)
ERROR:   suspend_mode_handler: unhandled sip (0x4)
[    1.494986] vcc_sd: regulator get failed, ret=-517
[    1.495766] vcc_host_5v: regulator get failed, ret=-517
[    1.496562] vcc_host1_5v: regulator get failed, ret=-517
[    2.227561] i2c i2c-4: of_i2c: modalias failure on /hdmi@ff3c0000/ports
[    2.308326] rk_gmac-dwmac ff540000.ethernet: cannot get clock clk_mac_speed
[    2.610646] .. rk pwm remotectl v1.1 init
[    2.667076] cpu cpu0: Failed to get pvtm
[    2.747333] rockchip-dmc dmc: unable to get devfreq-event device : dfi
[    2.762375] Error: Driver 'ov4689' is already registered, aborting...
[    2.763220] Error: Driver 'ov7750' is already registered, aborting...
[    2.764045] Error: Driver 'ov13850' is already registered, aborting...
[    2.764877] Error: Driver 'sc031gs' is already registered, aborting...
[    3.036427] rockchip-dmc dmc: Failed to get pvtm
[    3.037101] rockchip-dmc dmc: failed to get vop bandwidth to dmc rate
[    3.037766] rockchip-dmc dmc: failed to get vop pn to msch rl
[    3.079981] mali-utgard ff300000.gpu: Failed to get pvtm
[    3.181041] devfreq ff300000.gpu: Couldn't update frequency transition information.
[    3.405840] Unable to handle kernel paging request at virtual address ffdfffc03cc87948
[    3.406699] pgd = ffffffc02a878000
[    3.407065] [ffdfffc03cc87948] *pgd=0000000000000000, *pud=0000000000000000
[    3.407820] Internal error: Oops: 96000004 [#1] SMP
[    3.408338] Modules linked in:
[    3.408679] CPU: 3 PID: 187 Comm: systemd-udevd Not tainted 4.4.184-rockchip64 #2
[    3.409464] Hardware name: Pine64 Rock64 (DT)
[    3.409928] task: ffffffc03b9a8e00 task.stack: ffffffc03a98c000
[    3.410558] PC is at kmem_cache_alloc+0x1a0/0x1ec
[    3.411058] LR is at kmem_cache_alloc+0x40/0x1ec
[    3.411544] pc : [<ffffff80081de748>] lr : [<ffffff80081de5e8>] pstate: 60000145
[    3.412316] sp : ffffffc03a98fb50
[    3.412666] x29: ffffffc03a98fb50 x28: ffffffc03b9a8e00
[    3.413243] x27: ffffffc0388fa910 x26: ffffffc03ccd76c0
[    3.413820] x25: ffffffc03e8d96e0 x24: ffffff8009321000
[    3.414396] x23: ffffff800820b0a0 x22: 00000000024000c0
[    3.414974] x21: ffffffc03e8a8200 x20: ffdfffc03cc87948
[    3.415550] x19: ffffffc03e8a8200 x18: 0000000000000fff
[    3.416123] x17: 0000007fb71fe2e8 x16: ffffff80081f3ebc
[    3.416701] x15: 0000000000000048 x14: 0000000000000017
[    3.417278] x13: 32746e6576656b63 x12: 0101010101010101
[    3.417856] x11: 7f7f7f7f7f7f7f7f x10: feff6462687570ff
[    3.418433] x9 : 0000000000000000 x8 : ffffffc02afbba38
[    3.419008] x7 : 0000000000000000 x6 : 000000000000003f
[    3.419584] x5 : ffffffc03ccd76f8 x4 : 0000000000000018
[    3.420162] x3 : ffffffc03ff8cfc0 x2 : 0000000000000341
[    3.420735] x1 : 0000004036e87000 x0 : 0000000000000000
[    3.421313]
[    3.421313] PC: 0xffffff80081de6c8:
[    3.424934] e6c8  52800800 f0005063 f9450c63 1ac00c40 937d7c00 f8606860 9ac22400 360001e0
[    3.429012] e6e8  294302b8 f9401033 b4000193 93407f18 93407c15 a9400266 2a1603e5 aa1803e4
[    3.433125] e708  aa1503e3 aa1403e2 aa1703e1 d63f00c0 f8418e60 b5ffff00 aa1403e0 f94023f9
[    3.437249] e728  a94153f3 a9425bf5 a94363f7 a8c57bfd d65f03c0 aa1503f3 17ffffbb b9802260
[    3.441372] e748  f8606a81 d538d083 f9400260 91000444 8b030000 f9800011 c87f1406 ca1400c6
[    3.445500] e768  ca0200a5 aa0500c5 b5000065 c8261001 35ffff46 b5fff5a5 b9802260 f8a06820
[    3.449685] e788  17ffffbc d2800014 17ffffc5 a9bb7bfd 910003fd a90153f3 a9025bf5 a90363f7
[    3.453888] e7a8  a9046bf9 aa0003f7 aa1e03f8 2a0103f6 aa1e03e0 d503201f f1400aff 54000249
[    3.458023]
[    3.458023] LR: 0xffffff80081de568:
[    3.464246] e568  52801801 d2800302 72a04801 f947fc00 97ffff65 b4000120 f0008a01 91374021
[    3.468085] e588  a9005015 f9401022 f9000802 f9001020 52800000 17ffffee 12800160 17ffffec
[    3.471918] e5a8  a9bb7bfd 910003fd a90153f3 a9025bf5 a90363f7 f90023f9 2a0103f6 aa1e03f7
[    3.475800] e5c8  aa0003f5 aa1e03e0 d503201f b0007ac0 b9480014 0a1402d4 36b00054 94278c3a
[    3.479734] e5e8  f0008a18 aa1503f3 b94e1700 7100001f 540001ad 37a00a14 d5384100 b9401001
[    3.483684] e608  7218303f 54000981 f9425001 b4000941 b9402c00 37a80900 aa1503e0 94003cf4
[    3.487642] e628  aa0003f3 b4000b13 f9400260 910003e1 d538d082 91002000 f8626802 d538d081
[    3.491648] e648  f9400260 8b010003 f8616814 b5000794 d53b4239 d50342df aa1703e2 2a1603e1
[    3.495629]
[    3.495629] SP: 0xffffffc03a98fad0:
[    3.502209] fad0  024000c0 00000000 0820b0a0 ffffff80 09321000 ffffff80 3e8d96e0 ffffffc0
[    3.506140] faf0  3ccd76c0 ffffffc0 388fa910 ffffffc0 3b9a8e00 ffffffc0 3a98fb50 ffffffc0
[    3.510045] fb10  081de5e8 ffffff80 3a98fb50 ffffffc0 081de748 ffffff80 60000145 00000000
[    3.513956] fb30  3a98fb50 ffffffc0 081de5e8 ffffff80 00000000 00000080 00000002 00000000
[    3.517839] fb50  3a98fba0 ffffffc0 0820b0a0 ffffff80 3a98fd60 ffffffc0 3a98fd60 ffffffc0
[    3.521688] fb70  09139ae0 ffffff80 3b3fc800 ffffffc0 00000101 00000000 3ccd76c0 ffffffc0
[    3.525528] fb90  3e8d96e0 ffffffc0 3a98fd60 ffffffc0 3a98fbd0 ffffffc0 0820b1f4 ffffff80
[    3.529355] fbb0  3a98fd60 ffffffc0 3ccd76c0 ffffffc0 3ccd76c0 ffffffc0 3a98fd60 ffffffc0
[    3.533214]
[    3.533214] X3: 0xffffffc03ff8cf40:
[    3.539579] cf40  3b2a0000 ffffffc0 00000008 00000000 c0eca800 ffffffbd 00000000 00000000
[    3.543457] cf60  3e1ff420 ffffffc0 000000f0 00000000 c0f87fc0 ffffffbd 00000000 00000000
[    3.547331] cf80  00000000 00000000 00000003 00000000 00000000 00000000 00000000 00000000
[    3.551227] cfa0  00000000 00000000 00000003 00000000 00000000 00000000 00000000 00000000
[    3.555094] cfc0  3cc87948 ffdfffc0 00000341 00000000 c0f321c0 ffffffbd c0ebce40 ffffffbd
[    3.558992] cfe0  2b16a2f0 ffffffc0 0000002b 00000000 c0ac5a00 ffffffbd 00000000 00000000
[    3.562906] d000  2afbb7c0 ffffffc0 000003be 00000000 c0abee80 ffffffbd c0abf200 ffffffbd
[    3.566821] d020  0000000f 00000003 00000000 00000000 00000000 00000000 00000003 00000000
[    3.570771]
[    3.570771] X5: 0xffffffc03ccd7678:
[    3.577435] 7678  00000000 00000000 3ccd7680 ffffffc0 3ccd7680 ffffffc0 3ccd7bb0 ffffffc0
[    3.581462] 7698  3ccd5ac8 ffffffc0 3ccd76a0 ffffffc0 3ccd76a0 ffffffc0 00000000 00000000
[    3.585506] 76b8  388fa750 ffffffc0 00200088 00000004 00000000 00000000 3fe9aca0 ffffffc0
[    3.589594] 76d8  3aef4510 ffffffc0 bbec438a 00000004 3ccd76f8 ffffffc0 388fa910 ffffffc0
[    3.593708] 76f8  61746164 55551500 55555555 5157555d 555555d5 5555155d 55555555 005d4555
[    3.597885] 7718  08d008d0 dead4ead ffffffff 55d55d55 ffffffff ffffffff 00000038 5d555555
[    3.602090] 7738  08c02300 ffffff80 3b3fc800 ffffffc0 575d5555 dc545745 00000000 00000000
[    3.606348] 7758  3ccd7758 ffffffc0 3ccd7758 ffffffc0 3aef4c78 ffffffc0 3cc80840 ffffffc0
[    3.610574]
[    3.610574] X8: 0xffffffc02afbb9b8:
[    3.617700] b9b8  00000000 00000000 00000000 00000000 00000000 00000000 388e33c0 ffffffc0
[    3.621908] b9d8  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[    3.626054] b9f8  00000000 00000000 00000000 00000000 00000000 00000000 2afbba10 ffffffc0
[    3.630137] ba18  2afbba10 ffffffc0 2afbba20 ffffffc0 2afbba20 ffffffc0 00000000 00000000
[    3.634220] ba38  00000000 00000000 00000000 00000000 081f64b8 ffffff80 00000000 00000000
[    3.638272] ba58  00000000 00000000 00000000 00000000 08c0b1b8 ffffff80 00000000 dead4ead
[    3.642257] ba78  ffffffff 00000000 ffffffff ffffffff 00000000 00000000 00020000 0002800d
[    3.646280] ba98  00000001 00000000 00000000 dead4ead ffffffff 00000000 ffffffff ffffffff
[    3.650272]
[    3.650272] X16: 0xffffff80081f3e3c:
[    3.656918] 3e3c  2a1503e2 aa1703e0 9400feba aa1703e2 52800005 d2800004 52800023 2a1503e1
[    3.660876] 3e5c  aa1803e0 9400fdaa aa1403e1 2a1603e0 9400736c 17ffffcf a9bd7bfd 910003fd
[    3.664830] 3e7c  a90153f3 f90013f5 aa0103f4 aa0203f5 aa0003f3 aa1e03e0 d503201f 2a1503e3
[    3.668781] 3e9c  320f0282 aa1303e1 12800c60 97ffff65 f94013f5 a94153f3 a8c37bfd d65f03c0
[    3.672739] 3ebc  a9bd7bfd 910003fd a90153f3 a9025bf5 aa0003f3 aa0103f4 aa1e03e0 aa0203f5
[    3.676700] 3edc  aa0303f6 d503201f 2a1603e3 320f02a2 aa1403e1 2a1303e0 97ffff52 a94153f3
[    3.680642] 3efc  a9425bf5 a8c37bfd d65f03c0 a9be7bfd 910003fd a90153f3 aa0103f4 aa0003f3
[    3.684636] 3f1c  aa1e03e0 d503201f 2a1403e2 52804821 aa1303e0 97ffffd1 a94153f3 a8c27bfd
[    3.688617]
[    3.688617] X19: 0xffffffc03e8a8180:
[    3.695328] 8180  08ed64db ffffff80 3e8a8088 ffffffc0 3e8a8288 ffffffc0 3ebad7a8 ffffffc0
[    3.699358] 81a0  3ebad780 ffffffc0 09167018 ffffff80 3b9e1168 ffffffc0 00000002 00000007
[    3.703388] 81c0  00000001 00000000 3e8a81c8 ffffffc0 3e8a81c8 ffffffc0 00000000 00000000
[    3.707411] 81e0  00000000 00000000 00000000 00000000 3ebbf800 ffffffc0 3e8a9080 ffffffc0
[    3.711431] 8200  09105fc0 ffffff80 40060000 00000000 00000005 00000000 000000d8 000000d8
[    3.715475] 8220  00000000 0000001e 00000012 00000000 00000012 00000000 00000012 00000000
[    3.719465] 8240  00000010 00000001 00000000 00000000 000000d8 00000008 00000000 00000000
[    3.723448] 8260  08eaae47 ffffff80 3e8a8168 ffffffc0 3e8a8368 ffffffc0 00000000 00000000
[    3.727405]
[    3.727405] X21: 0xffffffc03e8a8180:
[    3.734136] 8180  08ed64db ffffff80 3e8a8088 ffffffc0 3e8a8288 ffffffc0 3ebad7a8 ffffffc0
[    3.738226] 81a0  3ebad780 ffffffc0 09167018 ffffff80 3b9e1168 ffffffc0 00000002 00000007
[    3.742304] 81c0  00000001 00000000 3e8a81c8 ffffffc0 3e8a81c8 ffffffc0 00000000 00000000
[    3.746384] 81e0  00000000 00000000 00000000 00000000 3ebbf800 ffffffc0 3e8a9080 ffffffc0
[    3.750471] 8200  09105fc0 ffffff80 40060000 00000000 00000005 00000000 000000d8 000000d8
[    3.754556] 8220  00000000 0000001e 00000012 00000000 00000012 00000000 00000012 00000000
[    3.758590] 8240  00000010 00000001 00000000 00000000 000000d8 00000008 00000000 00000000
[    3.762616] 8260  08eaae47 ffffff80 3e8a8168 ffffffc0 3e8a8368 ffffffc0 00000000 00000000
[    3.766616]
[    3.766616] X23: 0xffffff800820b020:
[    3.773354] b020  91393800 97fe108b d4210000 f9403660 f900367f 97fffe16 f9406a60 f27ff800
[    3.777395] b040  54000081 a94153f3 a8c27bfd d65f03c0 f1002014 54000060 91014000 940e2141
[    3.781430] b060  aa1403e0 17fffff4 a9bd7bfd 910003fd a90153f3 a9025bf5 d0007975 912b82b5
[    3.785459] b080  aa0103f4 aa0003f6 aa1e03e0 d503201f f9400aa0 52801801 72a04801 97ff4d43
[    3.789486] b0a0  aa0003f3 b40001e0 39015c1f b9400680 71007c1f 54000869 2a0003e0 52801801
[    3.793525] b0c0  72a04801 91004400 97ff4db3 b5000140 f9400aa0 aa1303e1 d2800013 97ff50c1
[    3.797548] b0e0  aa1303e0 a94153f3 a9425bf5 a8c37bfd d65f03c0 aa0003e3 52800020 b8010460
[    3.801619] b100  b9400680 b9002660 b9400280 b9002260 aa0303e0 b9400682 f9400681 940def29
[    3.805679]
[    3.805679] X24: 0xffffff8009320f80:
[    3.812632] 0f80  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[    3.816772] 0fa0  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[    3.820861] 0fc0  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[    3.824937] 0fe0  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[    3.828952] 1000  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[    3.832909] 1020  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[    3.836779] 1040  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[    3.840628] 1060  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[    3.844391]
[    3.844391] X25: 0xffffffc03e8d9660:
[    3.850604] 9660  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[    3.854351] 9680  00000000 00000000 082134fc ffffff80 00000000 00000000 00000000 00000000
[    3.858047] 96a0  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[    3.861693] 96c0  00000000 00000000 3e8ca438 ffffffc0 3e8d8000 ffffffc0 3cc03870 ffffffc0
[    3.865321] 96e0  3aedf5e8 ffffffc0 3b3fc800 ffffffc0 00000025 00000000 00000000 00000000
[    3.868941] 9700  00000000 00000000 00000000 00000000 891542fc ffffff7d 3e8d9718 ffffffc0
[    3.872555] 9720  3e8d9718 ffffffc0 3e8d8058 ffffffc0 3e8d93a8 ffffffc0 3b3fc8d8 ffffffc0
[    3.876205] 9740  3b3fc8d8 ffffffc0 3b11b340 ffffffc0 3e806ca8 ffffffc0 3e8d9590 ffffffc0
[    3.879801]
[    3.879801] X26: 0xffffffc03ccd7640:
[    3.885744] 7640  00060006 dead4ead ffffffff 4d55c557 ffffffff ffffffff 00000001 57455557
[    3.889398] 7660  08c02300 ffffff80 3ead0000 ffffffc0 555d555d 5d55555d 00000000 00000000
[    3.893062] 7680  3ccd7680 ffffffc0 3ccd7680 ffffffc0 3ccd7bb0 ffffffc0 3ccd5ac8 ffffffc0
[    3.896755] 76a0  3ccd76a0 ffffffc0 3ccd76a0 ffffffc0 00000000 00000000 388fa750 ffffffc0
[    3.900462] 76c0  00204088 00000004 00000000 00000000 3fe9aca0 ffffffc0 3aef4510 ffffffc0
[    3.904177] 76e0  bbec438a 00000004 3ccd76f8 ffffffc0 388fa910 ffffffc0 61746164 55551500
[    3.907860] 7700  55555555 5157555d 555555d5 5555155d 55555555 005d4555 08d108d1 dead4ead
[    3.911607] 7720  ffffffff 55d55d55 ffffffff ffffffff 00000038 5d555555 08c02300 ffffff80
[    3.915340]
[    3.915340] X27: 0xffffffc0388fa890:
[    3.921562] a890  00000000 00000000 388fa8a0 ffffffc0 00000000 dead4ead ffffffff 00000000
[    3.925357] a8b0  ffffffff ffffffff 00000001 00000000 00200000 00000000 00000000 00000000
[    3.929151] a8d0  00000000 00000000 388fa8d8 ffffffc0 388fa8d8 ffffffc0 388fa8e8 ffffffc0
[    3.932991] a8f0  388fa8e8 ffffffc0 00000000 dead4ead ffffffff 00000000 ffffffff ffffffff
[    3.936888] a910  000341ed 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[    3.940785] a930  08bff240 ffffff80 3b3fc800 ffffffc0 388faaa8 ffffffc0 00000000 00000000
[    3.944656] a950  00002b5f 00000000 00000002 00000000 000003ac 00000000 56a09bcb 00000000
[    3.948569] a970  2dc6c000 00000000 56a09bcb 00000000 31d45900 00000000 56a09bcb 00000000
[    3.952426]
[    3.952426] X28: 0xffffffc03b9a8d80:
[    3.958813] 8d80  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[    3.962644] 8da0  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[    3.966407] 8dc0  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[    3.970101] 8de0  00000000 00000000 00000000 00000000 d5554554 55555e77 d55d5555 54505441
[    3.973766] 8e00  00000012 00000000 ffffffff ffffffff 00000000 00000000 00000000 00000000
[    3.977421] 8e20  3a98c000 ffffffc0 00000002 00404140 00000000 00000000 00000000 00000000
[    3.981032] 8e40  00000001 00000003 00000138 00000000 fffedd6a 00000000 3ea3e200 ffffffc0
[    3.984679] 8e60  00000003 00000001 00000078 00000078 00000078 00000000 08bee588 ffffff80
[    3.988270]
[    3.988270] X29: 0xffffffc03a98fad0:
[    3.994348] fad0  024000c0 00000000 0820b0a0 ffffff80 09321000 ffffff80 3e8d96e0 ffffffc0
[    3.998136] faf0  3ccd76c0 ffffffc0 388fa910 ffffffc0 3b9a8e00 ffffffc0 3a98fb50 ffffffc0
[    4.001965] fb10  081de5e8 ffffff80 3a98fb50 ffffffc0 081de748 ffffff80 60000145 00000000
[    4.005848] fb30  3a98fb50 ffffffc0 081de5e8 ffffff80 00000000 00000080 00000002 00000000
[    4.009781] fb50  3a98fba0 ffffffc0 0820b0a0 ffffff80 3a98fd60 ffffffc0 3a98fd60 ffffffc0
[    4.013760] fb70  09139ae0 ffffff80 3b3fc800 ffffffc0 00000101 00000000 3ccd76c0 ffffffc0
[    4.017702] fb90  3e8d96e0 ffffffc0 3a98fd60 ffffffc0 3a98fbd0 ffffffc0 0820b1f4 ffffff80
[    4.021670] fbb0  3a98fd60 ffffffc0 3ccd76c0 ffffffc0 3ccd76c0 ffffffc0 3a98fd60 ffffffc0
[    4.025586]
[    4.028826] Process systemd-udevd (pid: 187, stack limit = 0xffffffc03a98c000)
[    4.032697] Stack: (0xffffffc03a98fb50 to 0xffffffc03a990000)
[    4.036444] fb40:                                   ffffffc03a98fba0 ffffff800820b0a0
[    4.040420] fb60: ffffffc03a98fd60 ffffffc03a98fd60 ffffff8009139ae0 ffffffc03b3fc800
[    4.044384] fb80: 0000000000000101 ffffffc03ccd76c0 ffffffc03e8d96e0 ffffffc03a98fd60
[    4.048331] fba0: ffffffc03a98fbd0 ffffff800820b1f4 ffffffc03a98fd60 ffffffc03ccd76c0
[    4.052294] fbc0: ffffffc03ccd76c0 ffffffc03a98fd60 ffffffc03a98fc00 ffffff8008201138
[    4.056207] fbe0: 0000000000000000 ffffffc03a98fcdf ffffffc03ccd76c0 ffffffc03a98fd60
[    4.060141] fc00: ffffffc03a98fc40 ffffff80082023fc ffffffc03a98fd50 ffffffc02afbb900
[    4.064036] fc20: 0000000000000000 0000000000000000 ffffffc03a98fe7c ffffff80086ff474
[    4.067911] fc40: ffffffc03a98fd10 ffffff80082042c4 ffffffc03a98fe7c 0000000000000001
[    4.071784] fc60: 00000000ffffff9c ffffffc03ba41000 0000000080000000 0000000000000015
[    4.075677] fc80: 000000000000011d 0000000000000038 ffffff8008be2000 ffffffc03b9a8e00
[    4.079570] fca0: ffffff8009139ac8 ffffff800826cf44 ffffffc000000041 ffffff8000000024
[    4.083465] fcc0: 000000003eba7a80 0000000000020000 ffffffc03a98fd00 00ffff8008216cd4
[    4.087336] fce0: ffffffc000000000 ffffff80082042b4 0000000000000000 0000000000000000
[    4.091203] fd00: 00000000ffffff9c ffffff800826d57c ffffffc03a98fe20 ffffff80081f3d94
[    4.095049] fd20: ffffffc03ba41000 00000000ffffff9c 00000000000a0000 0000000000000005
[    4.098949] fd40: ffffffc03a98fdb0 ffffff8008210a10 ffffffc03e8d96e0 ffffffc03ccd76c0
[    4.102820] fd60: 00000018d7b1fedf ffffffc03ba4102b ffffffc03e8d8020 ffffffc03e408000
[    4.106675] fd80: ffffffc0388fa910 0000000400000101 000000000000005e 0000000000000000
[    4.110524] fda0: ffffffc03a98fda8 ffffff80082109f4 ffffffc03a98fe00 ffffff8008210b58
[    4.114370] fdc0: 00000000000a0000 00000000ffffff9c 00000000000a0000 0000007fe658c540
[    4.118227] fde0: 0000000080000000 0000000000000015 000000000000011d 0000000000000038
[    4.122064] fe00: ffffffc03a98fe20 ffffffc03ba41000 0000000000000000 ffffff9c00000002
[    4.125892] fe20: ffffffc03a98fe90 ffffff80081f3ef8 ffffffffffffff9c 0000007fe658c540
[    4.129744] fe40: 0000000000080000 0000000000000000 0000000080000000 0000000000000015
[    4.133579] fe60: ffffffc03a98fe90 ffffff8008087cc8 0000000000000004 000200003b9a8e00
[    4.137442] fe80: 000000243a980000 0000000100000100 0000000000000000 ffffff8008082f30
[    4.141271] fea0: 0000000000000000 0000004036e87000 ffffffffffffffff 0000007fb7248e4c
[    4.145158] fec0: ffffffffffffff9c 0000007fe658c540 0000000000080000 0000000000000000
[    4.149107] fee0: 0000000000000008 0000000000000001 000000558bf981e6 0000000000080000
[    4.153062] ff00: 0000000000000038 7f7f7f7f7f7f7f7f feff6462687570ff 7f7f7f7f7f7f7f7f
[    4.157017] ff20: 0101010101010101 32746e6576656b63 0000000000000017 0000000000000048
[    4.161002] ff40: 0000007fb72f3010 0000007fb71fe2e8 0000000000000fff 0000007fb72f2000
[    4.164984] ff60: 0000007fe658c540 0000000000000008 000000558bf981e0 0000000000000001
[    4.168979] ff80: 000000558bfde000 000000558bfa3000 0000007fe658c608 00000055a3de8ae0
[    4.172938] ffa0: 00000055a3dfd370 0000007fe658c2d0 0000007fb71f6230 0000007fe658c2d0
[    4.176920] ffc0: 0000007fb7248e4c 0000000080000000 ffffffffffffff9c 0000000000000038
[    4.180864] ffe0: 0000000000000000 0000000000000000 0000000000000000 0000000000000000
[    4.184802] Call trace:
[    4.188228] Exception stack(0xffffffc03a98f980 to 0xffffffc03a98fab0)
[    4.192072] f980: ffffffc03e8a8200 0000008000000000 ffffffc03a98fb50 ffffff80081de748
[    4.196079] f9a0: ffffffc03a98f9c0 ffffff80081ddb68 ffffffc03e8a9200 0000000000000000
[    4.200086] f9c0: ffffffc03a98fad0 ffffff80081de058 0000000000000000 ffffffc03ff8d000
[    4.204087] f9e0: 0000000000000000 ffffffc03e8a8400 0000000100190019 0000000000210d00
[    4.208108] fa00: 00000000024080c0 ffffff80081f68f4 0000000000000000 ffffffc03b9a8e00
[    4.212084] fa20: 0000000000000000 0000004036e87000 0000000000000341 ffffffc03ff8cfc0
[    4.216030] fa40: 0000000000000018 ffffffc03ccd76f8 000000000000003f 0000000000000000
[    4.219937] fa60: ffffffc02afbba38 0000000000000000 feff6462687570ff 7f7f7f7f7f7f7f7f
[    4.223835] fa80: 0101010101010101 32746e6576656b63 0000000000000017 0000000000000048
[    4.227753] faa0: ffffff80081f3ebc 0000007fb71fe2e8
[    4.231413] [<ffffff80081de748>] kmem_cache_alloc+0x1a0/0x1ec
[    4.235167] [<ffffff800820b0a0>] __d_alloc+0x38/0x160
[    4.238851] [<ffffff800820b1f4>] d_alloc+0x2c/0x90
[    4.242495] [<ffffff8008201138>] lookup_dcache+0xa8/0xc4
[    4.246176] [<ffffff80082023fc>] path_openat+0x390/0xdf4
[    4.249835] [<ffffff80082042c4>] do_filp_open+0x48/0x94
[    4.253461] [<ffffff80081f3d94>] do_sys_open+0x158/0x238
[    4.257068] [<ffffff80081f3ef8>] SyS_openat+0x3c/0x4c
[    4.260618] [<ffffff8008082f30>] el0_svc_naked+0x24/0x28
[    4.264169] Code: d65f03c0 aa1503f3 17ffffbb b9802260 (f8606a81)
[    4.267796] ---[ end trace 0218cbf1d0616a51 ]---
[url=https://github.com/ayufan-rock64/linux-build/releases/download/0.6.40/bionic-minimal-rock64-0.6.40-226-arm64.img.xz][/url]
rock64 only works with 546 MB bionic-minimal-rock64-0.6.40-226-arm64 - by danjperron - 02-07-2020, 05:15 PM
  Rock64 No Audio @ Debian 12 dmitrymyadzelets 2 280 04-08-2024, 06:47 AM
Last Post: dmitrymyadzelets
  OpenWRT on the Rock64 CanadianBacon 14 8,318 04-03-2024, 08:48 AM
Last Post: helpmerock
  Rock64 bricked shawwwn 7 5,667 03-17-2024, 12:22 PM
  Rock64 won't boot luminosity7 10 4,131 03-16-2024, 08:33 AM
  Rock64 doesn't boot dstallmo 1 334 03-16-2024, 08:29 AM
  How well does Rock64 deal with HDR and Atmos on Kodi? drvlikhell 3 1,883 04-29-2023, 04:24 AM
Last Post: newestssd
  Rock64 board not working, no HDMI no Ethernet. EDited 3 3,524 01-17-2023, 02:31 PM
Last Post: Flagtrax
  ROCK64 v3 can it boot from USB? Tsagualsa 4 2,098 11-29-2022, 11:31 AM
Last Post: Macgyver
  rock64 v3 spiflash Macgyver 0 757 11-28-2022, 02:18 PM
Last Post: Macgyver
  my rock64 dosen't work rookie_267 0 951 10-07-2022, 07:50 PM
Last Post: rookie_267
