Flash dhivael's SPI uboot (risky)
#24
(02-08-2020, 12:21 PM)Wizzard Wrote: I think my SPI is not corrupted because when there is a boot device connected, the led goes green like it was loading a kernel... But I do not understand it. One time I was able to enter loader mode even when my SPI was broken using recovery button.
The recovery button is iffy at best, from what I have gathered from the community. It is not a consistent method of getting into maskrom, sadly.
The lights are a good sign that your pinebook is not terribly broken, though Smile still i recommend bypassing SPI altogether. which should be a surefire way of getting back into maskrom where you can flash zeroes to your SPI, and then flash either Dhiv's or pcm720 (since you know that works for you if you want to be done with Dhiv's)
Flash dhivael's SPI uboot (risky) - by clover - 02-06-2020, 10:42 PM
RE: Flash dhivael's SPI uboot - by Wizzard - 02-07-2020, 12:40 AM
RE: Flash dhivael's SPI uboot - by clover - 02-07-2020, 12:52 AM
RE: Flash dhivael's SPI uboot - by as400 - 02-07-2020, 01:18 AM
RE: Flash dhivael's SPI uboot - by amiraeva - 02-07-2020, 09:42 AM
RE: Flash dhivael's SPI uboot - by Wizzard - 02-07-2020, 02:04 PM
RE: Flash dhivael's SPI uboot - by clover - 02-07-2020, 02:42 PM
RE: Flash dhivael's SPI uboot - by User 15997 - 02-07-2020, 02:34 PM
RE: Flash dhivael's SPI uboot - by Wizzard - 02-07-2020, 02:40 PM
RE: Flash dhivael's SPI uboot - by as400 - 02-07-2020, 02:53 PM
RE: Flash dhivael's SPI uboot - by Wizzard - 02-07-2020, 03:05 PM
RE: Flash dhivael's SPI uboot - by as400 - 02-07-2020, 03:39 PM
RE: Flash dhivael's SPI uboot - by Wizzard - 02-07-2020, 03:57 PM
RE: Flash dhivael's SPI uboot - by as400 - 02-07-2020, 04:11 PM
RE: Flash dhivael's SPI uboot - by clover - 02-07-2020, 04:12 PM
RE: Flash dhivael's SPI uboot - by Wizzard - 02-07-2020, 04:23 PM
RE: Flash dhivael's SPI uboot - by as400 - 02-08-2020, 06:36 AM
RE: Flash dhivael's SPI uboot - by pinebro - 02-07-2020, 05:08 PM
RE: Flash dhivael's SPI uboot - by clover - 02-07-2020, 05:42 PM
RE: Flash dhivael's SPI uboot - by pinebro - 02-07-2020, 06:27 PM
RE: Flash dhivael's SPI uboot - by clover - 02-08-2020, 01:37 PM
RE: Flash dhivael's SPI uboot (risky) - by clover - 02-08-2020, 12:07 PM
RE: Flash dhivael's SPI uboot (risky) - by as400 - 02-08-2020, 12:36 PM
RE: Flash dhivael's SPI uboot (risky) - by clover - 02-08-2020, 12:25 PM
RE: Flash dhivael's SPI uboot (risky) - by clover - 02-08-2020, 01:46 PM
Flash dhivael's SPI uboot (risky) - by Wizzard - 02-08-2020, 02:02 PM
RE: Flash dhivael's SPI uboot (risky) - by clover - 02-08-2020, 02:13 PM
RE: Flash dhivael's SPI uboot (risky) - by as400 - 02-08-2020, 02:07 PM
RE: Flash dhivael's SPI uboot (risky) - by as400 - 02-08-2020, 03:35 PM
RE: Flash dhivael's SPI uboot (risky) - by as400 - 02-09-2020, 01:55 PM
RE: Flash dhivael's SPI uboot (risky) - by as400 - 02-09-2020, 02:27 PM
RE: Flash dhivael's SPI uboot (risky) - by as400 - 02-09-2020, 02:46 PM
RE: Flash dhivael's SPI uboot (risky) - by as400 - 03-12-2020, 11:16 AM
RE: Flash dhivael's SPI uboot (risky) - by vrabac - 03-13-2020, 12:12 AM
RE: Flash dhivael's SPI uboot (risky) - by as400 - 03-14-2020, 08:04 AM
  How to rewrite uboot to emmc pineitup 5 13,692 12-27-2020, 10:35 AM
Last Post: nightranger73
  Extracting a copy of SPI NOR flash contents using micro SD card and u-boot hmuller 0 4,601 09-21-2020, 11:24 AM
Last Post: hmuller
  Program SPI NOR Flash on Pinebook Pro with u-boot on micro SD Card hmuller 0 5,489 09-21-2020, 10:02 AM
Last Post: hmuller
  In-Circuit Programming of SPI NOR Flash hmuller 13 28,758 09-13-2020, 01:20 PM
Last Post: hmuller
  Installing Ubuntu 20.04 (Focal) with BSP uBoot with deep sleep and sound Syonyk 43 79,307 07-28-2020, 03:18 PM
Last Post: SamWilts
  How to boot Manjaro from NVME with uboot on eMMC as400 47 87,198 06-07-2020, 02:37 AM
Last Post: as400
  (almost) upstream uboot/atf User 15997 27 48,113 02-08-2020, 10:18 PM
Last Post: Natrox
  Widevine-flash on Chromium-SD Card mamboman777 3 9,539 01-20-2020, 04:00 PM
