full disk encryption with luks on manjaro xfce
#36
(05-15-2020, 12:42 AM)e-minguez Wrote: The howto is very simple, you just need:
* a manjaro x86_64 VM with X (see https://gitlab.manjaro.org/manjaro-arm/a.../issues/10 for the reason behind the X requirement) with an extra disk (in my case, I've used a 8gb qcow2 empty file mapped as sata, so it is /dev/sda in the VM)
* ssh into it
* clone the https://gitlab.manjaro.org/manjaro-arm/a...-installer repo
* install the required packages (dialog and manjaro-arm-qemu-static in my case)
* apply the patch (git apply)
* run export CRYPT=y, then the installer. It will ask you user/pass/software selection/keyboard/etc. then the luks password twice (first one to create the device, the second one to mount it)
Then, power off the manjaro VM, plug a microsd into your computer and convert the qcow2 image into a raw one, then flash it to your microsd (or do it at once as qemu-img convert -f qcow2 -O raw manjaro-usb.qcow2 /dev/mmcblkX)
Plug it into your pbp and profit!
In order to resize the luks partition:
* `parted /dev/mmcblkX`, then `resizepart NUMBER END` (in my case, partition = 2, end = 125GB)
* `cryptsetup resize /dev/mapper/ROOT_MNJRO`
* `resize2fs /dev/mapper/ROOT_MNJRO`
HTH!
Edit: I've tested with the console parameter as suggested and it doesn't work, so I'll keep it that way.
Amazing, Thank you!
sidenote - If you put a bad password in, the script will happily continue. (yes, I know, I was going to change it later)
Enter passphrase for /dev/sda2:
Password quality check failed:
 The password fails the dictionary check - it is based on a dictionary word
Device /dev/sda2 is not a valid LUKS device.
mount: /var/tmp/manjaro-arm-installer/root: special device /dev/mapper/ROOT_MNJRO does not exist.
RE: full disk encryption with luks on manjaro xfce - by FutureBucket - 05-19-2020, 02:31 PM
  Building PPSSPP with Manjaro AUR LivingLinux 0 1,159 06-11-2022, 05:07 PM
Last Post: LivingLinux
  How to update Manjaro to 20.10 pineitup 8 13,553 07-31-2021, 04:44 AM
Last Post: jiyong
  Make your own Manjaro image flatulent_piney 0 3,240 11-07-2020, 03:30 AM
Last Post: flatulent_piney
  Manjaro ARM, Cryptomator, and MEGA Sync dp1kinobe 3 7,131 10-24-2020, 06:38 AM
Last Post: pineitup
  Downgrading packages on Manjaro ARM (on the example of boinc) wrzomar 0 3,431 10-02-2020, 12:20 PM
Last Post: wrzomar
  Freepascal FPC3.20 and Lazarus IDE on Manjaro KDE dieselnutjob 0 2,909 08-02-2020, 06:57 AM
Last Post: dieselnutjob
  Installing WPS Office on Manjaro brent.thierens 5 9,738 07-13-2020, 03:13 AM
Last Post: brent.thierens
  kernel build script for latest mainline manjaro kernel xmixahlx 42 58,445 07-11-2020, 09:01 PM
Last Post: xmixahlx
  Is there a MMC upgrade instruction from debian-mate to manjaro factory (20.06)? pljanson 4 7,938 06-23-2020, 12:41 AM
Last Post: pljanson
  How to boot Manjaro from NVME with uboot on eMMC as400 47 56,771 06-07-2020, 02:37 AM
Last Post: as400
