I got it working with mkinitcpio after removing both the bootsplash and the console=ttyS2 stuff \o/
I'm going to try to clean up the code a bit, try to just modify the HOOKS in mkinitcpio.conf (to be able to be 'generic' and to work for other devices) and then I will submit a PR to the manjaro repo.
Thanks @as400 for your help!
Edit: No luck with just modifying the HOOKS section (black screen), so I guess that for every device, a list of modules needs to be provided.
Edit2: The patch is available here https://gist.github.com/e-minguez/5287bc...21248b8405 let's see if they merge it, meanwhile, I'm happy to have it working on my pbp \o/
