full disk encryption with luks on manjaro xfce
#21
(05-13-2020, 09:54 AM)e-minguez Wrote:
(05-13-2020, 03:49 AM)as400 Wrote: Here is how I'm generating initcpio with dracut. I have bootfs unencrypted and rootfs encrypted. I use nvme drive. Everything works just fine.
dracut -H --force -a "crypt lvm drm" -o "kernel-network-modules kernel-modules-extra kernel-modules mdraid qemu qemu-net \
lunmask resume dmraid btrfs modsign i18n" --drivers="rockchipdrm drm drm_kms_helper analogix_dp panel-simple pwm_bl" \
/boot/initramfs-dracut.img
I've used a slightly modified version (removed the -H and used the same name that mkinitcpio uses for the initrd file)  because the manjaro-arm-installer is using a chroot. No luck either Sad same blinking cursor.
I don't have any suggestions because when I tried, I was stuck at the same point you are.
I just wanted to say thank you for your work on this! I'm watching your progress and I'm hopeful you get it. I'll give it a try this weekend again and see how far I get. I'll post if I get anywhere. I'm not using my PBP because I cant get FDE working.
RE: full disk encryption with luks on manjaro xfce - by FutureBucket - 05-13-2020, 12:20 PM
  Building PPSSPP with Manjaro AUR LivingLinux 0 1,109 06-11-2022, 05:07 PM
Last Post: LivingLinux
  How to update Manjaro to 20.10 pineitup 8 13,328 07-31-2021, 04:44 AM
Last Post: jiyong
  Make your own Manjaro image flatulent_piney 0 3,187 11-07-2020, 03:30 AM
Last Post: flatulent_piney
  Manjaro ARM, Cryptomator, and MEGA Sync dp1kinobe 3 7,017 10-24-2020, 06:38 AM
Last Post: pineitup
  Downgrading packages on Manjaro ARM (on the example of boinc) wrzomar 0 3,378 10-02-2020, 12:20 PM
Last Post: wrzomar
  Freepascal FPC3.20 and Lazarus IDE on Manjaro KDE dieselnutjob 0 2,871 08-02-2020, 06:57 AM
Last Post: dieselnutjob
  Installing WPS Office on Manjaro brent.thierens 5 9,612 07-13-2020, 03:13 AM
Last Post: brent.thierens
  kernel build script for latest mainline manjaro kernel xmixahlx 42 57,467 07-11-2020, 09:01 PM
Last Post: xmixahlx
  Is there a MMC upgrade instruction from debian-mate to manjaro factory (20.06)? pljanson 4 7,809 06-23-2020, 12:41 AM
Last Post: pljanson
  How to boot Manjaro from NVME with uboot on eMMC as400 47 55,752 06-07-2020, 02:37 AM
Last Post: as400
