Suspend with NVME not working - Default Debian
(02-06-2020, 08:06 PM)Jeremiah Cornelius Wrote: This is probably related to the same nvme issues I solved for Linux on the Macbook Pro, recently. The drive would "sleep" but then resume as read-only - with unpredictable effects!
The Macs don't support APST, and many nvme units also seem to be "idiosyncratic" about implementations. The fix is to "turn-off" the ability of the kernel to impose sleep states on hardware that does not conform.
After researching a bit about this, my solution was:
echo 0 > /sys/bus/pci/devices/0000\:01\:00.0/d3cold_allowed
This is now featured on the authoritative  Dunedan /mbp-2016-linux github: https://github.com/Dunedan/mbp-2016-linux
This needs to be done in a root shell, sudo user won't cut it. You can elevate by runing 'sudo su -' and have a root shell, without additional login process.
I'd seriously give this a shot, AFTER you determine with lspci the actual device number for your nvme.
If this solves your problem, I supplied scripts and a systemd service wrapper, so you may automate at boot:
https://github.com/cb22/macbook12-spi-dr...-540208177
Create this file:
Quote:/etc/systemd/system/fix_sleep.service
# systemd oneshot service to set sleep boolean on Apple Macbook Pro disks
# Original by Pier Lim. Posted at https://kerpanic.wordpress.com/2018/03/1...in-ubuntu/
   [Unit]
   Description=Job that disables sleep from stopping nvme hardware on MBP
   [Service]
   ExecStart=/sbin/fixsleep
   Type=oneshot
   RemainAfterExit=yes
   [Install]
   WantedBy=multi-user.target
And the actual script:
Quote:/sbin/fixsleep
#!/bin/bash
/bin/echo 0 > /sys/bus/pci/devices/0000\:01\:00.0/d3cold_allowed
If you try this out, I'd love to hear how it goes.
My output from lspci:
00:00.0 PCI bridge: Device 1d87:0100
01:00.0 Non-Volatile memory controller: Intel Corporation Device f1a8 (rev 03)
Do I have to modify that command with this information somehow?
RE: Suspend with NVME not working - Default Debian - by appdev46 - 02-06-2020, 08:49 PM
  Selling my Pinebook Pro with a bootable NVMe WD SSD drive pinemouth 0 705 09-27-2023, 08:53 PM
Last Post: pinemouth
  Boot into NVME drive, no wifi, sound, buttons... PaulQ 0 751 07-13-2023, 01:50 PM
Last Post: PaulQ
  Games compilation howto on the Pinebook-pro (Manjaro Linux and Debian native) astr0baby 201 314,481 05-12-2023, 06:09 AM
Last Post: korreckj328
  I'm booting from NVME but I want to switch back to eMMC acruhl 4 1,384 04-23-2023, 06:58 AM
Last Post: acruhl
  bliuetooth not working in Armbian 22.11.1 Pinebook Pro River 0 721 12-09-2022, 04:48 PM
Last Post: River
  Installing Debian using files only from debian.org and encrypted root filesystem omarcomputing 0 739 10-08-2022, 11:03 AM
Last Post: omarcomputing
  U-Boot with direct NVMe boot support for eMMC/SPI Flash pcm720 125 212,201 09-27-2022, 07:41 AM
Last Post: olyavi
  Use SD to install new OS over pinebook debian Rudy558 9 10,417 09-25-2022, 01:19 AM
Last Post: jackwilson
  Mid 2022: what is in your humble opinion the best working OS for the PinePro? walterbe 3 2,282 06-29-2022, 02:00 PM
Last Post: Chief
  Selling Pinebook Pro (ISO) + nvme from Sweden DavidL 5 3,063 06-20-2022, 03:20 PM
Last Post: DavidL
