(03-22-2020, 06:06 AM)a-wai Wrote:
(03-22-2020, 05:38 AM)buskmann Wrote: Did a "sudo apt upgrade" for more or less one hour ago, and it stopped at 84%. Last thing it put out was: e2scrub_all.service is a disabled or a static unit not running, not starting it.
Hmmm, I had a similar issue, could you share the full apt log so I can double-check with mine?
Dont know if this works, but i Attached the logfile to this post.. Its a bit to big to post here Undecided
Just in case, heres the last part:
(Reading database ...
(Reading database ... 5%
(Reading database ... 10%
(Reading database ... 15%
(Reading database ... 20%
(Reading database ... 25%
(Reading database ... 30%
(Reading database ... 35%
(Reading database ... 40%
(Reading database ... 45%
(Reading database ... 50%
(Reading database ... 55%
(Reading database ... 60%
(Reading database ... 65%
(Reading database ... 70%
(Reading database ... 75%
(Reading database ... 80%
(Reading database ... 85%
(Reading database ... 90%
(Reading database ... 95%
(Reading database ... 100%
(Reading database ... 69240 files and directories currently installed.)
Preparing to unpack .../00-libasan5_9.3.0-6_arm64.deb ...
Unpacking libasan5:arm64 (9.3.0-6) over (9.3.0-5) ...
Preparing to unpack .../01-g++-9_9.3.0-6_arm64.deb ...
Unpacking g++-9 (9.3.0-6) over (9.3.0-5) ...
Preparing to unpack .../02-gcc-9_9.3.0-6_arm64.deb ...
Unpacking gcc-9 (9.3.0-6) over (9.3.0-5) ...
Preparing to unpack .../03-libstdc++-9-dev_9.3.0-6_arm64.deb ...
Unpacking libstdc++-9-dev:arm64 (9.3.0-6) over (9.3.0-5) ...
Preparing to unpack .../04-libgcc-9-dev_9.3.0-6_arm64.deb ...
Unpacking libgcc-9-dev:arm64 (9.3.0-6) over (9.3.0-5) ...
Preparing to unpack .../05-cpp-9_9.3.0-6_arm64.deb ...
Unpacking cpp-9 (9.3.0-6) over (9.3.0-5) ...
Preparing to unpack .../06-gcc-9-base_9.3.0-6_arm64.deb ...
Unpacking gcc-9-base:arm64 (9.3.0-6) over (9.3.0-5) ...
Preparing to unpack .../07-libibus-1.0-5_1.5.22-2_arm64.deb ...
Unpacking libibus-1.0-5:arm64 (1.5.22-2) over (1.5.22-1) ...
Preparing to unpack .../08-gir1.2-ibus-1.0_1.5.22-2_arm64.deb ...
Unpacking gir1.2-ibus-1.0:arm64 (1.5.22-2) over (1.5.22-1) ...
Preparing to unpack .../09-gnome-session-bin_3.36.0-2_arm64.deb ...
Unpacking gnome-session-bin (3.36.0-2) over (3.36.0-1) ...
Preparing to unpack .../10-gnome-session_3.36.0-2_all.deb ...
Unpacking gnome-session (3.36.0-2) over (3.36.0-1) ...
Preparing to unpack .../11-gnome-session-common_3.36.0-2_all.deb ...
Unpacking gnome-session-common (3.36.0-2) over (3.36.0-1) ...
Preparing to unpack .../12-libcom-err2_1.45.6-1_arm64.deb ...
Unpacking libcom-err2:arm64 (1.45.6-1) over (1.45.5-2) ...
Preparing to unpack .../13-libgtk3-perl_0.037-1_all.deb ...
Unpacking libgtk3-perl (0.037-1) over (0.036-2) ...
Preparing to unpack .../14-libss2_1.45.6-1_arm64.deb ...
Unpacking libss2:arm64 (1.45.6-1) over (1.45.5-2) ...
Preparing to unpack .../15-pci.ids_0.0~2020.03.20-1_all.deb ...
Unpacking pci.ids (0.0~2020.03.20-1) over (0.0~2020.02.22-1) ...
Preparing to unpack .../16-sudo_1.8.31p1-1_arm64.deb ...
Unpacking sudo (1.8.31p1-1) over (1.8.31-1) ...
Preparing to unpack .../17-pinephone-modem-scripts_0.4_arm64.deb ...
Unpacking pinephone-modem-scripts (0.4) over (0.3) ...
Preparing to unpack .../18-pinephone-base_0.2.4_arm64.deb ...
Unpacking pinephone-base (0.2.4) over (0.2.3) ...
Preparing to unpack .../19-pinephone-multimedia_0.2.4_arm64.deb ...
Unpacking pinephone-multimedia (0.2.4) over (0.2.3) ...
Preparing to unpack .../20-pinephone-tweaks_0.4_arm64.deb ...
Unpacking pinephone-tweaks (0.4) over (0.3) ...
Setting up pci.ids (0.0~2020.03.20-1) ...
Setting up pinephone-multimedia (0.2.4) ...
Setting up libibus-1.0-5:arm64 (1.5.22-2) ...
Setting up gnome-session-bin (3.36.0-2) ...
Setting up libcom-err2:arm64 (1.45.6-1) ...
Setting up libgomp1:arm64 (10-20200321-1) ...
Setting up pinephone-modem-scripts (0.4) ...
Setting up libatomic1:arm64 (10-20200321-1) ...
Setting up libss2:arm64 (1.45.6-1) ...
Setting up sudo (1.8.31p1-1) ...
Setting up logsave (1.45.6-1) ...
Setting up libubsan1:arm64 (10-20200321-1) ...
Setting up gnome-session-common (3.36.0-2) ...
Setting up gir1.2-ibus-1.0:arm64 (1.5.22-2) ...
Setting up libcc1-0:arm64 (10-20200321-1) ...
Setting up liblsan0:arm64 (10-20200321-1) ...
Setting up libgtk3-perl (0.037-1) ...
Setting up libitm1:arm64 (10-20200321-1) ...
Setting up libpython3-stdlib:arm64 (3.8.2-2) ...
Setting up gcc-9-base:arm64 (9.3.0-6) ...
Setting up libtsan0:arm64 (10-20200321-1) ...
Setting up pinephone-tweaks (0.4) ...
Creating boot script...
Image Name:   pinephone
Created:      Sun Mar 22 10:57:41 2020
Image Type:   AArch64 Linux Script (uncompressed)
Data Size:    811 Bytes = 0.79 KiB = 0.00 MiB
Load Address: 00000000
Entry Point:  00000000
Contents:
   Image 0: 803 Bytes = 0.78 KiB = 0.00 MiB
Setting up e2fsprogs (1.45.6-1) ...
Installing new version of config file /etc/mke2fs.conf ...
update-initramfs: deferring update (trigger activated)
.log   logapt.log (Size: 328.06 KB / Downloads: 176)
debian+phosh running on PinePhone - by a-wai - 02-04-2020, 01:20 PM
RE: debian+phosh running on PinePhone - by a-wai - 02-06-2020, 05:22 AM
RE: debian+phosh running on PinePhone - by Leiaz - 02-08-2020, 07:08 AM
RE: debian+phosh running on PinePhone - by a-wai - 02-09-2020, 04:09 AM
RE: debian+phosh running on PinePhone - by Leiaz - 02-09-2020, 12:40 PM
RE: debian+phosh running on PinePhone - by rico - 02-08-2020, 08:27 AM
RE: debian+phosh running on PinePhone - by Leiaz - 02-08-2020, 04:16 PM
RE: debian+phosh running on PinePhone - by rico - 02-08-2020, 08:35 PM
RE: debian+phosh running on PinePhone - by tyha - 02-08-2020, 09:51 PM
RE: debian+phosh running on PinePhone - by nikola - 02-09-2020, 01:58 AM
RE: debian+phosh running on PinePhone - by njha - 02-10-2020, 05:08 PM
RE: debian+phosh running on PinePhone - by bcnaz - 02-09-2020, 05:17 PM
RE: debian+phosh running on PinePhone - by a-wai - 02-17-2020, 05:32 PM
RE: debian+phosh running on PinePhone - by a-wai - 02-19-2020, 02:29 AM
RE: debian+phosh running on PinePhone - by j23 - 02-21-2020, 01:52 PM
RE: debian+phosh running on PinePhone - by a-wai - 02-22-2020, 10:04 AM
RE: debian+phosh running on PinePhone - by j23 - 02-24-2020, 11:19 AM
RE: debian+phosh running on PinePhone - by a-wai - 02-23-2020, 11:46 AM
RE: debian+phosh running on PinePhone - by a-wai - 02-24-2020, 09:44 AM
RE: debian+phosh running on PinePhone - by Luke - 02-24-2020, 06:40 PM
RE: debian+phosh running on PinePhone - by a-wai - 02-25-2020, 03:02 AM
RE: debian+phosh running on PinePhone - by a-wai - 02-25-2020, 02:22 PM
RE: debian+phosh running on PinePhone - by rico - 02-26-2020, 02:54 AM
RE: debian+phosh running on PinePhone - by a-wai - 02-26-2020, 09:05 AM
RE: debian+phosh running on PinePhone - by rico - 02-25-2020, 07:55 AM
RE: debian+phosh running on PinePhone - by rico - 02-26-2020, 09:52 AM
RE: debian+phosh running on PinePhone - by a-wai - 02-26-2020, 01:56 PM
RE: debian+phosh running on PinePhone - by nas - 02-26-2020, 01:24 PM
RE: debian+phosh running on PinePhone - by a-wai - 02-26-2020, 02:44 PM
RE: debian+phosh running on PinePhone - by a-wai - 02-27-2020, 12:25 PM
RE: debian+phosh running on PinePhone - by a-wai - 02-27-2020, 01:23 PM
RE: debian+phosh running on PinePhone - by nas - 02-27-2020, 02:19 PM
debian+phosh running on PinePhone - by ivanB1975 - 02-28-2020, 03:09 AM
RE: debian+phosh running on PinePhone - by murak - 02-28-2020, 05:27 AM
RE: debian+phosh running on PinePhone - by a-wai - 02-28-2020, 05:56 PM
RE: debian+phosh running on PinePhone - by a-wai - 02-29-2020, 06:42 AM
RE: debian+phosh running on PinePhone - by nas - 02-29-2020, 12:44 PM
RE: debian+phosh running on PinePhone - by buffer - 03-01-2020, 04:49 AM
RE: debian+phosh running on PinePhone - by rico - 03-01-2020, 12:27 PM
RE: debian+phosh running on PinePhone - by buffer - 03-01-2020, 12:46 PM
RE: debian+phosh running on PinePhone - by a-wai - 03-01-2020, 02:25 PM
RE: debian+phosh running on PinePhone - by nas - 03-01-2020, 07:28 PM
RE: debian+phosh running on PinePhone - by sundog - 03-01-2020, 04:34 PM
RE: debian+phosh running on PinePhone - by nas - 03-03-2020, 01:14 PM
RE: debian+phosh running on PinePhone - by a-wai - 03-02-2020, 04:41 AM
RE: debian+phosh running on PinePhone - by a-wai - 03-02-2020, 10:44 AM
RE: debian+phosh running on PinePhone - by buffer - 03-02-2020, 10:12 PM
RE: debian+phosh running on PinePhone - by rico - 03-03-2020, 08:12 AM
RE: debian+phosh running on PinePhone - by a-wai - 03-03-2020, 05:17 PM
RE: debian+phosh running on PinePhone - by nas - 03-03-2020, 07:16 PM
RE: debian+phosh running on PinePhone - by buffer - 03-03-2020, 06:56 PM
RE: debian+phosh running on PinePhone - by a-wai - 03-04-2020, 03:28 AM
RE: debian+phosh running on PinePhone - by nas - 03-04-2020, 10:11 AM
RE: debian+phosh running on PinePhone - by a-wai - 03-04-2020, 05:04 PM
RE: debian+phosh running on PinePhone - by bcnaz - 03-09-2020, 01:16 AM
RE: debian+phosh running on PinePhone - by a-wai - 03-04-2020, 08:10 AM
RE: debian+phosh running on PinePhone - by rico - 03-04-2020, 10:06 PM
RE: debian+phosh running on PinePhone - by a-wai - 03-05-2020, 08:27 AM
RE: debian+phosh running on PinePhone - by buffer - 03-08-2020, 11:02 PM
RE: debian+phosh running on PinePhone - by RMJ250 - 03-09-2020, 02:39 AM
RE: debian+phosh running on PinePhone - by saba - 03-09-2020, 04:43 AM
RE: debian+phosh running on PinePhone - by RMJ250 - 03-09-2020, 08:16 PM
RE: debian+phosh running on PinePhone - by rmgr - 03-09-2020, 11:57 PM
RE: debian+phosh running on PinePhone - by RMJ250 - 03-10-2020, 02:21 AM
RE: debian+phosh running on PinePhone - by a-wai - 03-09-2020, 09:54 AM
RE: debian+phosh running on PinePhone - by Quaa - 03-09-2020, 02:02 PM
RE: debian+phosh running on PinePhone - by a-wai - 03-10-2020, 02:57 AM
RE: debian+phosh running on PinePhone - by RMJ250 - 03-10-2020, 04:01 AM
RE: debian+phosh running on PinePhone - by clover - 03-10-2020, 12:39 PM
RE: debian+phosh running on PinePhone - by murak - 03-10-2020, 05:51 AM
RE: debian+phosh running on PinePhone - by a-wai - 03-10-2020, 08:53 AM
RE: debian+phosh running on PinePhone - by a-wai - 03-11-2020, 03:19 AM
RE: debian+phosh running on PinePhone - by clover - 03-11-2020, 01:22 PM
RE: debian+phosh running on PinePhone - by bcnaz - 03-11-2020, 03:39 PM
RE: debian+phosh running on PinePhone - by a-wai - 03-11-2020, 03:53 PM
RE: debian+phosh running on PinePhone - by bcnaz - 03-11-2020, 03:58 PM
RE: debian+phosh running on PinePhone - by rubenr - 03-11-2020, 07:51 PM
RE: debian+phosh running on PinePhone - by a-wai - 03-12-2020, 03:43 AM
RE: debian+phosh running on PinePhone - by murak - 03-12-2020, 05:02 AM
RE: debian+phosh running on PinePhone - by murak - 03-12-2020, 07:58 AM
RE: debian+phosh running on PinePhone - by saba - 03-12-2020, 08:47 AM
RE: debian+phosh running on PinePhone - by bcnaz - 03-12-2020, 03:07 PM
RE: debian+phosh running on PinePhone - by bcnaz - 03-13-2020, 07:34 PM
RE: debian+phosh running on PinePhone - by rico - 03-12-2020, 05:53 PM
RE: debian+phosh running on PinePhone - by bcnaz - 03-12-2020, 06:04 PM
RE: debian+phosh running on PinePhone - by rico - 03-13-2020, 01:19 AM
RE: debian+phosh running on PinePhone - by bcnaz - 03-13-2020, 04:55 AM
RE: debian+phosh running on PinePhone - by murak - 03-13-2020, 04:48 AM
RE: debian+phosh running on PinePhone - by a-wai - 03-13-2020, 05:51 AM
RE: debian+phosh running on PinePhone - by a-wai - 03-13-2020, 07:44 PM
RE: debian+phosh running on PinePhone - by rico - 03-13-2020, 07:50 PM
RE: debian+phosh running on PinePhone - by a-wai - 03-13-2020, 09:26 PM
RE: debian+phosh running on PinePhone - by bcnaz - 03-13-2020, 09:57 PM
RE: debian+phosh running on PinePhone - by rico - 03-14-2020, 01:09 PM
RE: debian+phosh running on PinePhone - by bcnaz - 03-14-2020, 04:58 PM
RE: debian+phosh running on PinePhone - by rico - 03-14-2020, 08:01 PM
RE: debian+phosh running on PinePhone - by a-wai - 03-15-2020, 01:31 PM
RE: debian+phosh running on PinePhone - by bcnaz - 03-15-2020, 06:11 PM
RE: debian+phosh running on PinePhone - by rico - 03-15-2020, 08:47 PM
RE: debian+phosh running on PinePhone - by rmgr - 03-15-2020, 09:27 PM
RE: debian+phosh running on PinePhone - by RMJ250 - 03-15-2020, 09:28 PM
RE: debian+phosh running on PinePhone - by rico - 03-15-2020, 11:41 PM
RE: debian+phosh running on PinePhone - by a-wai - 03-16-2020, 03:25 AM
RE: debian+phosh running on PinePhone - by rmgr - 03-17-2020, 01:04 AM
RE: debian+phosh running on PinePhone - by Luke - 03-16-2020, 08:19 AM
RE: debian+phosh running on PinePhone - by rico - 03-16-2020, 11:19 AM
RE: debian+phosh running on PinePhone - by Luke - 03-16-2020, 11:26 AM
RE: debian+phosh running on PinePhone - by bcnaz - 03-16-2020, 04:47 PM
RE: debian+phosh running on PinePhone - by a-wai - 03-16-2020, 06:02 PM
RE: debian+phosh running on PinePhone - by rico - 03-17-2020, 12:16 PM
RE: debian+phosh running on PinePhone - by Luke - 03-17-2020, 01:24 PM
RE: debian+phosh running on PinePhone - by bcnaz - 03-17-2020, 04:30 PM
RE: debian+phosh running on PinePhone - by buffer - 03-18-2020, 12:54 AM
RE: debian+phosh running on PinePhone - by a-wai - 03-18-2020, 03:29 AM
RE: debian+phosh running on PinePhone - by buffer - 03-18-2020, 03:10 PM
RE: debian+phosh running on PinePhone - by bcnaz - 03-18-2020, 05:29 PM
RE: debian+phosh running on PinePhone - by a-wai - 03-19-2020, 03:07 AM
RE: debian+phosh running on PinePhone - by bcnaz - 03-19-2020, 03:40 AM
RE: debian+phosh running on PinePhone - by bcnaz - 03-19-2020, 03:25 PM
RE: debian+phosh running on PinePhone - by nas - 03-18-2020, 09:14 PM
RE: debian+phosh running on PinePhone - by rico - 03-19-2020, 03:14 AM
RE: debian+phosh running on PinePhone - by rico - 03-19-2020, 05:25 AM
RE: debian+phosh running on PinePhone - by a-wai - 03-19-2020, 07:16 AM
RE: debian+phosh running on PinePhone - by a-wai - 03-19-2020, 12:15 PM
RE: debian+phosh running on PinePhone - by rico - 03-19-2020, 12:35 PM
RE: debian+phosh running on PinePhone - by vinnie - 03-19-2020, 05:40 AM
RE: debian+phosh running on PinePhone - by rico - 03-19-2020, 06:06 AM
RE: debian+phosh running on PinePhone - by vinnie - 03-19-2020, 07:42 AM
RE: debian+phosh running on PinePhone - by buffer - 03-19-2020, 11:13 PM
RE: debian+phosh running on PinePhone - by rico - 03-20-2020, 08:02 AM
RE: debian+phosh running on PinePhone - by bcnaz - 03-20-2020, 03:57 PM
RE: debian+phosh running on PinePhone - by bcnaz - 03-20-2020, 04:52 PM
RE: debian+phosh running on PinePhone - by bcnaz - 03-20-2020, 05:27 PM
RE: debian+phosh running on PinePhone - by buffer - 03-21-2020, 02:02 AM
RE: debian+phosh running on PinePhone - by bcnaz - 03-20-2020, 06:33 PM
RE: debian+phosh running on PinePhone - by rico - 03-20-2020, 07:33 PM
RE: debian+phosh running on PinePhone - by a-wai - 03-21-2020, 08:54 AM
RE: debian+phosh running on PinePhone - by buffer - 03-21-2020, 02:30 PM
RE: debian+phosh running on PinePhone - by bcnaz - 03-21-2020, 05:46 PM
RE: debian+phosh running on PinePhone - by rico - 03-22-2020, 12:29 AM
RE: debian+phosh running on PinePhone - by bcnaz - 03-22-2020, 02:13 AM
RE: debian+phosh running on PinePhone - by a-wai - 03-22-2020, 06:06 AM
RE: debian+phosh running on PinePhone - by buskmann - 03-22-2020, 07:11 AM
RE: debian+phosh running on PinePhone - by a-wai - 03-22-2020, 09:30 AM
RE: debian+phosh running on PinePhone - by bcnaz - 03-22-2020, 07:45 PM
RE: debian+phosh running on PinePhone - by rico - 03-23-2020, 05:14 AM
RE: debian+phosh running on PinePhone - by rico - 03-23-2020, 09:08 AM
RE: debian+phosh running on PinePhone - by Luke - 03-23-2020, 10:04 AM
RE: debian+phosh running on PinePhone - by a-wai - 03-23-2020, 04:58 PM
RE: debian+phosh running on PinePhone - by bcnaz - 03-23-2020, 05:59 PM
RE: debian+phosh running on PinePhone - by Luke - 03-23-2020, 06:42 PM
RE: debian+phosh running on PinePhone - by bcnaz - 03-23-2020, 07:26 PM
RE: debian+phosh running on PinePhone - by buffer - 03-27-2020, 05:56 PM
RE: debian+phosh running on PinePhone - by bcnaz - 03-28-2020, 02:49 AM
RE: debian+phosh running on PinePhone - by rico - 03-23-2020, 09:50 PM
RE: debian+phosh running on PinePhone - by bcnaz - 03-24-2020, 01:44 AM
RE: debian+phosh running on PinePhone - by a-wai - 03-24-2020, 08:25 AM
RE: debian+phosh running on PinePhone - by Luke - 03-24-2020, 11:08 AM
RE: debian+phosh running on PinePhone - by a-wai - 03-24-2020, 11:25 AM
RE: debian+phosh running on PinePhone - by rico - 03-24-2020, 01:04 PM
RE: debian+phosh running on PinePhone - by bcnaz - 03-24-2020, 01:38 PM
RE: debian+phosh running on PinePhone - by a-wai - 03-24-2020, 04:17 PM
RE: debian+phosh running on PinePhone - by Luke - 03-24-2020, 06:26 PM
RE: debian+phosh running on PinePhone - by a-wai - 03-25-2020, 07:21 AM
RE: debian+phosh running on PinePhone - by a-wai - 03-26-2020, 09:36 AM
RE: debian+phosh running on PinePhone - by RMJ250 - 03-26-2020, 10:10 PM
RE: debian+phosh running on PinePhone - by fpb4 - 03-27-2020, 04:16 AM
RE: debian+phosh running on PinePhone - by a-wai - 03-27-2020, 11:04 AM
RE: debian+phosh running on PinePhone - by bcnaz - 03-27-2020, 03:44 PM
RE: debian+phosh running on PinePhone - by buffer - 03-28-2020, 10:52 AM
RE: debian+phosh running on PinePhone - by bcnaz - 03-29-2020, 08:27 PM
RE: debian+phosh running on PinePhone - by buffer - 03-28-2020, 11:40 PM
RE: debian+phosh running on PinePhone - by janw - 03-29-2020, 05:48 AM
RE: debian+phosh running on PinePhone - by a-wai - 03-29-2020, 08:34 AM
RE: debian+phosh running on PinePhone - by janw - 03-29-2020, 10:54 AM
RE: debian+phosh running on PinePhone - by a-wai - 03-29-2020, 09:49 AM
RE: debian+phosh running on PinePhone - by fpb4 - 03-29-2020, 11:34 AM
RE: debian+phosh running on PinePhone - by a-wai - 03-29-2020, 12:15 PM
RE: debian+phosh running on PinePhone - by fpb4 - 03-29-2020, 03:05 PM
RE: debian+phosh running on PinePhone - by nas - 03-29-2020, 12:38 PM
RE: debian+phosh running on PinePhone - by murak - 03-29-2020, 01:43 PM
RE: debian+phosh running on PinePhone - by bcnaz - 03-29-2020, 10:31 PM
RE: debian+phosh running on PinePhone - by bcnaz - 03-30-2020, 12:35 AM
RE: debian+phosh running on PinePhone - by RMJ250 - 03-30-2020, 03:10 AM
debian+phosh running on PinePhone - by ivanB1975 - 03-30-2020, 05:29 AM
RE: debian+phosh running on PinePhone - by Luke - 03-30-2020, 05:33 AM
debian+phosh running on PinePhone - by ivanB1975 - 03-30-2020, 05:40 AM
RE: debian+phosh running on PinePhone - by a-wai - 03-30-2020, 07:04 AM
debian+phosh running on PinePhone - by ivanB1975 - 03-30-2020, 07:07 AM
RE: debian+phosh running on PinePhone - by a-wai - 03-30-2020, 10:42 AM
debian+phosh running on PinePhone - by ivanB1975 - 03-30-2020, 04:04 PM
RE: debian+phosh running on PinePhone - by a-wai - 03-30-2020, 06:01 PM
RE: debian+phosh running on PinePhone - by rico - 03-30-2020, 11:03 PM
RE: debian+phosh running on PinePhone - by bcnaz - 03-30-2020, 05:21 PM
RE: debian+phosh running on PinePhone - by rico - 03-31-2020, 03:09 AM
RE: debian+phosh running on PinePhone - by a-wai - 03-31-2020, 07:09 AM
RE: debian+phosh running on PinePhone - by rico - 03-31-2020, 08:57 AM
RE: debian+phosh running on PinePhone - by bcnaz - 03-31-2020, 03:59 AM
RE: debian+phosh running on PinePhone - by bcnaz - 03-31-2020, 01:43 PM
RE: debian+phosh running on PinePhone - by buffer - 03-31-2020, 09:08 PM
RE: debian+phosh running on PinePhone - by rico - 03-31-2020, 09:34 PM
RE: debian+phosh running on PinePhone - by buffer - 04-01-2020, 09:35 AM
RE: debian+phosh running on PinePhone - by a-wai - 04-01-2020, 01:05 PM
RE: debian+phosh running on PinePhone - by a-wai - 04-01-2020, 01:53 AM
RE: debian+phosh running on PinePhone - by Lanza - 04-01-2020, 08:51 AM
RE: debian+phosh running on PinePhone - by Lanza - 04-01-2020, 09:32 AM
RE: debian+phosh running on PinePhone - by janw - 04-01-2020, 02:18 PM
RE: debian+phosh running on PinePhone - by bcnaz - 04-01-2020, 12:15 PM
RE: debian+phosh running on PinePhone - by bcnaz - 04-01-2020, 11:55 PM
RE: debian+phosh running on PinePhone - by janw - 04-03-2020, 09:50 PM
RE: debian+phosh running on PinePhone - by a-wai - 04-04-2020, 02:51 AM
RE: debian+phosh running on PinePhone - by a-wai - 04-05-2020, 04:57 AM
RE: debian+phosh running on PinePhone - by bcnaz - 04-05-2020, 12:03 PM
RE: debian+phosh running on PinePhone - by clover - 04-06-2020, 09:49 AM
RE: debian+phosh running on PinePhone - by a-wai - 04-06-2020, 12:12 PM
RE: debian+phosh running on PinePhone - by buffer - 04-06-2020, 06:24 PM
RE: debian+phosh running on PinePhone - by a-wai - 04-07-2020, 01:22 AM
RE: debian+phosh running on PinePhone - by buffer - 04-07-2020, 12:45 PM
RE: debian+phosh running on PinePhone - by buffer - 04-06-2020, 08:22 PM
RE: debian+phosh running on PinePhone - by janw - 04-07-2020, 01:50 PM
RE: debian+phosh running on PinePhone - by a-wai - 04-07-2020, 03:36 PM
RE: debian+phosh running on PinePhone - by buffer - 04-07-2020, 03:38 PM
RE: debian+phosh running on PinePhone - by johns - 04-08-2020, 06:56 AM
RE: debian+phosh running on PinePhone - by a-wai - 04-07-2020, 01:10 PM
RE: debian+phosh running on PinePhone - by buffer - 04-07-2020, 02:08 PM
RE: debian+phosh running on PinePhone - by buffer - 04-07-2020, 02:54 PM
RE: debian+phosh running on PinePhone - by bcnaz - 04-07-2020, 03:41 PM
RE: debian+phosh running on PinePhone - by buffer - 04-07-2020, 04:28 PM
RE: debian+phosh running on PinePhone - by bcnaz - 04-07-2020, 04:34 PM
RE: debian+phosh running on PinePhone - by buffer - 04-07-2020, 04:43 PM
RE: debian+phosh running on PinePhone - by bcnaz - 04-07-2020, 05:00 PM
RE: debian+phosh running on PinePhone - by rico - 04-09-2020, 02:00 AM
RE: debian+phosh running on PinePhone - by nas - 04-10-2020, 04:03 AM
RE: debian+phosh running on PinePhone - by a-wai - 04-10-2020, 04:32 AM
RE: debian+phosh running on PinePhone - by a-wai - 04-10-2020, 06:06 AM
RE: debian+phosh running on PinePhone - by rico - 04-12-2020, 12:32 PM
RE: debian+phosh running on PinePhone - by Boern - 04-13-2020, 12:10 AM
RE: debian+phosh running on PinePhone - by a-wai - 04-13-2020, 07:38 AM
RE: debian+phosh running on PinePhone - by rico - 04-13-2020, 08:15 AM
RE: debian+phosh running on PinePhone - by Luke - 04-13-2020, 09:19 AM
RE: debian+phosh running on PinePhone - by a-wai - 04-13-2020, 10:15 AM
RE: debian+phosh running on PinePhone - by nas - 04-13-2020, 02:07 PM
RE: debian+phosh running on PinePhone - by Boern - 04-13-2020, 03:24 PM
RE: debian+phosh running on PinePhone - by nas - 04-13-2020, 04:13 PM
RE: debian+phosh running on PinePhone - by Luke - 04-13-2020, 04:47 PM
RE: debian+phosh running on PinePhone - by Boern - 04-13-2020, 11:58 PM
RE: debian+phosh running on PinePhone - by nas - 04-14-2020, 08:30 AM
RE: debian+phosh running on PinePhone - by bcnaz - 04-14-2020, 12:49 AM
RE: debian+phosh running on PinePhone - by bcnaz - 04-14-2020, 10:05 AM
RE: debian+phosh running on PinePhone - by Boern - 04-14-2020, 10:18 AM
RE: debian+phosh running on PinePhone - by bcnaz - 04-15-2020, 06:41 PM
RE: debian+phosh running on PinePhone - by a-wai - 04-16-2020, 08:19 AM
RE: debian+phosh running on PinePhone - by janw - 04-16-2020, 09:24 AM
RE: debian+phosh running on PinePhone - by wibble - 08-03-2020, 08:18 AM
RE: debian+phosh running on PinePhone - by nas - 04-14-2020, 03:34 PM
RE: debian+phosh running on PinePhone - by RMJ250 - 04-15-2020, 01:05 AM
RE: debian+phosh running on PinePhone - by bcnaz - 04-15-2020, 08:59 PM
RE: debian+phosh running on PinePhone - by nas - 04-16-2020, 06:46 AM
RE: debian+phosh running on PinePhone - by rico - 04-16-2020, 09:15 AM
RE: debian+phosh running on PinePhone - by rico - 04-16-2020, 10:04 AM
RE: debian+phosh running on PinePhone - by bcnaz - 04-17-2020, 08:55 PM
RE: debian+phosh running on PinePhone - by Boern - 04-18-2020, 10:33 AM
RE: debian+phosh running on PinePhone - by rico - 04-18-2020, 10:41 AM
RE: debian+phosh running on PinePhone - by a-wai - 04-19-2020, 03:36 AM
RE: debian+phosh running on PinePhone - by wibble - 04-19-2020, 05:19 AM
RE: debian+phosh running on PinePhone - by a-wai - 04-19-2020, 06:22 AM
RE: debian+phosh running on PinePhone - by wibble - 04-19-2020, 07:38 AM
RE: debian+phosh running on PinePhone - by a-wai - 04-20-2020, 11:05 AM
RE: debian+phosh running on PinePhone - by pjsf - 04-21-2020, 12:51 AM
RE: debian+phosh running on PinePhone - by a-wai - 04-21-2020, 01:53 AM
RE: debian+phosh running on PinePhone - by pjsf - 04-21-2020, 03:50 PM
RE: debian+phosh running on PinePhone - by bcnaz - 04-21-2020, 03:05 AM
RE: debian+phosh running on PinePhone - by Luke - 04-21-2020, 04:06 AM
RE: debian+phosh running on PinePhone - by wibble - 04-21-2020, 09:58 AM
RE: debian+phosh running on PinePhone - by a-wai - 04-21-2020, 10:23 AM
RE: debian+phosh running on PinePhone - by Luke - 04-21-2020, 03:20 PM
RE: debian+phosh running on PinePhone - by a-wai - 04-21-2020, 06:14 PM
RE: debian+phosh running on PinePhone - by pjsf - 04-21-2020, 06:30 PM
RE: debian+phosh running on PinePhone - by devrtz - 04-22-2020, 03:18 PM
RE: debian+phosh running on PinePhone - by Boern - 04-22-2020, 04:10 AM
RE: debian+phosh running on PinePhone - by dodoeg - 04-22-2020, 06:12 AM
RE: debian+phosh running on PinePhone - by a-wai - 04-23-2020, 05:21 AM
RE: debian+phosh running on PinePhone - by Boern - 04-24-2020, 08:20 AM
RE: debian+phosh running on PinePhone - by a-wai - 04-24-2020, 12:58 PM
RE: debian+phosh running on PinePhone - by Boern - 04-25-2020, 04:53 AM
RE: debian+phosh running on PinePhone - by rico - 04-25-2020, 08:42 PM
RE: debian+phosh running on PinePhone - by Boern - 04-26-2020, 02:49 AM
RE: debian+phosh running on PinePhone - by a-wai - 04-26-2020, 03:16 AM
RE: debian+phosh running on PinePhone - by a-wai - 04-27-2020, 11:23 AM
RE: debian+phosh running on PinePhone - by Boern - 04-28-2020, 02:04 AM
RE: debian+phosh running on PinePhone - by a-wai - 04-28-2020, 08:29 AM
RE: debian+phosh running on PinePhone - by rico - 04-28-2020, 12:01 PM
RE: debian+phosh running on PinePhone - by rico - 04-30-2020, 11:39 PM
RE: debian+phosh running on PinePhone - by rico - 05-02-2020, 07:33 PM
RE: debian+phosh running on PinePhone - by ieure - 04-28-2020, 09:44 PM
RE: debian+phosh running on PinePhone - by Boern - 04-30-2020, 03:35 PM
RE: debian+phosh running on PinePhone - by a-wai - 05-01-2020, 05:41 AM
RE: debian+phosh running on PinePhone - by Luke - 05-01-2020, 05:41 AM
RE: debian+phosh running on PinePhone - by Luke - 05-01-2020, 06:21 AM
RE: debian+phosh running on PinePhone - by Boern - 05-01-2020, 06:41 AM
RE: debian+phosh running on PinePhone - by Luke - 05-01-2020, 09:07 AM
RE: debian+phosh running on PinePhone - by spaetz - 05-03-2020, 01:30 PM
Pass code / login screen - by Juergen - 05-04-2020, 10:59 PM
RE: Pass code / login screen - by dukla2000 - 05-05-2020, 01:13 AM
RE: Pass code / login screen - by dflag84 - 05-06-2020, 10:47 AM
RE: Pass code / login screen - by chris_02 - 05-06-2020, 02:14 PM
RE: Pass code / login screen - by dukla2000 - 05-31-2020, 05:35 AM
RE: debian+phosh running on PinePhone - by nas - 05-04-2020, 09:52 PM
RE: debian+phosh running on PinePhone - by Luke - 05-04-2020, 09:18 AM
RE: debian+phosh running on PinePhone - by a-wai - 05-05-2020, 04:59 AM
RE: debian+phosh running on PinePhone - by nas - 05-06-2020, 04:53 AM
Convergence - by heng - 05-07-2020, 05:47 AM
RE: debian+phosh running on PinePhone - by a-wai - 05-08-2020, 01:01 AM
RE: debian+phosh running on PinePhone - by Boern - 05-08-2020, 03:45 AM
shutdown - by Juergen - 05-09-2020, 01:51 AM
RE: shutdown - by dukla2000 - 05-09-2020, 03:18 AM
RE: shutdown - by Juergen - 05-19-2020, 10:52 PM
RE: shutdown - by Juergen - 06-14-2020, 10:58 PM
RE: debian+phosh running on PinePhone - by rico - 05-09-2020, 02:13 AM
RE: debian+phosh running on PinePhone - by heng - 05-09-2020, 05:23 AM
RE: debian+phosh running on PinePhone - by rico - 05-09-2020, 11:39 AM
RE: debian+phosh running on PinePhone - by heng - 05-09-2020, 02:11 PM
RE: debian+phosh running on PinePhone - by a-wai - 05-14-2020, 09:47 AM
RE: debian+phosh running on PinePhone - by a-wai - 06-05-2020, 04:59 PM
debian+phosh running on PinePhone - by ivanB1975 - 06-15-2020, 03:44 AM
RE: debian+phosh running on PinePhone - by a-wai - 06-15-2020, 11:55 AM
RE: debian+phosh running on PinePhone - by a-wai - 06-16-2020, 09:29 AM
RE: debian+phosh running on PinePhone - by jjs - 07-05-2020, 06:42 AM
RE: debian+phosh running on PinePhone - by jjs - 07-05-2020, 01:49 PM
RE: debian+phosh running on PinePhone - by klick - 08-03-2020, 11:25 AM
RE: debian+phosh running on PinePhone - by klick - 08-04-2020, 07:38 AM
RE: debian+phosh running on PinePhone - by Kamzzy - 07-09-2020, 07:53 AM
RE: debian+phosh running on PinePhone - by a-wai - 07-09-2020, 08:37 AM
RE: debian+phosh running on PinePhone - by a-wai - 08-03-2020, 05:02 PM
RE: debian+phosh running on PinePhone - by bcnaz - 08-03-2020, 05:39 PM
RE: debian+phosh running on PinePhone - by bcnaz - 08-04-2020, 02:27 PM
RE: debian+phosh running on PinePhone - by klick - 08-04-2020, 03:11 PM
RE: debian+phosh running on PinePhone - by bcnaz - 08-04-2020, 03:28 PM
RE: debian+phosh running on PinePhone - by klick - 08-04-2020, 03:51 PM
RE: debian+phosh running on PinePhone - by bcnaz - 08-04-2020, 04:13 PM
RE: debian+phosh running on PinePhone - by bcnaz - 08-05-2020, 05:42 PM
RE: debian+phosh running on PinePhone - by Cree - 09-01-2020, 10:07 PM
RE: debian+phosh running on PinePhone - by bcnaz - 09-01-2020, 10:00 PM
RE: debian+phosh running on PinePhone - by klick - 09-02-2020, 04:09 PM
RE: debian+phosh running on PinePhone - by bcnaz - 09-02-2020, 04:33 PM
  bookworm vs trixie discussion for mobian in pinephone regular. zetabeta 15 1,864 03-25-2024, 09:07 AM
Last Post: anonymous
  unofficial kali linux for pinephone help needed pinesmell 5 3,587 01-08-2024, 02:50 PM
Last Post: ERPlegend
  Auto start application on Phosh login Zebulon Walton 8 3,304 10-14-2023, 06:29 AM
Last Post: alaraajavamma
  Problem with updates: Repository 'Debian bookworm' changed its 'non-free component' Anna 7 2,274 08-31-2023, 12:38 PM
Last Post: vusra
  Has anyone got briar-desktop running on mobian? vusra 5 2,972 06-19-2023, 03:02 PM
Last Post: vusra
  Using sway along phosh fdlamotte 2 3,285 05-11-2023, 04:24 PM
Last Post: kabouik
  Axolotl on PinePhone / Mobian arno_nuehm 219 164,412 03-26-2023, 01:49 AM
Last Post: shulamy
  PinePhone won't boot after software update jb2000 2 1,311 03-17-2023, 07:26 AM
Wink Pinephone lost graphic during mobian system upgrade cmpin 4 2,159 03-01-2023, 04:45 PM
  Mobian + phosh firefox ublock and other overlays display bugs tuxcall 3 1,760 02-24-2023, 12:11 AM
Last Post: nexion
