External DVD/CD
(02-01-2020, 05:36 PM)MIchael Wrote: zaius, it shows up in the file system just fine. I'm able to look within the AUDIO_TS and VIDEO_TS folders and browse the files. I'm just unable to play it on any of the programs.
pjsf, I thought the same might be an issue. On my larger/older laptop it'll play with the power and the data usb are both put into separate ports. It'll allow me to see the files but not play so I thought it'd be a power issue so I plugged the power usb into a OnePlus brick and no dice. Thought maybe too much power so used a regular power brick and still no-go.
I seriously only have 1 DVD in the entire house and it plays just fine on the BluRay player and I have it on digital. I was just cleaning up a little and pulled the little external out and thought I'd try it. More than anything, I just want to be stumped and figure it out, I enjoy the learning.
If you can see the files it's less likely to be power, in my case if the disk spins up and the directory structure is readable it'll play, which players did you use? sometimes the results can differ in vlc/smplayer/mpv. Also is this the default os? I think all of those work fine for me under the installed debian image.
Another good place to look would be in the log viewer, if you've changed the default user in anyway, you might have some permission errors in  there.
External DVD/CD - by MIchael - 02-01-2020, 02:46 PM
RE: External DVD/CD - by zaius - 02-01-2020, 02:56 PM
RE: External DVD/CD - by xmixahlx - 02-01-2020, 04:54 PM
RE: External DVD/CD - by pjsf - 02-01-2020, 04:56 PM
RE: External DVD/CD - by MIchael - 02-01-2020, 05:36 PM
RE: External DVD/CD - by pjsf - 02-01-2020, 06:06 PM
RE: External DVD/CD - by tllim - 02-02-2020, 12:31 AM
RE: External DVD/CD - by zaius - 02-02-2020, 01:20 PM
RE: External DVD/CD - by jiyong - 02-02-2020, 11:28 AM
RE: External DVD/CD - by pjsf - 02-02-2020, 03:29 PM
RE: External DVD/CD - by MIchael - 02-02-2020, 08:28 PM
RE: External DVD/CD - by ab1jx - 03-04-2021, 05:34 AM
RE: External DVD/CD - by moonwalkers - 03-04-2021, 11:55 AM
RE: External DVD/CD - by ab1jx - 03-04-2021, 01:07 PM
RE: External DVD/CD - by moonwalkers - 03-04-2021, 02:12 PM
RE: External DVD/CD - by Arwen - 03-04-2021, 01:29 PM
RE: External DVD/CD - by ab1jx - 03-04-2021, 02:43 PM
RE: External DVD/CD - by Arwen - 03-05-2021, 09:43 AM
RE: External DVD/CD - by ab1jx - 03-05-2021, 12:04 PM
RE: External DVD/CD - by jiyong - 03-06-2021, 06:00 AM
RE: External DVD/CD - by Arwen - 03-07-2021, 03:01 PM
RE: External DVD/CD - by ab1jx - 03-06-2021, 02:39 PM
RE: External DVD/CD - by ab1jx - 03-07-2021, 03:49 PM
  External monitor on PBP Docking Deck ColoBill 8 6,056 07-31-2024, 12:42 AM
Last Post: elenagilbert
  Issues with External Display After Recent Update reundo 0 2,631 11-18-2021, 06:37 PM
Last Post: reundo
  External Monitor resolution (would like 3840x2160) Phillip Bell 3 4,184 11-17-2021, 10:02 AM
Last Post: Phillip Bell
  External Monitor Recommendations SteveSquatch 1 3,124 02-17-2021, 08:23 AM
Last Post: Arwen
  [split] Change password from external media James Good 11 20,202 07-23-2020, 02:42 PM
  Battery draining with external power while under load? RndmNmbr 17 27,477 06-24-2020, 08:33 PM
Last Post: Syonyk
  Audio jack and external mic? johns 5 10,586 06-10-2020, 12:42 PM
  Always in 'Charging' state, despite being disconnected from external power phuzy 13 20,037 03-26-2020, 04:12 AM
Last Post: agurenko
