Boot from SD and edit screen res on native OS?
I played around with a Mangaro image on SD and all was well.  Tried changing don't size for these poor old eyes and worked.  Also found screen resolution change option.  So... I booted back up on the default internal image and tried the same.  Found both settings.  I set the screen resolution ton1024x768, as was the next visually larger size... Set to system wide and applied then rebooted.  Now, after logging in (with larger fomt on login window).... It boots to a blank screen.  No curaer, not mouse pointer.  It occasionally does a light flash, like it's trying a different resolution, but now change.  I don't have a USB to HDMI adaptor, so am stuck.
I can still boot to Mangaro, however.  can iount the internal drive, and change a config file to get back to theddefault resolution1292x1080?
Thanks in advance
Dennis
Dennis Hoshield
PBPro/ANSI/Manjaro
Boot from SD and edit screen res on native OS? - by dhosh - 01-26-2020, 05:22 PM
  Screen on pinebook stays black but can ssh into machine tuxxpine 0 282 02-23-2024, 04:22 PM
Last Post: tuxxpine
  uboot wont boot to SD card after upgrade jbradley419 7 759 01-19-2024, 02:29 PM
  Video Flashing/adjusting on boot and reboot jbradley419 0 277 01-16-2024, 09:17 AM
Last Post: jbradley419
  Brand new Pinebook Pro doesn't boot after Manjaro update johnboiles 8 2,173 12-15-2023, 02:11 PM
  PBP won't boot after trying to reinstall Manjaro ARM soupgirl 3 657 12-13-2023, 08:17 PM
Last Post: trillobite
  Various freezes during boot & while running several Linux distros - hardware error? donuts 1 569 11-22-2023, 11:47 AM
Last Post: fxc
  Cannot boot to Kali SD card after uboot upgrade jbradley419 4 1,147 09-19-2023, 08:48 AM
Last Post: dachalife
  Does latest Tow-Boot install/work correctly for everyone? tophneal 4 1,828 08-03-2023, 03:30 PM
  Black screen by start up bluedemon382 10 2,932 07-27-2023, 07:49 AM
Last Post: dstallmo
  Boot into NVME drive, no wifi, sound, buttons... PaulQ 0 788 07-13-2023, 01:50 PM
Last Post: PaulQ
