Hey guys, I figure this may be interesting to a few folks so wanted to share.
New to ARM and finding things can be a little trickier than I expected, so when I was setting up a dev environment I wanted to keep things simple and have my code compiled and running in an x64 machine.
So long story short I ran up an always free remote VPS and installed a virtual IDE there I can get at through the browser which will then be accessible across any of the images I boot on the PBP
Quick steps are:
1) Get a free VPS - currently Oracle will give anyone two free linux boxes (plus DB plus other stuff) forever, so I like this option (cloud.oracle.com/free) although I'm sure other options are available.
2) SSH into the remote box and install docker | docker-compose
3) Setup an a record on your domain e.g. vs.*** points to server IP.
4) Here's the docker compose setup I use to run the container with SSL behind an NGINX reverse proxy.
e' voila!
Ideally I was going to run the head melted vs code locally and then just ssh to the server as a remote host, but this currently isn't supported in the hed melted version as the feature is pre-release in VS code.... If anyone knows the workaround to that I'd be interested - as that feels like a cleaner approach!
Quick steps are:
version: '2'
services:
proxy:
image: jwilder/nginx-proxy
container_name: proxy
restart: unless-stopped
labels:
com.github.jrcs.letsencrypt_nginx_proxy_companion.nginx_proxy: "true"
volumes:
- /var/run/docker.sock:/tmp/docker.sock:ro
- certs:/etc/nginx/certs:rw
- vhost.d:/etc/nginx/vhost.d
- html:/usr/share/nginx/html
- ./uploadsize.conf:/etc/nginx/conf.d/uploadsize.conf:ro
ports:
- "80:80"
- "443:443"
networks:
- "default"
- "proxy-tier"
proxy-letsencrypt:
image: jrcs/letsencrypt-nginx-proxy-companion
container_name: letsencrypt
environment:
- NGINX_PROXY_CONTAINER=proxy
volumes:
- /var/run/docker.sock:/var/run/docker.sock:ro
volumes_from:
- "proxy"
depends_on:
- "proxy"
networks:
- "default"
- "proxy-tier"
portainer:
image: portainer/portainer
container_name: portainer
restart: always
environment:
- VIRTUAL_HOST=dock.YOURDOMAIN
- LETSENCRYPT_HOST=dock.YOURDOMAIN
- LETSENCRYPT_EMAIL=hi@YOURDOMAIN
volumes:
- ./portainer/:/data
ports:
- "9000:9000"
code-server:
image: linuxserver/code-server
container_name: code-server
environment:
- PUID=1000
- PGID=1000
- TZ=Australia/Perth
- VIRTUAL_HOST=vs.YOURDOMAIN
- LETSENCRYPT_HOST=vs.YOURDOMAIN
- PASSWORD=YOURPASSWORD
- SUDO_PASSWORD=YOURSUDO
volumes:
- /codeserver/config:/config
ports:
- 8443:8443
volumes:
certs:
vhost.d:
html:
networks:
proxy-tier:
e' voila!
