Devuan Appear to Work
(01-21-2020, 03:11 PM)Zachir999 Wrote: This thread is to post that, in my experience, migrating from the default Debian to Devuan works without issue. I will note that you need to use Devuan ASCII, Beowulf will not let you upgrade properly. I have not extensively gone through to test features, I will post if I run into any issues.
Steps:
1. Install sysv init system
2. Reboot
3. Install WICD (this is temporary, and unnecessary if you know how to use wpa_supplicant)
4. Stop NetworkManager, and start WICD (or wpa and dhcpcd)
5. Purge systemd (this will also remove mate, lightdm, and networkmanager)
6. Change /etc/apt/sources.list from the default debian repo to deb.devuan.org/merged and change Jessie to ASCII
7. Apt update and install devuan keyring, by running 'apt-get --allow-unauthenticated' (there must be a better way to do this, but I don't know it)
8. Apt upgrade
9. Install NetworkManager, lightdm, and whatever de or wm you want
Zachir999,
Interested in trying this Devuan install:
Wondering if there are any additional insights, caveats or suggestions that have raised their little heads since posting this tutorial?  Thanks in advance for your reply!
Devuan Appear to Work - by Zachir999 - 01-21-2020, 03:11 PM
RE: Devuan Appear to Work - by tophneal - 01-21-2020, 03:20 PM
RE: Devuan Appear to Work - by wdt - 01-21-2020, 08:18 PM
RE: Devuan Appear to Work - by PineFan - 01-27-2020, 03:54 PM
RE: Devuan Appear to Work - by Zachir999 - 01-27-2020, 04:39 PM
RE: Devuan Appear to Work - by PineFan - 01-27-2020, 07:58 PM
RE: Devuan Appear to Work - by rleasle - 01-30-2020, 03:28 PM
RE: Devuan Appear to Work - by Zachir999 - 01-30-2020, 03:50 PM
RE: Devuan Appear to Work - by rleasle - 02-01-2020, 11:56 AM
RE: Devuan Appear to Work - by Zachir999 - 02-01-2020, 12:18 PM
RE: Devuan Appear to Work - by rleasle - 02-01-2020, 12:36 PM
RE: Devuan Appear to Work - by Zachir999 - 02-01-2020, 01:17 PM
RE: Devuan Appear to Work - by rleasle - 02-03-2020, 08:40 AM
RE: Devuan Appear to Work - by Zachir999 - 02-03-2020, 06:14 PM
RE: Devuan Appear to Work - by rleasle - 02-04-2020, 08:17 AM
RE: Devuan Appear to Work - by xmixahlx - 02-04-2020, 10:28 AM
RE: Devuan Appear to Work - by Zachir999 - 02-04-2020, 12:55 PM
