Pine A64+ Gigabit issue...
(05-03-2016, 10:31 PM)rhkean Wrote: I installed the Ubuntu image from this link.
apt-get update while plugged into my gigabit switch:  reported 178b/s  (bytes per second)
I ctl-c'd it after 2 1/2 minutes on the 2nd source.
shutdown
plugged into 10mbps switch
ran the entire process under 30 seconds
Thx for ruling out other problem sources. We discussed in the meantime potential origins of this problem (most people with GbE boards aren't affected of) and thought about whether insufficient power supply might be the reason.
The external RTL8211E GbE PHY on the board needs a specific amount of power to work reliable and maybe connecting the board to a 100 Mbits/sec switch avoids the problem. Since still no one took the time to implement voltage readouts the only reliable way to check for a relationship with insufficient DC-IN is to ensure stable DC-IN, eg. powering through the Euler connector:
[Image: Pine64_Powered_through_Euler_Connector.jpg]
Another potential issue could be that there's something wrong with the 2 more cable pairs used for GbE. With Fast Ethernet only 4 wires/traces are used, with GbE all 8 are needed. But I would check for powering issues first.
Pine A64+ Gigabit issue... - by rhkean - 05-02-2016, 07:29 AM
RE: Pine A64+ Gigabit issue... - by rahlquist - 05-02-2016, 09:01 AM
RE: Pine A64+ Gigabit issue... - by rhkean - 05-02-2016, 09:12 AM
RE: Pine A64+ Gigabit issue... - by tkaiser - 05-02-2016, 09:25 AM
RE: Pine A64+ Gigabit issue... - by rhkean - 05-02-2016, 10:02 PM
RE: Pine A64+ Gigabit issue... - by tkaiser - 05-02-2016, 11:57 PM
RE: Pine A64+ Gigabit issue... - by rhkean - 05-03-2016, 10:31 PM
RE: Pine A64+ Gigabit issue... - by tkaiser - 05-04-2016, 01:46 AM
RE: Pine A64+ Gigabit issue... - by rahlquist - 05-02-2016, 09:22 AM
RE: Pine A64+ Gigabit issue... - by rhkean - 05-03-2016, 06:56 AM
RE: Pine A64+ Gigabit issue... - by tkaiser - 05-03-2016, 07:15 AM
RE: Pine A64+ Gigabit issue... - by tkaiser - 05-04-2016, 03:01 AM
RE: Pine A64+ Gigabit issue... - by rhkean - 05-04-2016, 06:38 AM
RE: Pine A64+ Gigabit issue... - by tkaiser - 05-04-2016, 07:00 AM
Pine A64+ Gigabit issue... - by Faye - 05-04-2016, 10:18 AM
RE: Pine A64+ Gigabit issue... - by tkaiser - 05-04-2016, 10:46 AM
Pine A64+ Gigabit issue... - by Faye - 05-04-2016, 06:32 PM
RE: Pine A64+ Gigabit issue... - by rahlquist - 05-04-2016, 08:25 PM
RE: Pine A64+ Gigabit issue... - by rhkean - 05-04-2016, 09:13 PM
RE: Pine A64+ Gigabit issue... - by rahlquist - 05-05-2016, 06:33 AM
RE: Pine A64+ Gigabit issue... - by rhkean - 05-05-2016, 07:25 AM
RE: Pine A64+ Gigabit issue... - by tkaiser - 05-05-2016, 07:33 AM
RE: Pine A64+ Gigabit issue... - by rhkean - 05-05-2016, 01:17 PM
RE: Pine A64+ Gigabit issue... - by frewind - 05-05-2016, 04:29 PM
RE: Pine A64+ Gigabit issue... - by frewind - 05-05-2016, 04:30 PM
RE: Pine A64+ Gigabit issue... - by frewind - 05-05-2016, 04:54 PM
RE: Pine A64+ Gigabit issue... - by amc2012 - 06-10-2016, 10:01 PM
RE: Pine A64+ Gigabit issue... - by waldo - 07-13-2016, 02:13 PM
RE: Pine A64+ Gigabit issue... - by rhkean - 07-13-2016, 03:11 PM
RE: Pine A64+ Gigabit issue... - by waldo - 07-13-2016, 06:51 PM
RE: Pine A64+ Gigabit issue... - by amc2012 - 07-14-2016, 10:57 AM
RE: Pine A64+ Gigabit issue... - by waldo - 07-14-2016, 03:02 PM
RE: Pine A64+ Gigabit issue... - by niall - 07-17-2016, 07:32 AM
  Pine A64+ mainline mipi-dsi Learnincurve 3 10,096 01-12-2021, 07:36 AM
Last Post: Learnincurve
  DietPi OS for PINE A64 MichaIng 0 12,477 12-15-2020, 06:11 AM
Last Post: MichaIng
  Fedora 32/CentOS 8 Pine A64+ Images wideawake 2 8,638 10-02-2020, 11:38 AM
Last Post: mathiraj
  LibreELEC(KODI) for Pine A64 (+) pineadmin 6 20,622 05-02-2020, 10:29 AM
Last Post: aaronmarsh632
  Lakka-nightlies for Pine A64 (and H64) roel 11 30,849 04-23-2020, 12:55 AM
Last Post: roel
  Read DHT22 on Pine A64 ayufan 3 9,844 01-19-2020, 02:51 PM
Last Post: {-DesT-}
  Centos 7 for Pine A64 Luke 2 8,805 05-28-2019, 12:18 AM
Last Post: pineadmin
  NEMS Linux for Pine A64 (+) Luke 1 7,999 05-09-2019, 05:42 PM
  Pine Board using linux stuck during boot sequence ktaragorn 4 12,505 03-30-2019, 06:48 AM
Last Post: ktaragorn
  motionEyeOS (PINE A64(+)) pineadmin 4 15,616 11-09-2018, 03:25 AM
