Pine A64+ Gigabit issue...
#31
(07-13-2016, 02:13 PM)waldo Wrote: I have 1 Pine64+ 2GB that has this problem. Another one that is working perfectly fine with the same powersupply, SD-card, ethernet cable and switch.
ATM i attached a USB network card as a workaround, its stable, but does only 100mbit...that raspberry feeling ......
Tried another switch, to no avail.
The issue reminds me of my Odroid-c1, I bought it way back when it was just released. Their gigabit port was also flakey. In the end it was fixed via patched to the kernel. Difference is that everyone had the same issue. I have the problem on 1 pine only.
Anyway ....I noticed in the thread that a lot of people have the problem after starting apt-get commands, while monitoring current consumption i saw the current spike well above 1A (idle @ 0.3A), so the load apt-get is generating might indeed cause a power issue.
I'll try powering from the euler connector tomorrow. since IIRC micro-USB connectors are only rated to 1.8A, I'll update later
I had just hypothesized with someone else that it might be a hardware issue and was going to test with another board this week.
thank you
Pine A64+ Gigabit issue... - by rhkean - 05-02-2016, 07:29 AM
RE: Pine A64+ Gigabit issue... - by rahlquist - 05-02-2016, 09:01 AM
RE: Pine A64+ Gigabit issue... - by rhkean - 05-02-2016, 09:12 AM
RE: Pine A64+ Gigabit issue... - by tkaiser - 05-02-2016, 09:25 AM
RE: Pine A64+ Gigabit issue... - by rhkean - 05-02-2016, 10:02 PM
RE: Pine A64+ Gigabit issue... - by tkaiser - 05-02-2016, 11:57 PM
RE: Pine A64+ Gigabit issue... - by rhkean - 05-03-2016, 10:31 PM
RE: Pine A64+ Gigabit issue... - by tkaiser - 05-04-2016, 01:46 AM
RE: Pine A64+ Gigabit issue... - by rahlquist - 05-02-2016, 09:22 AM
RE: Pine A64+ Gigabit issue... - by rhkean - 05-03-2016, 06:56 AM
RE: Pine A64+ Gigabit issue... - by tkaiser - 05-03-2016, 07:15 AM
RE: Pine A64+ Gigabit issue... - by tkaiser - 05-04-2016, 03:01 AM
RE: Pine A64+ Gigabit issue... - by rhkean - 05-04-2016, 06:38 AM
RE: Pine A64+ Gigabit issue... - by tkaiser - 05-04-2016, 07:00 AM
Pine A64+ Gigabit issue... - by Faye - 05-04-2016, 10:18 AM
RE: Pine A64+ Gigabit issue... - by tkaiser - 05-04-2016, 10:46 AM
Pine A64+ Gigabit issue... - by Faye - 05-04-2016, 06:32 PM
RE: Pine A64+ Gigabit issue... - by rahlquist - 05-04-2016, 08:25 PM
RE: Pine A64+ Gigabit issue... - by rhkean - 05-04-2016, 09:13 PM
RE: Pine A64+ Gigabit issue... - by rahlquist - 05-05-2016, 06:33 AM
RE: Pine A64+ Gigabit issue... - by rhkean - 05-05-2016, 07:25 AM
RE: Pine A64+ Gigabit issue... - by tkaiser - 05-05-2016, 07:33 AM
RE: Pine A64+ Gigabit issue... - by rhkean - 05-05-2016, 01:17 PM
RE: Pine A64+ Gigabit issue... - by frewind - 05-05-2016, 04:29 PM
RE: Pine A64+ Gigabit issue... - by frewind - 05-05-2016, 04:30 PM
RE: Pine A64+ Gigabit issue... - by frewind - 05-05-2016, 04:54 PM
RE: Pine A64+ Gigabit issue... - by amc2012 - 06-10-2016, 10:01 PM
RE: Pine A64+ Gigabit issue... - by waldo - 07-13-2016, 02:13 PM
RE: Pine A64+ Gigabit issue... - by rhkean - 07-13-2016, 03:11 PM
RE: Pine A64+ Gigabit issue... - by waldo - 07-13-2016, 06:51 PM
RE: Pine A64+ Gigabit issue... - by amc2012 - 07-14-2016, 10:57 AM
RE: Pine A64+ Gigabit issue... - by waldo - 07-14-2016, 03:02 PM
RE: Pine A64+ Gigabit issue... - by niall - 07-17-2016, 07:32 AM
  Pine A64+ mainline mipi-dsi Learnincurve 3 10,096 01-12-2021, 07:36 AM
Last Post: Learnincurve
  DietPi OS for PINE A64 MichaIng 0 12,477 12-15-2020, 06:11 AM
Last Post: MichaIng
  Fedora 32/CentOS 8 Pine A64+ Images wideawake 2 8,638 10-02-2020, 11:38 AM
Last Post: mathiraj
  LibreELEC(KODI) for Pine A64 (+) pineadmin 6 20,622 05-02-2020, 10:29 AM
Last Post: aaronmarsh632
  Lakka-nightlies for Pine A64 (and H64) roel 11 30,849 04-23-2020, 12:55 AM
Last Post: roel
  Read DHT22 on Pine A64 ayufan 3 9,844 01-19-2020, 02:51 PM
Last Post: {-DesT-}
  Centos 7 for Pine A64 Luke 2 8,805 05-28-2019, 12:18 AM
Last Post: pineadmin
  NEMS Linux for Pine A64 (+) Luke 1 7,999 05-09-2019, 05:42 PM
  Pine Board using linux stuck during boot sequence ktaragorn 4 12,505 03-30-2019, 06:48 AM
Last Post: ktaragorn
  motionEyeOS (PINE A64(+)) pineadmin 4 15,616 11-09-2018, 03:25 AM
