Widevine-flash on Chromium-SD Card
(01-20-2020, 02:05 PM)tophneal Wrote: When using ayufan's Chromium, also check out these scripts: https://github.com/ayufan-rock64/chromiu...es/scripts
Both are accessible through the terminal. One will resize STATE to fill the available space, and the other installs Widevine.
Quote:1. Resize STATE
After installing Chromium OS you should resize STATE partition:
Press: Ctrl+Alt+F2,
Login: chronos/chronos,
Run: sudo rockpro64-resize-statefs.sh, enter password chronos,
Exit and go back to the Chromium OS with Ctrl+Alt+F1.
2. Install Widevine DRM
The build supports Widevine DRM, but does not ship the binary as this is against Google license. You can install it manually, but first follow the resize manual:
Press: Ctrl+Alt+F2,
Run: sudo rockpro64-install-widevine.sh,
Reboot: sudo reboot.
Nice! Of course I didn't know about them. I just used gparted from bionic on the eMMC. I tend to just stick with the familiar. ?
RE: Widevine-flash on Chromium-SD Card - by mamboman777 - 01-20-2020, 03:56 PM
Widevine-flash on Chromium-SD Card - by tophneal - 01-20-2020, 04:00 PM
  How to enable widevine in firefox (PrimeVideo) sirspate 18 33,747 12-01-2023, 06:52 AM
Last Post: Tazdevl
  Tinkering with docker-chromium-armhf to use any armhf program e.g. vncviewer wrzomar 0 2,655 09-30-2020, 02:07 PM
Last Post: wrzomar
  Extracting a copy of SPI NOR flash contents using micro SD card and u-boot hmuller 0 2,722 09-21-2020, 11:24 AM
Last Post: hmuller
  Program SPI NOR Flash on Pinebook Pro with u-boot on micro SD Card hmuller 0 3,445 09-21-2020, 10:02 AM
Last Post: hmuller
  In-Circuit Programming of SPI NOR Flash hmuller 13 18,267 09-13-2020, 01:20 PM
Last Post: hmuller
Exclamation Flash dhivael's SPI uboot (risky) clover 51 53,179 06-20-2020, 03:24 PM
Last Post: craftkiller
