How to boot Manjaro from NVME with uboot on eMMC
Edited on 27.03.2020 - due to Manjaro not using boot.scr anymore.
I have taken below steps to achieve booting from NVME. It can be probably mirrored on Debian with some small changes since Manjaro is using boot.scr and Debian extlinux.conf.
First download a package: uboot-pinebookpro-2017.09-2-aarch64.pkg.tar.xz. It has uboot files with @pcm720 patches included. Current Manjaro uboot package does not have nvme support enabled. This is subject to change.
1. Extract the files from the package: idbloader.img, trust.img, uboot.img.
2. Write uboot files (pay attention to your device - it has to be eMMC !!! In my case /dev/mmcblk2):
"dd if=idbloader.img of=/dev/mmcblk2 bs=32k seek=1 conv=fsync"
"dd if=uboot.img of=/dev/mmcblk2 bs=64k seek=128 conv=fsync"
"dd if=trust.img of=/dev/mmcblk2 bs=64k seek=192 conv=fsync"
3. Create partition on your NVME drive to rsync filesystem from eMMC.
4. Mount the partition - lets say in /mnt
5. "cd /mnt"
6. "mkdir dev proc sys mnt"
7. "rsync -aHxv --numeric-ids --progress /* /mnt --exclude=/dev --exclude=/proc --exclude=/sys --exclude=/mnt"
8. chroot to your newly synced partition "chroot /mnt".
9. "cd /boot/extlinux"
9. Edit extlinux.conf and change "root=LABEL=ROOT" to "root=/dev/nvme0n1p1" (if your new partition is first on disk).
10. Exit chroot "exit".
11. On eMMC !!! Rename extlinux directory to something else eg. extlinux.old.
12. Reboot machine - you should boot from NVME.
13. After sucessful reboot check "lsblk" it should be something like:
[root@pbp ~]# lsblk
NAME         MAJ:MIN RM   SIZE RO TYPE MOUNTPOINT
mmcblk2      179:0    0  58.2G  0 disk
└─mmcblk2p1  179:1    0  58.2G  0 part
mmcblk2boot0 179:32   0     4M  1 disk
mmcblk2boot1 179:64   0     4M  1 disk
nvme0n1      259:0    0 894.3G  0 disk
└─nvme0n1p1  259:1    0    20G  0 part /
In case you want to start the system from eMMC just rename extlinux.old to extlinux on eMMC. Opposite to what has been done in step 11.
Enjoy ! Cool
How to boot Manjaro from NVME with uboot on eMMC - by as400 - 01-16-2020, 12:10 PM
  Install Tow-Boot on the SPI Shad0w 14 43,379 11-18-2024, 11:23 AM
Last Post: reukiodo
Question Can't Boot from MicroSD (What Am I Missing) falken 10 14,812 04-28-2023, 04:26 PM
Last Post: pinemouth
  Building PPSSPP with Manjaro AUR LivingLinux 0 4,480 06-11-2022, 05:07 PM
Last Post: LivingLinux
  How to update Manjaro to 20.10 pineitup 8 23,382 07-31-2021, 04:44 AM
Last Post: jiyong
  How to rewrite uboot to emmc pineitup 5 14,793 12-27-2020, 10:35 AM
Last Post: nightranger73
  How to install Ubuntu to eMMC and to install KDE (Neon) Wizzard 66 156,268 12-22-2020, 03:05 PM
Last Post: Wizzard
  Make your own Manjaro image flatulent_piney 0 6,177 11-07-2020, 03:30 AM
Last Post: flatulent_piney
  Manjaro ARM, Cryptomator, and MEGA Sync dp1kinobe 3 12,330 10-24-2020, 06:38 AM
Last Post: pineitup
  Tutorial: Run Debian off NVMe hive 4 11,546 10-19-2020, 10:09 AM
Last Post: hive
  Downgrading packages on Manjaro ARM (on the example of boinc) wrzomar 0 6,143 10-02-2020, 12:20 PM
Last Post: wrzomar
