External DAC
(11-07-2017, 09:48 AM)gkkpch Wrote:
(11-07-2017, 05:23 AM)Luke Wrote:
(11-07-2017, 03:46 AM)joe Wrote:
(11-07-2017, 01:08 AM)gkkpch Wrote:
(11-06-2017, 09:27 PM)joe Wrote: I tested it TOSLINK Coaxial work !
And play music and webradio very small volume
the music i only can use inside image Volumio space to copy paste my flac song , my usb 32bg stick can't find anything  .
other nas to find music not yet to test.
ANALOG(DAC) L,R NOT WORK no sound
ANALOG AUDIO OUT (  Headphone )WORK
Thank , this is good start
Hey Joe,
Go to the playback options and enable Volume Normalization, that should fix your webradio issue.
Working coaxial/ toslink puzzles me, both give no peep here, on the other hand: I have no issues with RCA.
Let's wait for some more feedback. Do you have a chance to test another simple i2s DAC?
@ gkkpch
Thank your support
enable volume normalization fixed it  the sound volume is ok now .
And first i haven't peep the coaxial is work or not Big Grin   because i tested many times RAC not work ( for me ) , so i test other . Sad
Unfortunately i haven't another i2s DAC Undecided
And this pine64 audio board have jumper , do i need to set ?
@ Luke
Have you try the RAC is work ?
Hey Joe, I am away from home until the end of the week - will check on Monday and report back :Smile
But it looks like others have gotten it to work and if Ge says it works then it must work Tongue
@ Joe, check that you have a jumper set to MCLK (not 50M!!) and the other to I2S.
@ Luke: "quick" try with sopine after changing the bootloader and u-boot:
boot from SD is perfect! Everthing works, also with the DAC, all the same as Pine64 plus.
But no luck with eMMC yet, it locates u-boot ok, but can't load it.
Soon as I have some time in between, I'll try a community image first.
When SD is ok, then there can't be much work left for eMMC.
Do you have an LTS or soPine to try a dev image for me next week?
-- Gé --
@ gkkpch
i set it MCLK and I2S to tested sure not work  RAC ( For me ) Sad
Thank you reply me
If I am wrong please correct my content , thank !
1. Use Pine64 Running Ubuntu 16.04 Web Server ( LAMP )
2. Use Pine64 Running Official Android 6  for Media player
3. Use Pine64 Running Volumio Digital Audio Player
External DAC - by kresten_ - 01-03-2016, 11:18 AM
RE: External DAC - by tllim - 01-03-2016, 11:43 AM
RE: External DAC - by stephen fleming - 02-01-2016, 07:10 PM
RE: External DAC - by tllim - 02-01-2016, 08:26 PM
RE: External DAC - by hazerty - 01-03-2016, 12:00 PM
RE: External DAC - by tllim - 01-03-2016, 12:14 PM
RE: External DAC - by StefanB - 01-29-2016, 07:01 PM
RE: External DAC - by tllim - 01-29-2016, 11:09 PM
RE: External DAC - by barichon21 - 01-30-2016, 03:11 AM
RE: External DAC - by tllim - 01-30-2016, 11:31 AM
RE: External DAC - by Danton - 01-30-2016, 03:24 AM
RE: External DAC - by Danton - 02-01-2016, 10:36 AM
RE: External DAC - by taros - 02-01-2016, 10:39 AM
RE: External DAC - by tllim - 02-01-2016, 04:35 PM
RE: External DAC - by DeepBlu - 02-12-2016, 02:21 AM
RE: External DAC - by joe - 02-12-2016, 03:10 AM
RE: External DAC - by tllim - 02-12-2016, 09:56 PM
RE: External DAC - by aphex0 - 02-12-2016, 10:33 PM
RE: External DAC - by joe - 02-20-2016, 02:43 AM
RE: External DAC - by tllim - 02-21-2016, 09:08 PM
External DAC - by Zoidiano0 - 02-20-2016, 05:16 PM
RE: External DAC - by Zoidiano0 - 03-10-2016, 04:56 PM
RE: External DAC - by tllim - 03-10-2016, 05:25 PM
RE: External DAC - by Zoidiano0 - 03-10-2016, 09:22 PM
RE: External DAC - by gbjensen - 03-12-2016, 01:25 PM
RE: External DAC - by Zoidiano0 - 03-12-2016, 01:38 PM
RE: External DAC - by gbjensen - 03-12-2016, 03:56 PM
RE: External DAC - by xaled - 04-12-2016, 06:41 AM
RE: External DAC - by rosswesleyporter - 04-17-2016, 06:48 PM
RE: External DAC - by Zoidiano0 - 04-17-2016, 09:09 PM
RE: External DAC - by kidrock - 05-27-2016, 02:25 PM
RE: External DAC - by tllim - 05-27-2016, 03:02 PM
RE: External DAC - by gbjensen - 06-23-2016, 03:47 AM
RE: External DAC - by joe - 07-31-2016, 04:11 AM
RE: External DAC - by tllim - 08-01-2016, 01:57 PM
RE: External DAC - by CareyCorbin - 09-28-2016, 12:09 PM
RE: External DAC - by tllim - 10-02-2016, 02:20 PM
RE: External DAC - by Danton - 10-05-2016, 12:39 AM
RE: External DAC - by tllim - 10-07-2016, 04:33 PM
RE: External DAC - by entropy attenuation - 10-05-2016, 01:14 AM
RE: External DAC - by mstraa - 10-25-2016, 06:21 AM
RE: External DAC - by tllim - 10-25-2016, 08:07 PM
RE: External DAC - by cr2016 - 11-03-2016, 01:39 AM
RE: External DAC - by cr2016 - 11-04-2016, 04:57 PM
RE: External DAC - by tllim - 11-06-2016, 09:44 PM
RE: External DAC - by gkkpch - 11-05-2016, 12:54 PM
RE: External DAC - by mrv - 11-13-2016, 03:48 PM
RE: External DAC - by Luke - 11-13-2016, 06:40 PM
RE: External DAC - by cr2016 - 11-05-2016, 03:31 PM
RE: External DAC - by gkkpch - 11-05-2016, 06:27 PM
RE: External DAC - by tllim - 11-06-2016, 09:45 PM
RE: External DAC - by cr2016 - 11-09-2016, 04:24 AM
RE: External DAC - by gkkpch - 11-14-2016, 12:34 AM
RE: External DAC - by gkkpch - 11-17-2016, 05:10 PM
RE: External DAC - by Luke - 11-17-2016, 05:19 PM
RE: External DAC - by gkkpch - 11-17-2016, 06:56 PM
RE: External DAC - by mrv - 11-18-2016, 12:51 PM
RE: External DAC - by cr2016 - 11-18-2016, 08:42 PM
RE: External DAC - by mrv - 11-20-2016, 01:22 PM
RE: External DAC - by aarturo - 11-19-2016, 02:29 AM
RE: External DAC - by gkkpch - 11-19-2016, 12:29 PM
RE: External DAC - by aarturo - 11-19-2016, 05:06 PM
RE: External DAC - by gkkpch - 11-20-2016, 07:59 AM
RE: External DAC - by joe - 11-20-2016, 09:45 AM
RE: External DAC - by entropy attenuation - 11-20-2016, 04:27 AM
RE: External DAC - by cr2016 - 11-20-2016, 06:19 PM
RE: External DAC - by mrv - 12-03-2016, 04:51 AM
RE: External DAC - by gkkpch - 12-03-2016, 07:04 AM
RE: External DAC - by gkkpch - 11-21-2016, 02:31 AM
RE: External DAC - by gkkpch - 11-21-2016, 12:27 PM
RE: External DAC - by entropy attenuation - 11-21-2016, 11:52 PM
RE: External DAC - by gkkpch - 11-22-2016, 12:22 AM
RE: External DAC - by Bookingo - 12-02-2016, 12:10 PM
RE: External DAC - by gkkpch - 01-19-2017, 02:31 PM
RE: External DAC - by tllim - 01-20-2017, 08:13 PM
RE: External DAC - by gkkpch - 01-22-2017, 01:05 PM
RE: External DAC - by gkkpch - 01-26-2017, 01:37 AM
RE: External DAC - by Luke - 01-26-2017, 05:49 AM
RE: External DAC - by gkkpch - 01-26-2017, 10:42 AM
RE: External DAC - by Luke - 01-26-2017, 12:12 PM
RE: External DAC - by Myszaks - 01-26-2017, 01:10 PM
RE: External DAC - by gkkpch - 01-26-2017, 01:47 PM
RE: External DAC - by aarturo - 01-28-2017, 12:49 AM
RE: External DAC - by gkkpch - 02-07-2017, 04:59 PM
RE: External DAC - by Luke - 02-07-2017, 05:53 PM
RE: External DAC - by joe - 02-09-2017, 06:52 AM
RE: External DAC - by tllim - 02-12-2017, 10:47 PM
RE: External DAC - by mbt28 - 02-08-2017, 08:04 AM
RE: External DAC - by tllim - 02-12-2017, 10:48 PM
RE: External DAC - by mbt28 - 02-09-2017, 12:07 PM
RE: External DAC - by ealltech - 02-28-2017, 12:48 AM
RE: External DAC - by MarkHaysHarris777 - 02-28-2017, 02:04 AM
RE: External DAC - by pfeerick - 02-28-2017, 04:47 AM
RE: External DAC - by gkkpch - 03-06-2017, 05:14 PM
RE: External DAC - by gkkpch - 03-07-2017, 12:42 PM
RE: External DAC - by cr2016 - 03-09-2017, 04:02 AM
RE: External DAC - by gkkpch - 03-09-2017, 04:15 AM
RE: External DAC - by cr2016 - 03-09-2017, 05:05 AM
RE: External DAC - by joe - 03-19-2017, 04:23 AM
RE: External DAC - by Luke - 03-19-2017, 10:30 AM
RE: External DAC - by Irmscher - 03-23-2017, 01:31 PM
RE: External DAC - by Luke - 03-23-2017, 01:47 PM
RE: External DAC - by stuckinhere - 03-29-2017, 09:01 PM
RE: External DAC - by Luke - 03-30-2017, 06:32 AM
RE: External DAC - by cr2016 - 04-10-2017, 03:34 AM
RE: External DAC - by Luke - 04-10-2017, 05:19 AM
RE: External DAC - by gkkpch - 04-16-2017, 11:20 AM
RE: External DAC - by Luke - 04-18-2017, 06:06 AM
RE: External DAC - by cr2016 - 06-24-2017, 03:20 AM
RE: External DAC - by joe - 06-24-2017, 10:29 AM
RE: External DAC - by gkkpch - 06-25-2017, 11:07 AM
RE: External DAC - by xalius - 06-24-2017, 07:02 AM
RE: External DAC - by xalius - 06-25-2017, 04:25 PM
RE: External DAC - by gkkpch - 06-26-2017, 12:25 AM
RE: External DAC - by cr2016 - 06-26-2017, 04:48 AM
RE: External DAC - by Luke - 07-02-2017, 07:57 AM
RE: External DAC - by gkkpch - 07-02-2017, 10:09 AM
RE: External DAC - by Luke - 07-03-2017, 05:34 AM
RE: External DAC - by james.irwin - 07-09-2017, 04:26 AM
RE: External DAC - by joe - 09-25-2017, 12:07 PM
RE: External DAC - by cr2016 - 07-03-2017, 03:46 AM
RE: External DAC - by kjez - 09-11-2017, 12:04 AM
RE: External DAC - by gkkpch - 09-25-2017, 02:08 PM
RE: External DAC - by Luke - 09-26-2017, 08:59 AM
RE: External DAC - by gkkpch - 09-26-2017, 11:56 AM
RE: External DAC - by gkkpch - 11-06-2017, 07:33 AM
RE: External DAC - by Luke - 11-06-2017, 07:53 AM
RE: External DAC - by gkkpch - 11-06-2017, 10:11 AM
RE: External DAC - by Luke - 11-06-2017, 10:50 AM
RE: External DAC - by joe - 11-06-2017, 09:27 PM
RE: External DAC - by gkkpch - 11-07-2017, 01:08 AM
RE: External DAC - by joe - 11-07-2017, 03:46 AM
RE: External DAC - by Luke - 11-07-2017, 05:23 AM
RE: External DAC - by gkkpch - 11-07-2017, 09:48 AM
RE: External DAC - by joe - 11-07-2017, 10:09 AM
RE: External DAC - by mat1 - 11-07-2017, 01:29 AM
RE: External DAC - by gkkpch - 11-07-2017, 01:57 AM
RE: External DAC - by mat1 - 11-07-2017, 02:04 AM
RE: External DAC - by Luke - 11-07-2017, 11:29 AM
RE: External DAC - by gkkpch - 11-07-2017, 11:35 AM
RE: External DAC - by gkkpch - 11-11-2017, 01:46 PM
RE: External DAC - by joe - 11-12-2017, 06:04 AM
RE: External DAC - by gkkpch - 11-12-2017, 01:04 PM
RE: External DAC - by Luke - 11-12-2017, 03:59 PM
RE: External DAC - by mat1 - 11-13-2017, 04:52 AM
RE: External DAC - by Luke - 11-13-2017, 05:12 AM
RE: External DAC - by gkkpch - 11-14-2017, 11:55 AM
RE: External DAC - by joe - 11-13-2017, 05:15 AM
RE: External DAC - by mat1 - 11-13-2017, 05:24 AM
RE: External DAC - by joe - 11-13-2017, 05:27 AM
RE: External DAC - by mat1 - 11-13-2017, 05:57 AM
RE: External DAC - by Luke - 11-13-2017, 06:04 AM
RE: External DAC - by joe - 11-13-2017, 06:48 AM
RE: External DAC - by Luke - 11-13-2017, 06:50 AM
RE: External DAC - by joe - 11-13-2017, 09:47 AM
RE: External DAC - by Luke - 11-13-2017, 03:31 PM
RE: External DAC - by joe - 11-13-2017, 07:59 PM
RE: External DAC - by Luke - 11-14-2017, 12:04 PM
RE: External DAC - by gkkpch - 11-14-2017, 12:05 PM
RE: External DAC - by Luke - 11-14-2017, 04:51 PM
RE: External DAC - by joe - 11-19-2017, 06:59 AM
RE: External DAC - by gkkpch - 11-24-2017, 03:50 PM
RE: External DAC - by joe - 11-28-2017, 03:29 AM
RE: External DAC - by gkkpch - 03-17-2018, 04:56 AM
RE: External DAC - by gkkpch - 03-30-2018, 10:22 AM
RE: External DAC - by tllim - 04-02-2018, 06:24 PM
  Popping on SPDIF - External DAC mjgoode 3 12,416 05-14-2019, 11:12 AM
Last Post: TrisWood
