Fried eMMC?
With the eMMC inserted and no SD card, my pbp goes into maskrom mode, doesn't matter if I use the recovery button or not. I can't seem to do anything in this state, I can't even reset it:
matega@neofelisnebulosa:~/build/rkdeveloptool$ sudo ./rkdeveloptool ld
DevNo=1 Vid=0x2207,Pid=0x330c,LocationID=102    Maskrom
matega@neofelisnebulosa:~/build/rkdeveloptool$ sudo ./rkdeveloptool rid
Reading flash ID failed!
matega@neofelisnebulosa:~/build/rkdeveloptool$ sudo ./rkdeveloptool rci
Read Chip Info failed!
matega@neofelisnebulosa:~/build/rkdeveloptool$ sudo ./rkdeveloptool rfi
Read Flash Info failed!
matega@neofelisnebulosa:~/build/rkdeveloptool$ sudo ./rkdeveloptool db rk3399_usbplug_v1.19.bin
Opening loader failed, exiting download boot!
matega@neofelisnebulosa:~/build/rkdeveloptool$ sudo rkdeveloptool rd
Reset Device failed!
If I insert my 16G Samsung uSD card, boot it and execute `reboot loader`, it gets into loader mode, but then the only thing it sees is the uSD:
DevNo=1 Vid=0x2207,Pid=0x330c,LocationID=102    Loader
Chip Info:  43 30 33 33 0 0 0 0 0 0 0 0 30 30 31 56
Flash ID: 45 4D 4D 43 20
Flash Info:
       Manufacturer: SAMSUNG, value=00
       Flash Size: 14992 MB
       Block Size: 512 KB
       Page Size: 2 KB
       ECC Bits: 0
       Access Time: 40
       Flash CS: Flash<0>
I've tried swapping and switching the eMMC multiple times, I'll make some more tries but I'm fairly confident I toggled the switch correctly Smile The USB adapter might as well have disintegrated, I can't find it anywhere.
Fried eMMC? - by matega - 01-15-2020, 03:25 PM
RE: Fried eMMC? - by belfastraven - 01-15-2020, 06:48 PM
RE: Fried eMMC? - by matega - 01-16-2020, 12:59 AM
RE: Fried eMMC? - by belfastraven - 01-16-2020, 01:59 PM
RE: Fried eMMC? - by matega - 01-17-2020, 08:03 AM
RE: Fried eMMC? - by belfastraven - 01-18-2020, 04:33 PM
RE: Fried eMMC? - by matega - 01-28-2020, 06:47 AM
RE: Fried eMMC? - by matega - 01-28-2020, 07:53 AM
  Happy eMMC and SDcard OS usage for Pinebook Pro Newbies... Paulie420 42 60,136 11-20-2023, 06:22 PM
  I'm booting from NVME but I want to switch back to eMMC acruhl 4 1,488 04-23-2023, 06:58 AM
Last Post: acruhl
  Doesn’t power on after flashing emmc badguru 3 1,245 02-25-2023, 09:00 PM
Last Post: badguru
  eMMC problem with Tow-Boot/u-boot on SPI repa 3 1,718 02-21-2023, 01:49 AM
Last Post: repa
  Partial boot after installing Manjaro on emmc regivanx 11 3,170 02-06-2023, 09:11 AM
  Unable to Boot anything (emmc or SDcard) line72 5 2,029 01-17-2023, 12:07 PM
Last Post: nfms
  What OS have you recently flashed onto PBP eMMC? jcun4128 6 2,376 11-26-2022, 09:39 AM
  Unable to boot from emmc after flashing it rfm83 3 1,785 11-08-2022, 10:59 PM
Last Post: rfm83
  Pinebook picky about which EMMC will boot flatulent_piney 8 3,076 11-05-2022, 06:03 PM
Last Post: ajtravis
  After Flashing eMMC, Will Not Boot Mossbot 5 2,363 09-28-2022, 06:22 PM
